Some infrared shenanigans - R720 and E-M5
Started Oct 15, 2013 | Discussions
Martin.au
Martin.au Forum Pro • Posts: 10,317
Just a few snapshots with the R720 filter.
Not quite sure yet what I want to do with IR images in post.
Pretty happy about how easy they are to capture though.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
ASR45
ASR45 Forum Pro • Posts: 34,979
Re: Some infrared shenanigans - R720 and E-M5
Weird stuff is infrared.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
slimandy Forum Pro • Posts: 16,389
Personally I'd edit them for monochrome, or inverse the colour channels for faux colour. You've got some good detail and no hotspots so you've done well. Can I ask what lens you used please?
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
Martin.au
Martin.au OP Forum Pro • Posts: 10,317
E-M5, 12-50, R72 filter, handheld using a custom white balance (just grabbed WB from some whitish looking concrete).
JeanPierre Martel Senior Member • Posts: 2,844
© 2013 -- Mjankor
If you look at the histogram, about all IR photos have a curve that doesn't extend fully to each side: black is dark grey and white is pale grey.
It's certainly a question of taste but stretching that curve, adding contrast and even accept to lose some very dark greys (as they become black), adds drama.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
Thanks for that. Unfortunately I sold one of those without trying it for IR first. D'oh!
I ususally take WB from bright green grass, but I'd be happy with your results.
Martin.au
© 2013 -- Mjankor
Cheers. That looks pretty cool.
Taurus43 Regular Member • Posts: 398
Re: No hotspot?
I agree that the overall detail is pretty good, but I think there is a hotspot. Take a look at this false-color version - it has the typical red shift and lower contrast in the center.
And after a quick attempt to remove it.
I shoot a lot of IR using a Panasonic 7-14mm which definitely has a hotspot, but I normally manage to eliminate it in PP so it's not the end of the world. Well worth persevering!
LOL ! Yet, you did it (I've just improved it a little bit).
Scott Whittemore
Scott Whittemore Veteran Member • Posts: 3,702
I agree. The cyan cast in the foliage doesn't appeal to me. Otherwise, they're quite nice, especially the third one.
Scott Whittemore
Nice tweak.
