XA1 ISO2500
Started Oct 5, 2013 | Discussions
Absolutic
Absolutic Veteran Member • Posts: 5,022
XA1 ISO2500
Just got the camera this morning.   Busy with work so no time to shoot yet.   This is RAW of my child at ISO2500
 Absolutic's gear list:Absolutic's gear list
Panasonic Lumix DMC-ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Sony Alpha 7R II Panasonic Lumix G Vario 7-14mm F4 ASPH +11 more
forpetessake
forpetessake Senior Member • Posts: 4,892
Re: XA1 ISO2500
The child looks good, the picture looks misfocused. Were you using manual lens?
Absolutic
Absolutic OP Veteran Member • Posts: 5,022
Re: XA1 ISO2500
yep, he never stops not for a second and I was trying to focus with Konica 50/1.7 manual lens.   I mainly posted this for noise considerations on RAW files, as most reviews on XA1 out there talks about jpeg engine.
Davidgilmour Senior Member • Posts: 1,400
Re: XA1 ISO2500
Could you make a picture that is in focus?
 Davidgilmour's gear list:Davidgilmour's gear list
Fujifilm FinePix X100 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Sony RX1 Fujifilm X-A1 +1 more
Absolutic
Re: XA1 ISO2500
I shall
Absolutic
Re: XA1 ISO3200
in focus
nikoj Contributing Member • Posts: 783
Re: XA1 ISO3200
That looks really, really good. How is the AF compared to x100, for instance?
 nikoj's gear list:nikoj's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
Absolutic
Re: XA1 ISO3200
I only have 16-50 lens so far (35 1.4 is coming in the mail). I can't wait to use the 35 1.4 on XA1 because 35 1.4 is a magical lens and everything comes together with it.
The AF with 16-50 is clearly faster than X100. It also feels faster than my fomer XE1 with 18-55, however I don't have the XE1 now so I am going by memory.
One thing with XA1 is that it is so small that it might be difficult to hold at first. However, I happened to own a thumb grip http://www.amazon.com/Fotodiox-Mirrorless-Digital-Cameras-Type-A/dp/B00D62VZBW/ref=sr_1_2?ie=UTF8&qid=1381036072&sr=8-2&keywords=thumb+grip
that I tried to use with XE1 before, but it always fell out from the hot shoe because it was too loose. With XA1's hot shoe it goes it perfectly and stays in. With thumb grip, it is very comfortable to handhold.
Absolutic
Jpegs
a few jpeg snaps..... with 16-50. Can't wait for 35/1.4!
Keit ll Senior Member • Posts: 3,703
Re: Jpegs
Given the relatively slow shutter speeds the output from that lens looks good !
(unknown member) Contributing Member • Posts: 578
Re: Jpegs
These look pretty good, the 16-50 looks better than the copy of the 18-55 I had
