Help. Having Trouble with Wifi on X-A1
Started Oct 23, 2013 | Discussions
Photo-Wiz Senior Member • Posts: 1,651
I just got a Fuji XA-1. I'm having trouble getting the wifi going.
I downloaded the Fuji camera application on both the Ipad 4 and the Iphone 5. I tap connect, and also tap the wifi button on the X-A1. The Fuji says it is searching, but it never locates either the Iphone or the Ipad. The Iphone/Ipad don't see the Fuji either.
I also tried going through the playback menu on the Fuji, but it still won't work.
I typed in the router info for my router (password).  The X-A1 refuses to connect.  I re-typed the password just in case I had a typo the first time.  It refuses to connect.   I need help, or Fuji needs a firmware upgrade --- or hopefully not...I have a dead wireless in the X-A1.
 Photo-Wiz's gear list:Photo-Wiz's gear list
Sony RX100 Panasonic LX100 Sony RX10 III Fujifilm X-T100 Fujifilm XF 16-80mm F4 +2 more
sinclaircg New Member • Posts: 1
Re: Help. Having Trouble with Wifi on X-A1
I'm having similar problems.  Did you get a solution?
 sinclaircg's gear list:sinclaircg's gear list
Fujifilm X100S
eugene69 Forum Member • Posts: 69
press wifi on your x camera , then open wifi the on your tablet and tap connect once your fuji camera appears on available wifi connection once connected, only then open your app to connect to your camera in this order...
Daniel Lauring
Daniel Lauring Veteran Member • Posts: 9,343
Yes.  The problem is you are trying to connect your camera as a client to the local wifi.  Camera wifi works by connecting your phone or tablet device to the camera as a client.
Step One:  Turn on WIFI on camera.
Step Two:  Connect WIFI on device to WIFI on camera.
Step Three:  Open app and connect to camera.
The Olympus software works the same way except you have to register your camera with the device first, which requires another couple steps.
mariorenz Regular Member • Posts: 273
You don't have to be inside a wireless network otherwise the wifi link between camera and smartphone doesn't work...
_____________
Mario
westofwy New Member • Posts: 19
I have found that I was having trouble connecting an iPhone to the X-T1's wi-fi until I pressed the OK/Menu button while the phone was trying to connect. The OK button, while the phone is trying to connect has the word "Change" next to it. When you click the OK button, the OK button function becomes "Transmit". Click it again, and my phone connects to the camera Wi-Fi and I can use the app to control the camera.
At first, I could only connect my iPad. By clicking the OK button "Change", then "Transmit", things work. I hope you are able to get things to work.
West
 westofwy's gear list:westofwy's gear list
Sony RX100 III Fujifilm X-T2 Nikon D850 Fujifilm X-H1 Nikon Z7 +21 more
Mudfog New Member • Posts: 1
Thanks for help.  I was going crazy trying to connect my iPhone after using my iPad as a remote.
 Mudfog's gear list:Mudfog's gear list
Fujifilm X100S Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
Nigni New Member • Posts: 2
Hello Folks, same problem here but with the Fuji X30.. Even if i follow the instructions i cant connect the camera to the Ipad or Nexus 5.. I connect only 2/3 times since i buy the X30.. Other X30 owners can help me? thanks!
 Nigni's gear list:Nigni's gear list
Nikon Coolpix AW110 Fujifilm X30 Nikon D800 +1 more
meandering New Member • Posts: 6
This solved it for me (X100s), thanks so much!
Fullhouse2009 New Member • Posts: 2
I can not find camera's wifi on iphone. Camera search then i can not cancel, or turn off camera. After reset i can cancel search, but still can not find camera wifi on smartphone (even other smart phone)!
"I can not find camera's wifi on iphone. Camera search then i can not cancel, or turn off camera. After reset i can cancel search, but still can not find camera wifi on smartphone (even other smart phone)!"
In addition, I find error when try to connect camera to wifi router: "WiFi NVRAM Warning: ERR 0x10"
Please help me solve this problem!
mammasaurus New Member • Posts: 1
For anyone using an X30 and having problems!
Do not install the Fujifilm Camera Application - instead go to your X30 manual and go to page 44. Scan the QR code and that takes you to the Fujifilm Camera Remote app which is you download does work.
I just googled 'Fujifilm app' when I got my X30 and installed the only one that came up - but actually that one isn't compatible with the X30.
Hope that helps someone - took me an hour to work that out!
Annie x
simonfrios New Member • Posts: 1
Yes sir! I thought the camera had something wrong with it until I read your comment.
One must go to Fuji,
then the Apple store,
then WiFi on camera
then launch app
then hit OK on camera!
doolittledoc New Member • Posts: 1
I am having the same problem with a new fuji xp... the camera and the i phone 6 app both say they are searching for each other but never find each other for wireless transfer of photos... has anyone found a work around?? As far as I can tell the app is the latest version.
Teri
