LR5 and Elements 12?
Started Sep 30, 2013 | Discussions
MikeFromMesa Senior Member • Posts: 2,849
I have LR5 and have usually used it in connection with CS6. Out of curiosity I downloaded the trial of Elements 12 and set LR5 up to call Elements 12 as an external editor. I assumed this would work since both are Adobe products, but when Elements 12 opens it does not open the image sent to it by LR5.
Does anyone use this connections (LR X <--> Elements X)? Is it supposed to work? Or does Adobe make the assumption that no one would use LR and Elements? Or have I missed some step here?
(unknown member) Veteran Member • Posts: 5,593
Re: LR5 and Elements 12?
Maybe Adobe somehow intentionally broke that link in 12? It works fine with me with 11. Just another reason to avoid buying Elements 12.
Ron AKA Veteran Member • Posts: 4,875
Elements is an obvious and common companion application to Lightroom. Can't see Adobe wanting to discourage it. Perhaps a bug? Elements 12 has only been out a week or less...
 Ron AKA's gear list:Ron AKA's gear list
Sony RX100 Epson Stylus Photo R3000 +1 more
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,274
Here is the solution to your problem.
The Secret To Getting Photoshop Elements To Work With Lightroom | Lightroom Killer Tips
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Jim B (MSP) Veteran Member • Posts: 7,726
This should work for you. I have used PSE with LR since V3. I am now at LR 5 and PSE10. They work well together.
Jim
"Its all about the light"
MikeFromMesa OP Senior Member • Posts: 2,849
Yes. That did it. Thanks for the tip.
