Tamron 150-600mm
Started Oct 31, 2013 | Discussions
SHood
Veteran MemberPosts: 4,558Gear list
Tamron 150-600mm
Oct 31, 2013
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
paulski66
Senior MemberPosts: 2,736Gear list
If this is as great as the 70-300 VC...
In reply to SHood, Oct 31, 2013
...then Shotcent's will be posting pics of his kid's eyeball taken from two counties away!
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
SHood
SHood OP
Picture of new lens
In reply to SHood, Nov 6, 2013
SHood
SHood OP
Tamron SP 150-600mm F5-6.3 DI IF VC USD
In reply to SHood, Nov 7, 2013
Price looks good.
http://www.canon-board.info/obiektywy-21/tamron-150-600-f-5-6-3-vc-usd-93364/
- focal 150-600mm
- focal f/5-6.3
- Filter diameter: 95mm
- Internal Focusing (AF)
- Image Stabilization (VC)
- ultrasonic motor (Ultrasonic Silent Drive)
- price (projected) $ 1,500 (about 6,000 PLN)
- dust + moisture resistant (seal) certainly more
Michael Benveniste
Senior MemberPosts: 2,342Gear list
Re: Tamron SP 150-600mm F5-6.3 DI IF VC USD
Hmm.  600/6.3 ~= 95.24mm.  So if this thing really exists and has a 95mm filter ring, then Tamron is "hedging" either on the focal length or the maximum aperture.
I miss the days when I used to be nostalgic.
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D200 Nikon 1 V1 Nikon D800 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +33 more
SHood
SHood OP
In reply to Michael Benveniste, Nov 7, 2013
Zooms always cheat a bit on the focal length and aperture.  The patent show 582mm f6.45.
Dennis
Forum ProPosts: 16,158
SHood wrote:
Price looks good.
- focal 150-600mm
- focal f/5-6.3
That sounds almost too good to be true.  I owned a Minolta 400/4.5, which is similar to 600/6.3 with an imaginary 1.5X teleconverter on it.  It had a 95mm front filter (took drop ins).  It sold for $1900 years ago, but was built like 300/2.8 & 600/4 type lenses.  Screw drive AF (no built in motor), no IS.  Nowadays you can buy a used one for $2500 or so.
So a zoom with updated optics that goes out to 600/6.3 with a built in focus motor and VC for $1500 sounds like a tremendous bargain.  Presumably, the build is nothing like that old Minolta.  (I've seen the 180/3.5 and 70-200 and they're decent, but not like the more expensive OEM brands).  If it comes through at this price and is good at the tele end, I could be very interested in this lens.
- Dennis
brunobarolo
Senior MemberPosts: 1,048
SHood wrote:
Price looks good.
I'm afraid at that price it will not be better than the Sigmas, which means rather mediocre optical quality at least at the long end. I wish I'm wrong, though
Luftwalk
Forum MemberPosts: 78Gear list
In reply to brunobarolo, Nov 7, 2013
I think that's the big question...how well will it perform on the long end...Hopefully, since it's 600mm, it will edge out the Sigmas at 500mm
Anyone knows when this will be made available?
 Luftwalk's gear list:Luftwalk's gear list
Nikon D750 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 35mm f/2D Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tamron SP 70-300mm F/4-5.6 Di VC USD +3 more
photospots
Regular MemberPosts: 156Gear list
brunobarolo wrote:
SHood wrote:
Price looks good.
Hi
If you look at the number of glass (elements and groups) in the lens it is build like the 80-400/100-400/70-400 from Nikon/Canon/Sony, and it is a big increase from the 200-500, so I wouldnt rule out a good image quality from this monster lens
 photospots's gear list:photospots's gear list
Nikon AF-S Nikkor 14-24mm f/2.8G ED
Luftwalk
In reply to photospots, Nov 7, 2013
Take this with a grain of salt, but this is taken from a certain polish forum and is supposed to be a sample of the lens at 600mm.
It's a small size sample, has no exif to confirm, but if it's for real it looks very promising.
opiecat
Senior MemberPosts: 2,003Gear list
In reply to Luftwalk, Nov 7, 2013
if that shot is from the new 150-600, that's very promising
http://opienc.wordpress.com
'when 900 years you reach, look as good you will not'
-- master yoda
http://jordanpaw.zenfolio.com
ltcdata
ltcdata MOD
Regular MemberPosts: 207Gear list
Re: Tamron 150-600mm
 ltcdata's gear list:ltcdata's gear list
Nikon D80 Nikon D7100 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 50mm f/1.4D +3 more
Luftwalk
In reply to ltcdata, Nov 7, 2013
And full size as well....excellent. Thank you for that link. At 100% you do see certain problems, but that is to be expected from such a lens, in fact I would say it fares better than I thought it would. Hopefully they went for a better longer than wider end.
opiecat
it might be too early to tell, but are these images from the tammy better than the 120-400 or 150-500 sigmas?
-- master yoda
SHood
SHood OP
Focus limits
opiecat
Re: Focus limits
nice, nice!  time to save up
-- master yoda
unknown member
(unknown member)
Re: Focus limits
In reply to opiecat, Nov 7, 2013
+1
SHood
SHood OP
Re: Focus limits
-- master yoda
I wish it had a short range limit of 2.7m-15m.  The long range limit is of no use to me.
opiecat
Re: Focus limits
-- master yoda
ditto.  i wish the limiter was at around 5m.  but, we'll see after some folks get to use it
-- master yoda
