Best value for street photography
Started Oct 15, 2013 | Discussions
Pablom
Pablom Regular Member • Posts: 123
Hello everyone,
I'm looking for a light and compact setup for street photography and for obvious reasons I'm thinking M43 should suit my purpose. I currently shoot Pentax DSLR and it can be a little too much on the shoulder at times, although everything else is fantastic.
My setup has to include a body (obviously...), wide/normal prime lens (preferably fast), viewfinder.
I tried looking at the different models by Oly and Panasonic but I lost myself quickly.
Ideally I'd get something like an OM-d or the new gx7 but they cost more than I'd like to spend. I think around 600$ is my approximate budget but I'd like to know if I can get away with less than that or if I'm too optimistic.
Pablo M.
 Pablom's gear list:Pablom's gear list
Pentax K-5 Olympus PEN E-PL2 Olympus PEN E-PL5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +6 more
Panasonic Lumix DMC-GX7
FrankS009
FrankS009 Veteran Member • Posts: 3,879
Re: Best value for street photography - new Panasonic GM1?
There is a small camera with tiny 12-32 kit lens and the same sensor as the GX7 being introduced on Thursday that might suit you. The price is "$600 to $700." There are 14mm and 20mm prime lenses that are also good for the street.
F.
Henry Richardson Forum Pro • Posts: 15,347
You might look at the Panasonic G5 or G3. Both can usually be found new for very good prices. You can get one with the 14-42mm f3.5-5.6 with IS kit lens (effective 28-84mm) for just a few dollars more. Try them out. Then for very small you might want the 14mm f2.5 pancake lens.
I have used the G3 + 14-42mm for street life photos in Tokyo. I also have an E-M5 that I use for street life photos. Before I used various DSLRs. The E-M5 is slow to wake up from sleep mode so that is a big annoyance with it for the street. My G3 wakes up a bit faster and just enough faster that it is less of a problem.
Henry Richardson
http://www.bakubo.com
tjuster1 Senior Member • Posts: 1,680
How do you like to shoot--from the eye or from the hip? Do you want to be stealthy? Do you zone focus with deep DOF or do you like to isolate subjects? Do you tend to use WA, normal, or telephoto lenses? Do you like to MF or AF?
The answers to those questions will help a lot in offering advice.
For zone focusing from the hip, a camera with a flip-up LCD like the E-PL5 or many of the NEX cameras is perfect. If you require an EVF then you have many fewer options in that price range; perhaps a PM2 + VF3 (recently offered at <$100) would work. But a lot depends on how you like to shoot.
Michael Kaufman
Michael Kaufman Senior Member • Posts: 2,683
At $600, I would probably suggest a Panasonic GF5 and the 20 1.7 lens. That comes out to about $675 at B&H but it includes the kit lens which you could sell on eBay.
If you decide you can spend a bit more, I would say the next steps up are
Olympus EPM2+20 1.7 for $750
Olympus EPL5+20 1.7 for $850
Olympus E-M5 (or Panasonic GX7) +20mm 1.7 for $1300
all the way up to what I think is going to be (for now) the perfect street photography system:
Olympus E-M1+17mm 1.8 for $1800.
I prefer a VF for photography in general and for street Photography in particular, buy you are going to have a tough time finding a new camera with a VF in your price range.
Essentially,  I would recommend you get the 20mm 1.7 or the 17mm 1.8 and the best body you can afford. All of the current m43 bodies are pretty good, so you should be ok with any of them. I prefer the 17mm, but the original 20mm is about $150 less.
 Michael Kaufman's gear list:Michael Kaufman's gear list
Fujifilm X100T Sony Cyber-shot DSC-RX100 IV Olympus E-M1 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +4 more
Pablom
Pablom OP Regular Member • Posts: 123
That does sound interesting. Although I presume I'd have to buy a viewfinder for it, if there will be an option.
I'm not restricted the the newest and greatest, used is an option too.
I can't tell the difference between the Pana G, GH, GX etc. It's very confusing.
