Tele-extender or cropping?
Started Oct 21, 2013 | Discussions
athleticpete New Member • Posts: 6
I have a teleplus 2x extender which I have used occassionally with mixed results on a Canon 40D and 70-300 zoom. I don't like fact that AF does not work or is extrememly slow so therefore it is only used in extreme circumstance.
I have just treated myself to a Sigma 120-300 f 2.8 zoom so thought I would give the extender another try. The AF works reasonably well and I can manually focus if necessary but now I can really notice the difference with and without the extender. Without the extender at full 300mm zoom pictures are pin sharp, but with the extender, even at 150mm there is a definite loss of quality.
An example without the extender at 1/2000s focal length 250mm
Since I am also considering upgrading my body to a 7D I wonder if, with the increased pixels of the 7D, would I get better picture with a 2x digital zoom in photoshop, rather than the 2x optical zoom on camera. i am sure it would work for small prints, but what about A· size, or larger.
Any thoughts
TIA
Pete
valenciabioparc.wordpress.com
athleticpete OP New Member • Posts: 6
Re: Tele-extender or cropping?
Here's one using the tele-extender, 1/160s at 300m x2.
Admittedly this is at the full range of the lens but it is the best I managed among several using AF and manual. Whilst this is an OK shot it has nothing like the detail of the Eagle.
Am I expecting too much?
steephill Veteran Member • Posts: 9,747
Handholding?
1/160th sec handheld at 600mm focal length is pushing your luck a bit too far. Tripod mounted you lose camera shake but the shutter speed might still be too low to avoid subject movement.
Steve
www.pbase.com/steephill
StevenMajor Forum Member • Posts: 76
You should  test your equipment to learn what works best.
Since your concern is about sharpness, shoot the same static, detailed composition with and without the converter ( a flat brick wall works well  parallel to the cameras sensor). Use a tripod and only change the shutter speed when using the converter. Treat both image files the same in post processing. Do a 2X crop on the non converter image. Judge both files side by side in Photoshop and you will have your answer.
Since you have a zoom, you can also do the same test at different focal lengths if you wish and you will likely see that results will differ.
What affects image sharpness is camera movement, subject movement, and lens quality. That is why you should use a tripod (correctly) and shoot a static subject for your test..so the results will be affected only by the lens.
That's the long answer...the short answer is to throw out that low end piece of junk converter.
Good Luck
Henry Falkner
Henry Falkner Forum Pro • Posts: 13,236
With a tele-converter, the minimum distance at which the camera focusses is further away.
My Olympus SP-570UZ (which does have an adaptor for the Olympus B-300, later renamed the Tcon17) this is particularly noticeable when I try to get small birds.
My Olympus SZ-30MR (for which I had to bodge an old adaptor), works beautyfully with the Olympus B-300.
This particular converter is also tried with other brands of camera. I have read reports saying that the B-300 focus distance with some cameras is wrong, and that adaptors have to be modified to correct this.
I have also found that dust settling on the tele-extender during long periods of storage also misleads the focussing, and the B-300 in particular is prone for the butter finger treatment since it has a large exposed glass surface.
Historically, the B-300 was designed for a 35mm all-in-one SLR, the Olympus IS-3000. Olympus used to state categorically that the B-300 would NOT work with their digital cameras, but I have used it directly with the Olympus C-1400L and the C-2500L at that particular time.
Other tele-extenders may have a similar history.
Henry
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1
BertIverson Veteran Member • Posts: 3,470
athleticpete wrote:
... Since I am also considering upgrading my body to a 7D I wonder if, with the increased pixels of the 7D, would I get better picture with a 2x digital zoom in photoshop, rather than the 2x optical zoom on camera. i am sure it would work for small prints, but what about A· size, or larger.
Any thoughts
TIA
Pete
A couple of years ago (on a 12MP DSLR), I did some tests to compare digital zoom with 2x tele-extender. I convinced myself to forget the tele-extender. Today with 20-36MP cameras, 2x digital zoom makes even more sense to me. Nothing to carry and no lens fiddling. Maybe in the 1-3MP camera era the optical extenders made sense.
of course, just my experience and personal preference,
Bert
 BertIverson's gear list:BertIverson's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 +4 more
joejack951 Senior Member • Posts: 2,682
Not all teleconverters are created equal, especially when it comes to 2X converters. If you aren't using the latest Sigma DG 2X teleconverter, you may be selling that option short.
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Good Luck
Thanks for the honesty Steve. It was bought when I first started and couldn't afford much more. In all honest I generally can't be bothered with fiddling about, especially as the results aren't that good.
www.valenciabioparc.wordpress.com
Thanks to everyone for taking the time to reply. I think I will try the scientific approach by taking the same shot with the same settings on a tripod just to see if it is worth persevering.
fishy wishy
fishy wishy Senior Member • Posts: 3,107
Digital zooms have always been called bad, even if an optical zoom can also be quite bad.
As someone who has had to crop images more often than he'd like, I'd counsel you to beware of the increase in image noise with cropped pictures. At a low ISO you could crop and get something pleasant for web viewing, but it's not the solution of quality.
(Of course, you could argue the toss just to please yourself)
Doug Haag Contributing Member • Posts: 816
Several years ago I did precisely this test with a Nikon 70-300 and a Tamron 1.4 converter ordered from B&H.  Because my 90mm f2.8 Tamron lens is sharper than any of my three Nikon lenses, I assumed it would be good glass.
Immediately following the test, I returned the converter because a crop of the same portion of the image taken without the converter was noticeably better than the same view with the converter.
And, yes, the camera was on a tripod and I held the f-stop constant (adjusting only the shutter speed) so that the f-stop would be the same.
The Sage Knows Contributing Member • Posts: 910
Crop - but with a sharp original
BertIverson wrote:
Any thoughts
TIA
Pete
Bert
With enough megapixels (that's why I get much more than I think I'll need for enlargements) and as long you start with a sharp - both optically and without motion blur - original, a crop of up to about 2x will look as good or better than an original with a converter. That is because you will be using the sharpest part of the lens image (cropping out the corners) yet still retaining enough pixels to print an 8x10ish enlargement and more than enough for web.
See also this thread where the subject of cropping was "discussed" (for the most part) :
http://www.dpreview.com/forums/post/52240780
Robert
