Who Wants a DA 29 mm f2.0 Limited Lens?
Started Oct 22, 2013 | Discussions
haziz Regular Member • Posts: 302
I have the DA 21 mm Limited, I love the lens but sometimes find it a bit too wide. Obviously I can crop, but it is always nice to crop 'in the camera' while composing. I probably would have been happier with a 24 mm lens producing the field of view of a 35 mm lens on 35 mm film.
I recently acquired the DA 40 mm Limited. Very nice, but again maybe just a hair too long.
I find myself hankering for a 29 mm f2.0 lens. Small, and unobtrusive and with "Limited" quality; hence the f2.0 rather than faster. We really need a normal lens for APSc format sensors.
So who else is hankering for a compact DA Limited 29 mm f2.0 lens?
Bob Corson Senior Member • Posts: 2,316
Re: Who Wants a DA 29 mm f2.0 Limited Lens?
Seems to me the 35mm  is pretty darn close to "normal" lens. At least that is what I use for normal and at 52mm equiv it fits the bill perfectly!
Bob Corson
To truly see one must open their mind as well as their eyes
 Bob Corson's gear list:Bob Corson's gear list
Pentax K-30 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro +5 more
awaldram
awaldram Forum Pro • Posts: 12,316
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
HozicEmir Contributing Member • Posts: 708
24mm 1.8 or 2.0 close focus (n/t)
Bill Robb Senior Member • Posts: 3,332
I bought into another system because Pentax has refused to bring a fast standard lens to market. They need to fill that hole in their lens line.
drummercam Contributing Member • Posts: 773
a pic is worth 1,000 words
 drummercam's gear list:drummercam's gear list
Pentax K-01 Pentax K-30 Pentax K-3 Pentax K-S2 HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR
viking79
viking79 Forum Pro • Posts: 14,137
I gave up asking many years ago.
Here is my post from 5 years ago: http://www.dpreview.com/forums/post/28315867
when there were rumors of a 30mm f2 or so lens floating around.
Now that Ricoh owns them they have a better chance of coming out with some nice new lenses
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Tyler Monson Senior Member • Posts: 1,452
No thank you
I've been using the DA21 since 2007 (on K10, K20, K-5) for more than 90% of my exposures. On occasions when I require wider or narrower view, I have the DA15 and DA40.
I have no qualms about cropping (or merging frames) or anything else in the virtual darkroom—my interest is only in the end result, and I have been very pleased with Pentax.
Having less equipment means better portability and fewer decisions to make—and better images, I believe.
FWIW, I almost never use the maximum aperture on any lens. High speed just means more size and weight.
Stepping off the soapbox now.
The Profligatographer
More Original Refrigerator Art
Here Now, Gone Before Long
UtahManSir Veteran Member • Posts: 4,648
Nope, want a DA* (or WR like the DFA 100) 24mm f1.8-2.0
29/28mm is too long.
Lloyd
“For every problem there is a solution which is simple, clean and wrong.” Henry Louis Mencken
http://lloydshell.blogspot.com/
http://lloydshell.zenfolio.com/
WSSA #354
http://lloydshell.zenfolio.com/img/s3/v41/p234497562-3.jpg
I was thinking much the same thing, but the OP did specify compact. The 31/1.8 is a big, heavy horse of a lens. The same thing with an APS-C image circle should be much smaller. For that matter, my A35/2 is about half the size and 1/3 the weight.
But neither are what I consider a fast lens. Something in the 30mm range with an f/1.4 or faster maximum aperture would be nice.
jimrpdx
jimrpdx Veteran Member • Posts: 3,319
I have the SMC-A 24/2.8 and it's a nice focal length for sure.  Trouble is, I also have a DA16-45 and it defies me to use primes, it's excellent (though a bit slower), focuses close and its modern coating have made a significant difference in many shots.  Each added lens disturbs my dreams -er dream kit, which would now be 16-45, 70, 105 macro and 50-200 for all the rest.