Pablo M.
jack Hoggard
jack Hoggard Contributing Member • Posts: 825
Fuji X100.
jaxupra
 jack Hoggard's gear list:jack Hoggard's gear list
Olympus Stylus 1 Sony Xperia Z Ultra Google Nexus 7 +1 more
Fredrik Glckner Veteran Member • Posts: 3,348
If you want the fastest lens, then the Leica co-branded Lumix DG 25mm f/1.4 may be interesting for you. This lens is a bit big, though, although if you are coming from DSLRs, you may find it small still.
Otherwise, the Lumix 20mm f/1.7 and Lumix 14mm f/2.5 pancake lenses can be good for street use, as they are small and stealthy. Read about them and their differences here.
Ulric Senior Member • Posts: 3,580
I say wait for the GM1.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
Michael Kaufman
jack Hoggard wrote:
Fuji X100.
A great camera, but even used its $150 over his budget.
JeanPierre Martel Senior Member • Posts: 2,842
There are two types of m4/3 cameras.
Those with a back LCD but without viewfinder : Panasonic GF, Panasonic GX, Olympus Pen
Those with both a back LCD and a viewfinder : Panasonic G, Panasonic GH and Olympus OM-D.
The difference between G and GH: the latter, High-End model.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
Loga Senior Member • Posts: 1,171
Rumours say it will have a built-in EVF, and its name is Panasonic GM-1. Check it out on the web!
Pablo M.
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Lumix G 42.5mm F1.7
Michael Kaufman
I haven't seen any rumors that say it will have an EVF. I'm not sure they could fit an EVF into a body that small. I'll be happy to be wrong.
JBurnett Contributing Member • Posts: 816
Pablo M.
Wide to normal lens -- Olympus 17mm f/1.8 or Panasonic 20mm f/1.7. The 17 focuses slightly faster. The lens is going to eat a lot of your budget, although the 20mm (original version) can now be found at reasonable prices used ($300?)
Body with viewfinder -- Bodies with add-on viewfinders tend to be more expensive than bodies with a built-in EVF. The Panasonic G3 is pretty much gone from everyone's shelves new, but keep an eye out. Used, you can sometimes find them dirt cheap in near mint condition with low actuations. At the end of their cycle, shops were selling new G3 bodies for $230. This may happen to the G5, too. So a bit of patience may net you a great deal. The G5 also has a silent shutter mode, and a better grip.
 JBurnett's gear list:JBurnett's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 +9 more
BigGG Contributing Member • Posts: 756
You can buy a GX-1 body for about US$200.00 these days. THen go to eBay for a used Pana 20mm F1.7 for another US$250.00  then about $100 for flash chips, etc. Maybe $100 for the EV2 view finder.
GaryG
 BigGG's gear list:BigGG's gear list
Sony RX100 Sony SLT-A77 Sony SLT-A99 Panasonic Lumix DMC-GX7 Sony a77 II +46 more
jennajenna Senior Member • Posts: 1,299
Pablom wrote:
Hello everyone,
Pablo M.
Panasonic 14mm 2.5 with G3 panasonic. That lens is awesomely sharp and cheap ~ $200 used. Get the body for similar price. You can also get a used ep2 with vf2 for maybe $350.
agentlossing
agentlossing Senior Member • Posts: 1,490
The fact that it took so long in this thread for the GX1 to be mentioned is just nuts! The G-series isn't nearly as subtle of a camera. GX1 plus 14mm or 20mm (or both!) hands down. Great camera with awesome controls/handling and awesome image quality, even the grain when you disable in-camera noise reduction looks classic and perfect for street. Both of these lenses are tiny - buy based on whether you prefer to shoot wide or normal.
 agentlossing's gear list:agentlossing's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Sigma 60mm F2.8 DN Art Olympus M.Zuiko Digital 25mm F1.8 +2 more
14mm f2.5
You can get the 14mm new on ebay for around $160.  I bought a new one there last year for $161.
Henry Richardson
Pablom
Thank you, that is very helpful
Pablo M.
Pablom
Re: 14mm f2.5
Henry Richardson
Thanks, that looks like a good value. Oly 17mm looks interesting too.
Are any of the EVFs not recommended at all, or anyone much better than the others? I've never used an EVF so it is a bit intimidating.
Pablo M.
