Terada: Olympus could go Full Frame !
Started Oct 2, 2013 | Discussions
tt321 Senior Member • Posts: 7,265
Re: It will be fun to watch m43 fans react to Olympus E mount cameras
calxn wrote:
I remember the exasperation that 43 owners had when Olympus was ending it in favor of m43. It'll be fun to watch m43 fans react to E-mount Olympus.
There are no m43 fans.
There are Olympus fans. This concept is different from m43 fans. People go for m43 for the sake of utility, and stick to Olympus because of the company's Apple-like allure. Panasonic is known to produce consumer appliances and their cameras and lenses have been called this name exactly. So Panasonic users are just users, like people use consumer appliances. Not fans. Can anyone be a fan of a consumer appliance?
So in all likelihood, Olympus fans will welcome whatever Olympus FF systems that will come with great enthusiasm, and will start hating Nikon, Canon, and maybe even Sony, instead of hating Panasonic. And m43 users will either continue using m43 if the new FF mirrorless does not give them what they want, or equally likely move to FF mirrorless because that format means that FF is no longer a synonym for dinosaur, battleship, IBM PC XT, and SLR.
stevo23 Forum Pro • Posts: 10,371
Re: Terada: Olympus could go Full Frame !
Bluephotons wrote:
http://www.43rumors.com/more-terada-interviews-no-silver-e-m1-coming-we-do-not-exclude-a-full-frame-future/
Is Sony offering their FF sensor? Will Olympus take it and come up with a mirrorles FF?
Bluephotons
Ah, but I was so much older then, I'm younger than that now. Bob Dylan
You're taking an exclusive negative and turning it into a positive hope. I think that's kind of spinning his statement a little too much in the wrong direction.
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF Nikkor 20mm f/2.8D +1 more
News Flash! Olympus is going 4x5 Digital!
It could happen...
Sergey_Green
Sergey_Green Veteran Member • Posts: 8,906
If they have to ..
boggis the cat wrote:
I assume that they would be willing to sell it.
But Olympus have no 135 format system to use such a sensor in.
They will build it. Just like they built mFT.
No, I don't think so.
Sony may end up buying Olympus, and producing Zuiko branded lenses for their 135 bodies (which would almost certainly all be mirrorless in a few years).
Or maybe Olympus will recognize that it is cheaper to buy sensors that everybody else buys, rather than have a smaller format that is built specifically for them (therefore expensive).
My view is that if they want to build a larger format system from scratch they may as well devise something with a competitive advantage over 135 systems.
Build a reliable camera that focuses faster, for example.
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
Bluephotons OP Veteran Member • Posts: 4,478
Bluephotons
No, I'm just speculating, which is what most of the posters here do nost of the times.
Bluephotons
 Bluephotons's gear list:Bluephotons's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8
Re: News Flash! Olympus is going 4x5 Digital!
stevo23 wrote:
It could happen...
See, you are learning very fast!
Bluephotons
dv312
dv312 Veteran Member • Posts: 3,451
Lenses first
If  we see Olympus making lenses for Sony FF bodies then it's quite possible they could make FF bodies as well since the sensors are there for the picking; might as well be the E mount
It all depends on what lenses they 'll make first; if it's a standard zoom then that's a signal they could also compete with Sony in the same arena, not unlike what they do with Pana in the MFT arena
October should be an interesting month as far as Sony is concerned
 dv312's gear list:dv312's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus PEN-F Olympus 12-40mm F2.8 Olympus M.Zuiko Digital 25mm F1.8 +8 more
Re: Lenses first
Exactly!
Bluephotons
Bluephotons wrote:
Bluephotons
Bluephotons
It's all in how you spin it and present it. I have no idea what you intend, only what you wrote. By the truth of what you're referring to, Ferarri could start making women's panties.
Re: News Flash! Olympus to make first full frame dishwasher!
Bluephotons wrote:
stevo23 wrote:
It could happen...
Bluephotons
Ha ha!
dennis tennis Veteran Member • Posts: 3,501
Re: 2X is the perfect balance
of size and IQ....that is until Olympus say that FF is also fine and then all the fanboys will say of course.
This happened with Nikon, if it happens with Olympus, you'll get the same.
FT was the best thing since sliced bread until it is not.
Contrast AF was superior to PDAF until they added it to EM1.
