Fuji Lenses Weather Sealing
Started Nov 4, 2013 | Discussions
zenpmd Senior Member • Posts: 1,129
At the cost of some of the lenses being released, it is ridiculous - is it not - that they are not weather sealed? To me, its a form of insurance.
George Paulides Senior Member • Posts: 1,005
Re: Fuji Lenses Weather Sealing
Why? How many Leica or Carl Zeiss lens or in fact lens from most manufacturers do you see that are weathershield?
Besides there are no weathershield bodies as yet from Fuji. They will most probably release a weather sealed body in the future (if you believe the rumours) and a possibly a selected number of WS lens. That is the best you can hope. Do not expect the entire range to be WS.
Why impose an extra cost on all user to benefit a few.
Red5TX
Red5TX Senior Member • Posts: 1,586
+1.  Pentax has a beautiful line of weather sealed *Limited primes.  The new Olympus 12-40 is weathersealed and looks excellent.  If weathersealing is a source of anxiety for you, Fuji probably isn't your best choice.
airat Forum Member • Posts: 57
Pentax has not very much weather sealed lenses indeed, the best lenses are 'usual'.
As for me every lens has degree of weather/dust sealing because  internal surfaces stay clean.
Al Valentino Senior Member • Posts: 4,619
I posted a little over a week ago my conversation with Fuji that stated two new fast f/2.8 constant aperture zooms that are weather sealed may be coming - or at least added to the lens roadmap on the next 'map' update. Then a rumor of a new weather sealed body to be announced in early 2014 came out which fits.
So Fuji is listening and a more environmentally sealed combo seems planned for the foreseeable futureĀ
Fuji XE1 w/14, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
zenpmd OP Senior Member • Posts: 1,129
Sounds great if so. And some lens its more important than others, I suppose. But its definitely a nice to have for someone intro travel photography.
So much about the Olympus means I really should be buying the camera, but I just cannot get excited about it!
hellocrowley Senior Member • Posts: 1,271
They will release more expensive weather-sealed versions of the same lenses later so you can buy twice. Smart business!
cdp8 Forum Member • Posts: 99
Supposedly, the new X body arriving in January will slot between the X-E2 and the X-Pro1 and it will be weather sealed. If they plan to sell a weather sealed body, then weather sealed lenses must also be on the horizon.
I have an E2 on order. I've only had the E1 since April, and I have always skipped 2-3 generations when replacing electronics. But I pre-ordered an E2 for the PDAF, faster EVF refresh,  vastly improve auto ISO function and improved button arrangement. I'm thinking about cancelling my E2 pre-order and waiting to see what drops in January. But I have four XF lenses that aren't weather sealed, so then I would be looking at replacing glass instead of expanding my collection. I have until about November 14th to decide on the E2 pre-order.
afragisk Senior Member • Posts: 1,291
I also have an XE2 on order. I will wait until 1-2 yrs for more WS
lenses to be out b4 I sell..
bavarius6 Contributing Member • Posts: 574
None of the Pentax Limited primes are weather sealed. The DA* zooms and primes are weather sealed but they are modern style chunky lenses unlike the lovely jewel like Limited primes.
Pat
Red5TX
Pat
I stand very corrected!  Thanks for pointing that out.
Jeff Charles Veteran Member • Posts: 7,514
The Limited primes are not weather sealed, but Pentax does have a number of weather sealed lenses, but high-end and consumer.
Jeff
"Look it up. It's science." Skinny Pete
 Jeff Charles's gear list:Jeff Charles's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X100T Olympus E-M1 Fujifilm X-E2 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +5 more
Rod McD Veteran Member • Posts: 3,846
I've been sitting on the fence for a while and haven't taken the plunge into Fuji yet, much as I really like the XE1/2 and lens range.  The lack of water and dust resistance has been one aspect of Fuji's design that disappoints me.  As premium cameras it should have been designed into the system from the outset.  It's clear from Pentax products that it adds mere grams in weight and limited extra cost -  they've offered sealed DSLRs at prices less expensive than X series cameras.
IMO sealing should be standard - and I think sealing would be an asset to the X system.  I was intrigued to read above that a sealed camera between the XE and XP series is tipped to be offered early in 2014.  I'll look with interest........
Rod
 Rod McD's gear list:Rod McD's gear list
Canon PowerShot G1 X Fujifilm X-T1 Voigtlander 90mm F3.5 APO-Lanthar SL II Voigtlander 15mm F4.5 Super Wide Heliar Fujifilm XF 60mm F2.4 R Macro +8 more
Has there ever existed a weather sealed lens on any system which also has apeture control on it? Can anyone see any reason why this would be difficult?
