updated lens roadmap...
Started Oct 8, 2013 | Discussions
JustDavid
Regular MemberPosts: 496Gear list
Oct 8, 2013
added 55-300 WR, but can't see any other changes...
http://www.ricoh-imaging.co.jp/japan/products/lens/images/K_Mount_Lens.pdf
 JustDavid's gear list:JustDavid's gear list
Pentax K-5 II Pentax smc DA 16-45mm F4 ED AL Pentax smc DA* 50-135mm F2.8 ED (IF) SDM HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR Pentax Q +6 more
Tan68
Veteran MemberPosts: 5,294Gear list
Re: updated lens roadmap...
In reply to JustDavid, Oct 8, 2013
Getting to be a colorful thing.  I like it.
thanks
 Tan68's gear list:Tan68's gear list
Phase One Capture One Pro +1 more
MightyMike
Forum ProPosts: 33,167
Based on a little inside information it looks like 2014 will be a banner year for Pentax... err... Ricoh
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
TomWret
Senior MemberPosts: 1,874Gear list
In reply to JustDavid, Oct 9, 2013
I see 6 HD lens' includes a HD 560mm f5.6 AW. Also Ricoh is printed in the upper left hand corner:-D
Tom W(ret)
...a bad picture is like a missed putt, it's never your fault.
 TomWret's gear list:TomWret's gear list
Pentax K-5 IIs Tamron SP AF 90mm F/2.8 Di Macro Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Epson Stylus Photo R3000 +3 more
Gary Martin
Veteran MemberPosts: 3,390Gear list
Now, if only they would put that DA*30 back on there ...
 Gary Martin's gear list:Gary Martin's gear list
Pentax K-30 Pentax K-01 Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 21mm F3.2 AL Limited +9 more
Zvonimir Tosic
Senior MemberPosts: 2,545Gear list
I like the deep purple of FA Ltds
I think that purple ring on updated FA Ltds would be quite cute.
That update would make "some smoke on Pentax waters", and raised fire in the sky
Zvonimir Tosic
“A portrait is not made in the camera, but on either side of it.”
— Edward Steichen
 Zvonimir Tosic's gear list:Zvonimir Tosic's gear list
Fujifilm FinePix X100
SHood
Veteran MemberPosts: 4,529Gear list
I wonder what Pentax has planned for the Tele-zoom.  From the map it looks like it could cover most of 100-400mm.  I presume this would be f4-5.6 and compete against similar offerings from Canon, Nikon and Sony.
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
Rod McD
Veteran MemberPosts: 3,532Gear list
Re: On the Ltd zoom and the long zoom....
Hi,
The Ltd zoom has disappeared. (Perhaps it did that earlier than this road map? I'm not sure.) In any case, I couldn't see them making something to compete with the likes of the Sigma Art 18-35/1.8.
The long zoom looks like a 135 - 370-ish design on the road map. I would prefer to see them make a high grade zoom out to the full 400/5.6.  I'd like it to be a DA*250 - 400/4-5.6 to start from the end of the DA*60-250, (rather than the 135mm start) and priced accordingly. The shorter the zoom range the better they typically are, and I'd argue for WR construction because teles are usually used outdoors (whether it's for sport or wildlife).  Now that the HD 55-300 is out in WR construction, it would look rather pointless and sub standard to have the longer lens out in non-WR construction.
My $0.02c worth.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Canon PowerShot G1 X Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +6 more
Barry Pearson
Veteran MemberPosts: 6,318Gear list
In reply to Rod McD, Oct 9, 2013
Rod McD wrote:
Hi,
The "DA Zoom Limited" is still on the latest roadmap, with the same (vague) focal length range.
In fact, the entire "2013 or later" section is the same as it was on the January 2012 roadmap, except that what was previously a "DA* Zoom" is now a "DA Zoom". (That changed in the August 2013 roadmap).
