PENTAX SMC DA 70mm f/2.4 AL Limited
Started Oct 17, 2013 | User reviews
Robert A F
Robert A F Senior Member • Posts: 1,010
The Sharpest lens in my arsenal of optics. Might be the sharpest of all APS-C dedicated lenses on the market. Build quality and compactness second to none.
Seize The Day!
Pentax smc DA 70mm F2.4 AL Limited
Telephoto prime lens • Pentax KAF • 21620
Announced: Sep 13, 2006
Robert A F's score
5.0
Average community score
5.0
Tan68
Tan68 Veteran Member • Posts: 5,539
Re: PENTAX SMC DA 70mm f/2.4 AL Limited
Carpe DA !
 Tan68's gear list:Tan68's gear list
Phase One Capture One Pro +1 more
samhain Senior Member • Posts: 1,157
Not the sharpest, but a good one.
I think the 43mm & 55mm hold the title.
(I think the 77mm might have it beat too, can't remember the photozone test scores off the top of my head).
Robert A F
Robert A F OP Senior Member • Posts: 1,010
Center to edge sharpness is progressively better for landscapes than the 43 or 77. I will give up speed for a well corrected lens any day. 55 was designed as a portrait lens. So (70) yes, the sharpest.A lens is more than how sharp it is in the center.Your mileage may vary.
Cheers, Robert
Robert A F
Tan68 wrote:
Carpe DA !
Carpe DA :0)
mauritsvw
mauritsvw Senior Member • Posts: 1,024
Isn't the FA50 mm f2.8 macro the sharpest? I've heard that somewhere.
 mauritsvw's gear list:mauritsvw's gear list
Canon PowerShot SX50 HS Pentax K-5 +1 more
Tan68
He did say 'might be the sharpest' rather than 'is sharpest'.
Perhaps something like 'the DA70 is among the sharpest' would have been less risky and open to suggestion  :^)
Robert A F
I was just trying to make the owners of other brands feel insecure
Sleepless nights ahead for Olysoncankon users.
Cheers, Robert
Robert A F
Along those same lines I might say also that the 70mm often provides that elusive 3D effect that photographers like to talk about. I think there is 3D effect from either having  a large maximum aperture lens like a f/1.4 or just having a background that is far enough away to give that nice soft out of focus effect no matter the f/ stop or that magic light of a low sun separating scene elements.  I used to use a Leica M4P for my light weight black and white work. That camera and three basic lenses (28, 50, 90) had that magic often. Now I'm noticing that pure separation of elements in a scene from my 70mm and my newly acquired 60-250mm that I used to experience from the Leica. The K5 resolution might have something to do with it also. The Leica and Pentax 3D effect that I notice is from pure contrast, resolution and color separation. I use all of the DA Limiteds except the 40mm and the 70mm has that"magic" often.
I would like to hear other opinions on the paint brushes you use. Now I'm really out on a limb.
Robert
SBS
SBS Senior Member • Posts: 2,006
"The Sharpest lens in my arsenal of optics."
Mine too.
(My arsenal: 15, 21, 31, 43, 70, 77, 100.)
Tan68
I use 15, 21, 77
I struggled over the 70 v. 77mm.  The 70 is smaller and lighter (if you count ounces when you travel).  At the time, the price of the 70 had risen to quite close to the 77 so I went FA.  Now the FA costs more again...
I am pretty happy with these three lenses.  I use the 77 quite often.
When I think I will be around animals, I take a Tamron 70-300 Di.
I do have other lenses, but I don't really use them...
fakuryu
fakuryu Senior Member • Posts: 1,321
Seize The Day!
+1 for the DA70
I have the DA40 and DA70, might get a HD 35 macro Limited in the future because of some product photography that I'm into right now if it pays well enough.
There is no such thing a "Pro" level gear, just Pro level work.
 fakuryu's gear list:fakuryu's gear list
Panasonic Lumix DMC-LX7 Olympus PEN E-PL1 Pentax K-r Pentax Q Pentax K-5 II
britcam
britcam Senior Member • Posts: 2,414
Robert
I noticed significantly more "3D effect" when using my 60-250 and 70 last week in Giverny then Paris. Very different subject matter of course. This with my K5IIs, and is much more than I have seen in the past using a K5, K-01 and K30. Edges seem to me more defined, so perhaps it is a result of higher resolution, contrast & those lenses .....
Kind regards
britcam - Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Ricoh GR Digital IV Fujifilm X-E1 Pentax K-5 IIs Fujifilm X-A1 +8 more
Robert A F
I came really close to buying the 77 when I was deciding between the two. About 4 years ago the 77 was alot higher in price. I haven't noticed too many photos posted with these two lenses. I think they are both great, a person can't go wrong with either.
Robert A F
I noticed significantly more "3D effect" when using my 60-250 and 70 last week in Giverny then Paris. Very different subject matter of course. This with my K5IIs, and is much more than I have seen using past using a K5, K-01 and K30. Edges seem to me more defined, so perhaps it is a result of higher resolution, contrast & those lenses .....
Kind regards
britcam - Rich S
I agree completely. A K5IIs or K3 is in my future.
britcam
fakuryu wrote:
Seize The Day!
+1 for the DA70
I have those lenses as well - the 35 macro, 40, and 70.
I've started getting into the habit of taking a prime along with a DA zoom so as to get a very flexible and high IQ combo that takes up very little space. Two zooms is often overkill, but a small prime and a zoom is about right I reckon ...
So for me, its the 35 or the 40 that takes a ride, with either the 50-135 or the 60-250 .... Otherwise its the 70 with the 16-50.
Kind regards
britcam - Rich S
Tan68
Most of the pictures I have posted recently have been taken with the 77mm.  I use it more that just quite often, actually...
SBS
Or better yet, both. I have both and use them differently. Although, the 70 translates to an ideal focal length for portraits (105mm), I do not consider this the ideal portrait lens, except maybe, for men. It is sharp to a fault. If you shoot a women with this lens, you better be prepared to do some skin softening in post processing. This makes it an interesting lens for male portraits, and of course, landscapes, architecture, etc. I also like to use it at wedding receptions with flash, because it produces contrasty, punchy images with flash. The 77 is certainly sharp enough, but it also has a photographic depth and complexity that creates intrigue. I'm sorry, but you simply must have both of them. There is more to the character of lenses than sharpness and focal length. These two lenses are some of the best lenses that Pentax makes, as well as some of the best lenses made by any producer.
Robert A F
Well said. Now I'm thinking 77mm for my arsenol.
