Ghost arc with 300mm f/4D ED-IF
Started Sep 29, 2013 | Discussions
newfounder Contributing Member • Posts: 517
Since last November I saw every shots with this lens has a ghost arc at the bottom, a little to the left from the middle. If the back ground is white the arc is very visible. Here is 1:1 crop from a 4288x2848 shot. I opened the front and end cap and can't see anything there. I still think it's probably a dust over somewhere. Since this lens has instruction no not to blowing with dust blower I can't do anything. I bought from gray market nearly 3 years ago and nobody except me is responsible. So what's it and how can I get rid of it.
jhinkey
jhinkey Senior Member • Posts: 2,772
Re: Ghost arc with 300mm f/4D ED-IF
Looks like dust on your sensor.  Telephotos tend to accentuate visibility of dust.  Take a look at your sensor.
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-LX7 Nikon D800 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GH3 +21 more
newfounder OP Contributing Member • Posts: 517
It can't be on camera. I used 55-200mm VR and 135mm f2 and a few other short lenses though all of them are considerably shorter than 300mm. And the ghost arc only appears when I use the 300mm Lens and photos with other lenses are very clean at that position. My camera is D300 and I had cleaned the sensor often.
(unknown member) Veteran Member • Posts: 3,441
Clean the Sensor again, i have seen this too with big Dust on a Sensor...
What I did was "Clean image sensor" on the setup menu. I did it intentionally and I also set it to clean at startup and shutdown. So it's done pretty often. Beyond this is there more means to clean that? If so how can I do that myself? Thanks.
NikonHaoleboy
NikonHaoleboy Contributing Member • Posts: 751
Since you don't see this with two other lenses, there may be something in the lens, in the back group of elements. Something in the front elements of the 300mm ED-IF should be far enough out of focus that it won't be a problem. Either way, the problems are usually noticed at smaller apertures such as f/11-16 and when shooting against a bright background, where it is in effect a shadow. If this is something on your sensor, camera auto-sensor clean is probably better than nothing, but not that much better. Aloha.
 NikonHaoleboy's gear list:NikonHaoleboy's gear list
Nikon D700 Nikon D300S Canon EOS 6D Canon EF 135mm f/2.0L USM Canon EF 100mm f/2.8 Macro USM +18 more
LoL...
I don't mean this internal Camera Cleaning function.
It is the same if You would shaking a full vacuum cleaner Bag.
Yes.
Sensor Cleaning
Regards: Carsten
Al Giordano
Al Giordano Senior Member • Posts: 1,130
Get a good lighted Sensor Loupe
I use it to inspect my sensor but also to inspect and clean my lenses.  It's a great investment.
 Al Giordano's gear list:Al Giordano's gear list
Nikon D810 Sony Alpha 7 II Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +10 more
Re: Get a good lighted Sensor Loupe
The only other cleaning I did was to air blow inside of camera and haven't used any tools to touch the surface of sensor.
NikonHaoleboy
Have the 300 examined
Have a local repair facility give the lens a quick check, they probably won't charge you. Aloha.
bryand7k
bryand7k Contributing Member • Posts: 700
Yes, shoot with your other lens even down to f22 and see if there is anything showing. If not then its the 300 ....  get the lens checked out.
 bryand7k's gear list:bryand7k's gear list
Nikon D7200 Nikon D500 Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) Nikon AF-S DX Micro Nikkor 40mm F2.8 Sigma 150-600mm F5-6.3 | C