 Barry Pearson's gear list:Barry Pearson's gear list
Panasonic Lumix DMC-LX100 Pentax K-7 Pentax K-3 Pentax K-3 II Pentax smc DA 12-24mm F4.0 ED AL (IF) +15 more
Rod McD
In reply to Barry Pearson, Oct 9, 2013
Hi Barry,
Thanks.  You're dead right - don't know how I missed that.  That having been said, I still can't see why they'd produce another 18-35-ish zoom lens and compete with the Sigma Art 18-35/1.8.  The Limiteds have all been primes so far, and small and high grade is the general sense in which they're seen by Pentax owners.  I'm not sure that a Limited zoom makes a lot of sense.  And would it be APSC or FF when they're considering the development of an FF camera?
It would seem better to me (a mere enthusiast not running a camera manufacturing company) that it would be better to turn priorities toward lenses we really need :  the TC, the WA zoom, a good DA* (not DA) zoom out to 400mm, and a suite of FF lenses if they are indeed heading in that direction.
Cheers, Rod
Barry Pearson
Rod McD wrote:
Hi Barry,
That has been puzzling me for a long time. Unless there is something very special about that "DA Zoom Limited", it doesn't appear to have a clear purpose. Sigma came out with something very special, and credit to them.
I'll buy that! (Both the principle, and also some of the items, especially the TC).
miles green
Veteran MemberPosts: 4,711Gear list
HD, WR....
Looks like many lens are getting HD treatment, and some are getting WR.
I wonder if compared to SMC, HD coating is both better and cheaper to produce!?
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +9 more
kitsios_spyros
Senior MemberPosts: 1,834Gear list
Re: HD, WR....
In reply to miles green, Oct 9, 2013
Miles Green
Corfu, Greece
HD sounds consumer friendly nomenclature so it may not be the best of their coatings. But here is a test that shows how a coating can influence a lens
http://www.lenstip.com/239.1-Lens_review-Samyang_14_mm_f_2.8_ED_AS_IF_UMC.html
it there wasn't Sigma 8-16, I might have fallen for this lens on Pentax mount..
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Samsung NX300 Pentax K-5 II Pentax smc DA 35mm F2.4 AL Pentax smc DA 40mm F2.8 XS Lens +8 more
Plakanina
Contributing MemberPosts: 760Gear list
In reply to Gary Martin, Oct 9, 2013
Yes. That is THE lens that should be above all others. A standard lens is missing!!! similar to the FA43mm (in 35mm terms)
 Plakanina's gear list:Plakanina's gear list
Ricoh GR Pentax K-5 II HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR
miles green
Re: HD, WR....
In reply to kitsios_spyros, Oct 9, 2013
Miles Green
Corfu, Greece
Yes they do have a better one, they use on a few DA* and 645 lens. I forget the name. I wish the 560 HD were a little more consumer friendly!
Yes the Sigma 8-16 is a nice lens!
Kind Regards,
Spyros
Regards!
Miles
Miles Green
Corfu, Greece
miles green
Tele zoom?
Any news on the tele-zoom?
The Canon 100-400 is a nice lens despite its age. To place the K3 amongst the wildlife contenders (as Thom suggests) Pentax ABSOLUTELY needs a weather sealed DA* 100-400-ish lens (or that TC, but we said that already).
The 560 sure is nice but due to budget is simply isn't an option for most of us.
Miles Green
Corfu, Greece
Peter Budd
Contributing MemberPosts: 968Gear list
In reply to SHood, Oct 9, 2013
I think you are right on this , but personally I would prefer a constant F4 and WR.
Peter
GMT
 Peter Budd's gear list:Peter Budd's gear list
Nikon D810 Pentax K-3 Olympus E-PL7 Nikon AF Nikkor 50mm f/1.8D Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +19 more
Peter Budd
Re: HD, WR....
According to the guys as SRS I spoke to a few hours ago the HD coating is more expensive to do  and also increases light through in low light situations.
Peter
GMT
MightyMike
In reply to Peter Budd, Oct 9, 2013
Peter
GMT
Are you ready to pay $10,000 for it? Really? Constant F4? yes I'd like that too but let some reality sink in before you drool!
Mike from Canada
miles green
Re: HD, WR....
Peter
GMT
OK, I take their word for it! Thanks for the info.
Miles Green
Corfu, Greece
