Interesting features of the D5300
Started Oct 17, 2013 | Discussions
JasonED Contributing Member • Posts: 941
A couple of things I noted on the Nikon Imaging site about the D5300.
Firstly its very light weight and it seems to be because the camera uses a new monocoque chassis that dispenses with metal in favour of carbon fibre reinforced plastic.   The monocoque is shown here:
Also the 'newly developed' sensor does not look the same as the Toshiba sensor in the D7100/D5200.
The new sensor ....
The D7100 sensor:
The sky is blue and there is nothing we can do..
Nikon D5300 Nikon D7100
JasonED OP Contributing Member • Posts: 941
Re: No banding?
The available sample photos so no sign of the banding that was immediately visible in the D7100 samples.    Early days and limited samples but they look promising.
http://imaging.nikon.com/lineup/dslr/d5300/sample.htm
Re: Interesting features of the D5300
I guess nobody cares about the body construction or a potentially new sensor...   Surprising given the debates that frequently rage on these forums...
bryand7k
bryand7k Contributing Member • Posts: 700
Well .. the Expeed 4 sounds interesting and what it might mean for newer bodies or updates to existing ones.
 bryand7k's gear list:bryand7k's gear list
Nikon D7200 Nikon D500 Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) Nikon AF-S DX Micro Nikkor 40mm F2.8 Sigma 150-600mm F5-6.3 | C
Dmac60 Forum Member • Posts: 74
This link posted on the main dp article contains some sample jpg test shots http://www.nikonclub.cz/clanek/nikon-predstavil-novy-model-d5300-doplnil-wi-fi-gps#.UmBv459wbqA
 Dmac60's gear list:Dmac60's gear list
Nikon D5100 Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF)
JimPearce
JimPearce Veteran Member • Posts: 8,823
The sensors are clearly not identical...
They show different total and effective megapixels on Nikon's global website.
Jim
 JimPearce's gear list:JimPearce's gear list
Nikon D7100 Nikon D500
wildlifr
wildlifr Senior Member • Posts: 1,355
Re: No banding?
What samples immediately show D7100 banding? Not the ones on the Nikon website. And the D7100 wouldn't show banding on any of the samples you linked to for the D5300. For the most part, banding only shows up when the image was shot poorly and processed poorly.
 wildlifr's gear list:wildlifr's gear list
Nikon D7100 Nikon D750 Nikon D500 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Teleconverter TC-14E II +10 more
Re: No banding?
Well it's interesting that Nikon appears to have changed the sample shots!    At the time there was a pic of the inside of a helicopter that had been processed with d-lighting that showed banding inside the cockpit without any further processing.    Here is a thread from the time at mentions it...
http://www.dpreview.com/forums/post/50958588
google d7100 banding helicopter..
samples
Anyone have any thoughts on the D5300 or the samples at the Czech site above?!
Re: samples
I see they've also enabled lossless NEF.
rockjano Senior Member • Posts: 2,450
Yep there are some dark samples on that site and seems to be no banding at all.
This i important. No I don't think that banding is really a huge problem with this sensor but sometimes it could shows, and if they can improve on this (also D7200???) that is very good.
rockjano
Re: The sensors are clearly not identical...
Any more sample images from the D5300 or news on the sensors high iso performance ... something usually leaks out by now!?
fotolopithecus Senior Member • Posts: 1,699
I wonder who makes the sensor,  I can't really determine how good it is without being able to directly compare it to say the D5200, or D7100.
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 50mm f/1.8G
Well, to answer my own question it appears the new sensor was developed by Nikon themselves, although most likely produced by someone else. Perhaps it's similar to the D3200 sensor.
Shunda77
Shunda77 Senior Member • Posts: 1,861
Re: No banding?
Nope, not true, there are plenty of examples from the D7100 and 5200 that show banding that could be very annoying in shots that are far from strongly 'pushed'.
Shunda77
I hope not!
Looks like the D5100 potentially still has the image quality benchmark in the 5000 series.
I hope not!
Well presumably it isn't the same sensor as the D3200 even if it's designed by Nikon. Let's give em a chance, and see how it tests out, but yeah the D5100, and D7000 are turning out to be hard acts to follow.
BillD7000 Contributing Member • Posts: 778
One would expect later generation sensors to show meaningful improvement in some way... as the D7100 did for me over my D7000. Are these differences meaningful all the time? No. Are they the same for everyone? No.
Looking at the Czech site images from the D5300 at full posted size, it's very difficult to see where these improvements have been made. I'm not picking up the EXIF data on this images, and that would be interesting.
But hats off to Nikon for consistently putting great sensors, loaded with DR, in their cameras.
 BillD7000's gear list:BillD7000's gear list
Nikon D7100 Nikon AF-S Nikkor 300mm f/4D ED-IF Sigma 8-16mm F4.5-5.6 DC HSM Sigma 105mm F2.8 EX DG OS HSM Nikon AF-S Nikkor 85mm f/1.8G +1 more
Dmac60 wrote:
Sample lab shots from a production version
http://www.ephotozine.com/article/nikon-d5300-dslr-sample-photos-23327
The JPEGs look like a noticeable improvement at high iso over the D5200, although I guess hard to say is that down to better JPEG processing due to the EXPEED 4 or a real improvement in the sensor? It will be interesting when they get the RAW files up.
