G6 1080p 60fps avchd files and aperture
Started Nov 3, 2013 | Questions
Ron Joiner
Ron Joiner Contributing Member • Posts: 898
Re: I've had no problem with iMovie and 1080/60. (nt)
Have you tired Corel VideoStudio X6?
Ron
 Ron Joiner's gear list:Ron Joiner's gear list
Panasonic Lumix DMC-GF1 Olympus PEN E-PL5 Panasonic Lumix DMC-G6 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Panasonic Lumix G 20mm F1.7 ASPH +6 more
Corkcampbell
Corkcampbell Forum Pro • Posts: 15,058
Did you mean this reply for the OP? (nt)
no text
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-RX100 III Sony Cyber-shot DSC-RX10 III Panasonic Lumix DMC-GH3 +4 more
d3xmeister Senior Member • Posts: 1,895
Re: G6 1080p 60fps avchd files and aperture
Aperture does not support AVCHD2 format that the G6 record. That's because is not a standard. If you want to store your videos in the same library, without any loss in quality, use a little free software called Remux beta. It remuxes your avchd files to m4v or mp4 without any loss in quality. It only takes 2-3 seconds per clip to convert. It supports batch conversion. It does not recompress your files, it's just changing the comtainer type for the video files, because inside all formats are H264 encoded.
 d3xmeister's gear list:d3xmeister's gear list
Nikon D5100
Ron Joiner
Re: Did you mean this reply for the OP? (nt)
Corkcampbell wrote:
no text
Yes
Aberaeron Senior Member • Posts: 4,509
Something odd with all this. Just checked the video clips I took last Sunday for the format. They are, as I thought, AVCHD HD 50p, and they upload and play with no problem in iPhoto. If it handles European 50p, it should handle American 60p just as well should it not?
I'm just wondering whether the OP has a computer that is pre-Intel?
Edit. You've got me wondering now whether the clips are HD Lite or full HD. The camera doesn't go into that much detail in its playback data.
 Aberaeron's gear list:Aberaeron's gear list
Fujifilm X20 Sony SLT-A57 Panasonic Lumix DMC-G6 Sony DT 35mm F1.8 SAM Panasonic Lumix DMC-ZS1 +15 more
mgibbs OP Regular Member • Posts: 389
i have an iMac with an Intel 2.4 ghz core 2 duo processor. 4gb of ram.  alas, it has begun to perform very sluggishly (another issue altogether).
 mgibbs's gear list:mgibbs's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS +7 more
I'll take a clip that will certainly be of the highest quality that the camera is capable of, but it is nearly midnight here at the moment so I'll post the result in about 12 hours time.
Corkcampbell
I think that I have about the same machine (summer 2009) with same RAM.
Mine is a 2.66 Core 2 Duo 24" iMac.
No problem with AVCHD video files in iMovie, LightRoom, etc. Have never tried in Aperture and don't plan on it. These are files from a GH2, Sony A33/65/77, and a interlaced files from a Pany camcorder. My 1080/60 files are from a GH3, which are not wrapped in AVCHD.
Corkcampbell
Thanks for the Remux beta tip; I'll give it a try. (nt)
no text
i have it set to highest hd setting - avchd 1080p 60fps 28mbps.
PC Wheeler
PC Wheeler Forum Pro • Posts: 16,028
mgibbs wrote:
have also stayed away from iMovie, as i had an older version that took forever to upload movies (probably my older computer's fault). maybe that is a solution? or is iPhoto preferable - have you had success with iPhoto and 1080p 60fps?
New version of iMovie with Mavericks, too.  I haven't tried it but supposed to deal with AVCHD nicely.  I tend to shoot MOV.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS +5 more
Not AVCHD2. I have a Sony RX100 and shoot video at 1080p50, only photos show up when I import with any Apple software. Lightroom won't ,,see,, them either. I have to manually import them.
Nikon D5100
Sorry, yes the clips that have uploaded to iPhoto are 1280x720 50p, not Full HD.
I shot at the highest quality this morning and, infuriatingly, it doesn't transfer to the iMac. I'll try the same with my Sony camera some time today.
Oddly and probably not related to the above, when I connected the camera to the iMac this morning, it tried to transfer four duplicate video clips to the computer. It has not tried that before and I connect and transfer images regularly. The 16gig card has about 13gig of images and video, mostly stills on it.
bummer.  i was hoping you were doing something correctly that i was not!
That is because 1080p50 is not a standard, there is only 24p, 25p and 30p.   720 is a standard up to 60p.  Panasonic and Sony are on their own with 1080   50p and 60p.  Remux beta is a quick solution for this, it converts them instantly in mp4 or m4v in just a few seconds, with no loss in quality.
Nikon D5100
just downloaded remix beta today - worked as advertised!  thanks for the tip - until aperture supports the native panny 60fps files, i will likely go this route.  not one stop shopping, but not too inconvenient either....
I've just experimented a bit with these 50/60p movies on both my Panasonic and Sony cameras. Using Finder, I find the clips in the camera's AVCHD folder [on the card obviously] and just clicked to open them in Quick Time. They open and play with no problem. Then I just opt to Save and rename them in a folder I've created especially for them on the desktop. I can open this folder like any other and click on the clips to open them in Quick Time. They appear to be saved as .mov files.
This seems to lose some quality, but I'm not sure yet.
Will try the redux program some time to compare. Thanks.
thanks d3xmeister - tried remux beta out and worked just as you said.  until aperture supports native 1080p 60fps files, this is a good and not-too-inconvenient solution.  thanks!  and thanks to all who were kind enough to weigh in.