Jim in Oregon -- Pentax user, Alpha & m4:3 veteran
talking to myself at http://granitix.blogspot.com
 jimrpdx's gear list:jimrpdx's gear list
Olympus PEN E-PM2 Samsung NX300 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Sigma 30mm F2.8 DN | A +1 more
timo Veteran Member • Posts: 4,778
I have the DA21 but I use the K28/3.5 more. More comfortable with the FOV. It's fine at 3.5 and it's very rare that I hanker after anything faster at that length. 35-40mm is getting a bit close. But's a matter of personal taste, obviously.
tim
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 +1 more
Gary Martin Veteran Member • Posts: 3,444
I would prefer a weather-proof DA* lens with a modern internal focusing motor. The lack of a weather-sealed prime shorter than 55mm is a serious omission, IMO. Would definitely NOT be cheap, however.
 Gary Martin's gear list:Gary Martin's gear list
Pentax K-01 Pentax K-5 IIs Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +9 more
dwm2020 Regular Member • Posts: 107
I started this thread a few months back asking the same thing.
http://www.dpreview.com/forums/post/51593473
A 27mm or 28mm seems a bit better since as mentioned the 29mm is a little close to the 31mm. Plus 28mm on crop sensor is close to 43mm on 'FF', which is a nice FOV. I'd also take a 24mm if it came to that.
I would have to agree that a weather sealed DA* would be beneficial in this range, as there are no primes that are wide angle under the 55mm. And it's nice to be able to leave a camera on a tripod for night time lapses without having to worry about weather.
Would be nice to see something appear on the road map.
Dave.
 dwm2020's gear list:dwm2020's gear list
Pentax Q Pentax K-01 Pentax K-3 +12 more
Tom__Brown Senior Member • Posts: 1,344
Agreed. DA 21L perfect FL for me too. (nt)
-- Tom
 Tom__Brown's gear list:Tom__Brown's gear list
Pentax K100D Pentax K20D Pentax K-5 Pentax K-01 Pentax smc DA 14mm F2.8 ED (IF) +6 more
Conjure
Conjure Regular Member • Posts: 413
I totally agree. There are only 2 small gaps in the current lineup of special (LTD or SDM or */WR) lenses:
DA 15 ltd
DA 21 ltd
--> DA*26 SDM (WR)
FA 31 ltd
DA 35 macro ltd
DA 40 ltd
FA 43 ltd
--> DFA 50 macro WR
DA*55 SDM (WR)
DA 70 ltd
FA 77 ltd
DFA 100 macro WR
DA* 200 (WR)
DA* 300 (WR)
But the size/weight-advantage of primes is gone if you buy all of them
And the WR-advantage is useless if you have to change prime lenses every minute.
steephill Veteran Member • Posts: 9,747
Previous similar lens spec designs
There are the A and M 28mm f2 lenses - fairly small and light but MF only of course. The K version is much bigger and heavier. Then there was the FA*24 f2 - highest grade but not so small. The FA*31 f1.8 has been mentioned but it isn't that size just through malice on the part of Pentax. A re-design might be able to use fewer elements though. There is unlikely to be any size benefit in designing an APS-C specific lens at these focal lengths.
Steve
www.pbase.com/steephill
paulkienitz
paulkienitz Veteran Member • Posts: 5,204
everybody wants that
Though personally, I'd prefer a 24mm, because I'm not interested in the slow-ass 21.  For me the perfect set of short primes would be 12, 24, and 50.  The 12 can be slow but the other two need to be faster.  The only one I've got is the 50.
"A good photograph is knowing where to stand." -- Ansel
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
Conjure
awaldram wrote:
Wouldn't it clash in sales
Happy Birthday Andrew!
View original size!
Anton
Not really, I can divide up the load a lot easier with primes rather than a couple of fat zooms.
This, of course, is not true at all. Not even close.
