XF 23f1.4 first findings and test shots
Started Oct 9, 2013 | Discussions
grasmuc
Forum MemberPosts: 79
Oct 9, 2013
I found a Fuji XF 23f1.4 at a local Guangzhou foto dealer. Of course bought it:--)
The lens i bigger than (I) expected, looks very cool on the X-E1. Actually the size should not be a surprise, a 135 format 35f1.4 lens also is always much bigger than a 50f1.4.
The 23 has the same manual focus lens barrel shift mechanism like the 14. IMO both the lens barrel and the MCS switch allow quick convenient toggeling between M and AF w/ keeping the eye at the viewfinder, so no preference from my side.
I just took very few street life pics and one series of sharpness/contrast test pics from my balcony that I want to share.The two pics enclosed are at f2.
AF speed similar to the 35, but need more time for examination.
The lens hood is huge. Hmm, maybe I won't use it for street photography.
Findings from test pics (raw. acr conversion. automatic ca removal. no vignetting correction. no distortion correction. sharpness usm 80/0.5):
- sharpness good at f1.4 in center and at corner. corner sharpness at open aperture is really impressive (I should do the same test with the 14 and 35 for comparison ...)
- sharpness improves significantly at f2, at f2.8-f4, the pics are essentially perfectly sharp across the whole frame
- contrast rather low at f1.4, improves at f2, very good form f2.8
- barely any vignetting at f1.4
- barely any geometrical distortion (please excuse my incapability to level the camera horizontally on the small ball head tripod)
Can't wait for the XF 56f1.2 to complete my favorite prime lens set up (21/35/50/85 in 135).
Enjoy, Chris
X-E1 + XF 23f1.4
X-E1 + XF 23f1.4
X-E1 + XF 14, 21, 35
X-E1 + XF 23f1.4 @f2
X-E1 + XF 23f1.4 + lens hood
XF 23f1.4 test
test scene
ryan2007
Forum ProPosts: 12,001Gear list
Re: XF 23f1.4 first findings and test shots
In reply to grasmuc, Oct 9, 2013
From this it seems to me this 23mm 1.4 does very well at F 2.8 - f 4.0 which is typical with many lenses so far as being stopped down a couple stops to get to optimum sharpness.
IMO and of course I am making a judgement call, but the 23mm 1.4 is a waste of $900 IF you have the 18-55 f 2.8 - f 4.0.
With that 18-55 lens you should be pretty close to the same f 2.8 at the same 23 mm focal length if not it is a minor adjustment to shutter speed, ISO or exposure compensation.
The difference with the impending 56 mm 1.2 I think would make more of a difference compared to the zoom counterpart at the 55 mm f 4.0 or even the 60 mm 2.4 focal length.
I am sure this 23 mm is a great lens and unless you are a all prime lens shooter I think the more bang for the buck is the 18-55 zoom lens and is over lap to own both. I would pull the 18-55 first vs the 23 mm prime.
If the 18-55 was a f 4.0 - f 5.6 that would be completely different and the 23 mm prime makes more sense with the greater difference in light gathering ability.
It will be a rare occasion you need f 1.4, but it seems like (right now) it is over lap to the Fuji 18-55 zoom.
vkphoto
Senior MemberPosts: 1,632
Thanks for sharing. Looks like the lens is in the same league as 14 and 35.
nikoj
Contributing MemberPosts: 783Gear list
In reply to vkphoto, Oct 9, 2013
Hopefully more in the league with 14 than 35. I find the 14 to be exceptional while the 35 very good.
 nikoj's gear list:nikoj's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 14mm F2.8 R Fujifilm XF 35mm F1.4 R +2 more
Absolutic
Veteran MemberPosts: 4,963Gear list
Thanks for your thoughts.  I find surprising that the contrast is low wide open on 23 as the smaller and cheaper 35/1.4 is actually very contrasty wide open in my opinion.   The photos you posted look flat and unremarkable but I assume you just wanted to post a few quick snap shots from the first day.
I'll personally pass on this lens but I am very interested in 56/1.2 and can't wait for Fuji to release it.
 Absolutic's gear list:Absolutic's gear list
Sony Cyber-shot DSC-RX100 III Sony RX1 Sony Alpha 7R II Nikon D800 Sony a6000 +15 more
Davidgilmour
Senior MemberPosts: 1,340Gear list
In reply to nikoj, Oct 9, 2013
I think the 35 is an exceptional lens, amazingly sharp and great bokeh. And not expensive unlike...
 Davidgilmour's gear list:Davidgilmour's gear list
Fujifilm FinePix X100 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Sony RX1 Fujifilm X-A1 +1 more
57LowRider
Senior MemberPosts: 3,514Gear list
In reply to Davidgilmour, Oct 9, 2013
My 7D-owning colleague was moaning earlier this week "That 35 is a thousand-quid lens at less than half price!". Purely for that lens, he continues to search for an X-Pro1 on the cheap, good luck with that son.
Someone wrote a little while ago that they thought the 14, 23 and upcoming 56 are the "diamond-standard" X lenses from Fuji. Looks like it could be the case.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 27mm F2.8 +10 more
unknown member
(unknown member)
In reply to Absolutic, Oct 9, 2013
I agree that these samples do look a little flat but I would guess this is down to the light, the majority of samples I've seen from this lens @ f1.4 looking very good, the X-Trans sensor can often make images seem flat in flat lighting much like any camera.
It does look like a chunky lens though so at lest your getting your money's worth
Tandua
Regular MemberPosts: 107Gear list
In reply to LWS2013, Oct 9, 2013
A must have lens.
I switched from x100s to x-pro1 for this awesome lens
5D Mark II
EF 70-200 F4 IS L
TS-E 24 3.5 II L
X-Pro1 35 1.4
 Tandua's gear list:Tandua's gear list
Sony Alpha 7R II Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 70-200 F4 Sony FE 28mm F2 Sony FE 55mm F1.8
grasmuc
grasmuc OP
In reply to Tandua, Oct 9, 2013
I know guys, the pics are soso ... one indoors with fluorescent light and one against the sun with lifted shadows ... not the best choice to show 3d pop
But I definitely would't blame the lens!
C.
Joachim Gerstl
Veteran MemberPosts: 6,238Gear list
Thanks for posting the picture of the lens on the camera with the 14mm lens beside it. Looks like they are the same size.
I love the first shot.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Panasonic Lumix DMC-GM1 Canon EOS 6D Fujifilm X-T1 +17 more
MrFlash
Contributing MemberPosts: 688Gear list
In reply to ryan2007, Oct 9, 2013
Please stop tying to compare a zoom lens to a fast prime. They are completely different animals. I own the 18-55. It's a good lens for a zoom and I do use it occasionally, but when my 23 gets here I will consider the 18-55 to be completely redundant in my system and it will hit the 'bay.
MrFlash
 MrFlash's gear list:MrFlash's gear list
Fujifilm X100S Sony Cyber-shot DSC-RX100 III Canon EOS 6D Fujifilm X-E2 Canon EF 24-70mm f/4L IS USM +6 more
Alohaman
Contributing MemberPosts: 573Gear list
Thanks for the info.  Fuji is on the right track!
 Alohaman's gear list:Alohaman's gear list
Panasonic Lumix DMC-GX7 Sony Alpha 7R II Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 17mm 1:1.8 +2 more
Red5TX
Senior MemberPosts: 1,586
In reply to Alohaman, Oct 9, 2013
How are you getting on with the LensMate XP1 thumb rest on the X-E1?  I notice it has a set screw, whereas my X-E1 LensMate rest does not.
