70D 7-shot bracket
Started Oct 30, 2013 | Questions
David Neese Regular Member • Posts: 265
70D 7-shot bracket
Trying to figure out how to do a 7-shot bracket. I can do three shot through Auto Exposure Bracket Menu, but can only get three and there seems to be negligible difference in the three shots. Thanks for any help
Canon EOS 70D
mfait Contributing Member • Posts: 653
Re: 70D 7-shot bracket
The bracketing only supports 3 shots.
Sounds like you need to increase the AEB range.
 mfait's gear list:mfait's gear list
Canon PowerShot S100 Canon EOS 450D
TTMartin
TTMartin Veteran Member • Posts: 7,304
At least on the 6D the number of bracketed shots is set in the Custom Function Exposure Menu.
To set how wide the brackets are I have added the Expo.comp/AEB menu selection to 'My Menu' after selecting it, turn the 'main dial' (the one by the shutter) and you will see the lines for each exposure spread out below the exposure compensation scale. If you have it set to 5 you will see 5 lines.
edit: You can also offset the bracketed exposures using exposure compensation.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
TTMartin
The 70D supports 2, 3, 5, or 7 shots, the same as the 6D.
David Neese OP Regular Member • Posts: 265
Okay. Thanks. The manual said three, but a few websites had it at up to 7 (even DPReview listed: AE Bracketing±3 (2, 3, 5, 7 frames at 1/3 EV, 1/2 EV steps) @ http://www.dpreview.com/news/2013/07/02/canon-announces-eos-70d-mid-range-SLR-with-dual-pixel-cmos-af-on-chip-phase-detection .
Maybe they were going to go to 7 but changed it.
mfait, how is this done on the 70D? Can only see option for 3. Thanks.
Found it. Just as post above said - it is in Custom Function Exposure Menu. Thanks for everyone's help.
Excel Fotografia New Member • Posts: 1
Can somebody tell me how? (like step by step) i juts can't find the way to make a 2, 5 and 7 Bracketing with my 70D, and i¿m really going to need that function.
Do i need any firmware update?
Thanks anyway
nisda New Member • Posts: 13
Open the menu
goto the custom function tab (camera symbol 2nd in from  the right)
Pick Cfn I Exposure
Use the back wheel to select No 5 - number of bracked shots
Pick 3:7 shots
Press menu twice to get out.
Press Q to get up the quick menu screen
select the exposure compensation box - the one with numbers from -3 to 3.
Use the top wheel by the shutter button to pick you spread of exposures.
Take the photos either by using the shutter button with drive set to high speed or if on a tripod use the 2 seconds delay and it will take all 7 photos automatically.
Michele720 New Member • Posts: 7
nisda wrote:
Open the menu
Pick Cfn I Exposure
Pick 3:7 shots
This explanation worked PERFECTLY for me!  Thank you so much!  Made myself a cue card and stuck it in my bag for future reference, but I went out and shot alot of stuff after I learned how to get this camera to bracket without merging the photos, AND to get up to seven images bracketed.  Thanks!  Only thing I dont like is having to reset the Exposure Compensation everyt time you shut the camera off.  I'm wondering if there's a function to save my setting so I dont have to keep resetting it.
TTMartin
Michele720 wrote:
nisda wrote:
Open the menu
Pick Cfn I Exposure
Pick 3:7 shots
Yes you can save it to your custom user setting (C on the mode dial), then when you want to do bracketing, just set the mode dial to C and the camera will be set exactly how it was when you saved the settings.