Sergey_Green
In fact this is a very good point!
Very much so.
Usually it is 2, 3 lenses from the start. Olympus are no strangers to reworking old designs, might as well "un-modify" and expand few existing ones.
Yup.
- sergey
Ulric Senior Member • Posts: 3,580
Bluephotons wrote:
Bluephotons
Bluephotons
Or put a Ferrari mark on Chinese women's panties. I wouldn't be surprised if they already do.
 Ulric's gear list:Ulric's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +9 more
tinternaut Veteran Member • Posts: 7,178
Re: Yes, using someone else's mount makes sense.....
The real money is in the lenses, not the personal computer in the body of a camera (which is all a modern camera is, mostly - hope I don't upset anyone by saying that).  A move to be more like Sigma/Tamron and make lenses for one or more other systems, could save Olympus.
 tinternaut's gear list:tinternaut's gear list
Olympus E-30 Olympus E-510 Olympus PEN E-PL1 Panasonic Lumix DMC-L1 Olympus PEN E-P5 +13 more
MatsP
MatsP Senior Member • Posts: 1,526
Bluephotons wrote:
Bluephotons
Bluephotons
This is what might happen. If the FF NEX get Olympus IBIS as rumoured it's already partly Olympus. A version with Oly logo on it (and a hump!) could attract Oly fans and make it sell a little more. With adaptors for OM and FT lenses of course. And Oly versions of Oly constructed lenses for Sony. Just speculating of course. But with Hasselblad branded NEX7, why not Olympus branded NEX FF. Not that ugly I hope.
 MatsP's gear list:MatsP's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus 12-40mm F2.8 Samyang 7.5mm F3.5 UMC Fisheye MFT
Christopher G Regular Member • Posts: 188
ff sensor with 4/3 crop
Make it with a bigger ff sensor but with a 4/3 aspec ratio , and a rotating back like a mini mamiya rz67 and it would be the perfect portrait or commercial camera next to going medium format. That would be my dream camera. I would pay 4 grand for that. I always wanted to go medium format again from my film days, for the aspect ratio, but it never became affordable.
Dennis Forum Pro • Posts: 16,377
Apple could go full frame
Anybody could go full frame.  It's smart to keep options open and not "rule things out".  Doesn't mean it's a twinkle in anybody's eye.
- Dennis
Marty4650
Marty4650 Forum Pro • Posts: 12,091
Sure.... when pigs can fly
I realize a lot of FF fans would love to see Olympus make a FF camera so they can can compare it to their Nikon or Canon FF camera and then announce it just isn't as good.
And I realize that FF is the current fad, and it isn't just Olympus users who want them, but Pentax and Fuji users are clammoring for one too.
And there are also a lot of Olympus OM fans who think that Olympus is so good they can make a better FF camera than anyone else can.
For Olympus to get in the ring with Canon and Nikon (and Sony too) to slug it out on their home turf would be suicidal. Canon and Nikon have had a ten year head start, and are producing outstanding FF cameras (oil spots and AF issues notwithstanding). If you really want a FF camera, then the Canon 6D seems to make a lot of sense.
Olympus needs to do what they do best and avoid direct competition with with the two 800 pound gorillas. They have carved out a nice niche in the MILC market, and seem to be very successful there.
It would actually make more sense to revive the 4/3 line than to go FF. But upon reflection, I think both are really bad ideas.
Competing in every market is something that very few companies can do well. Witness how Canon is faltering in the MILC market with their EOS-M. And how Pentax failed with the K-01.
If Olympus needs a fresh project they can get to work creating more M4/3 PRO lenses. A 300mm f/4 might be nice. A really nice 100mm Macro would be appreciated. You get the idea.
 Marty4650's gear list:Marty4650's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
MichaelKJ Veteran Member • Posts: 3,432
I would prefer to hear that the Olympus imaging devision was
Bluephotons
making a profit.  That is something I would find much more exciting than the ridiculous notion that they might make a FF camera.
 MichaelKJ's gear list:MichaelKJ's gear list
Sony Cyber-shot DSC-RX100 III Olympus PEN E-PL1 Olympus OM-D E-M5 +1 more
Re: Apple could go full frame
Not Apple. If Apple goes into something of similar size they would make it at least appreciably different from everyone else and call it iMax format or something.
