G15 Knurled Front Ring
Started Sep 28, 2013 | Questions
Dan Hudson
Regular MemberPosts: 438Gear list
Sep 28, 2013
Does the knurled ring on the front of the G15 do anything? If so, what?  Thanks
Christian Amateur Photographer
 Dan Hudson's gear list:Dan Hudson's gear list
Pentax K-30 Canon PowerShot SX120 IS Canon PowerShot S100 Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax 16-85mm F3.5-5.6 WR
Canon PowerShot G15
vavam
Regular MemberPosts: 104Gear list
Re: G15 Knurled Front Ring
In reply to Dan Hudson, Sep 28, 2013
It can be assigned to various functions, as described on the page 168 of the user's manual. Which one depends o the shooting mode used. In A mode - aperture change, in S mode - shutter speed, I use it in P mode to set focal distance in steps.
ericN2
Forum ProPosts: 16,325Gear list
In reply to vavam, Sep 28, 2013
I think you may be referring here NOT to the Black Ring but to the FRONT knurled edge rotating dial just forward of the shutter press button as that can be assigned values as you say.
I believe the OP refers to the main Black Ring which encircles the lens at the base.. THAT is simply decorative in the first instance but is there so it can be unscrewed (pressing the press-button about 5 o'clock position to the lens when looked at in frontal view..that Black Ring unscrews and the exposed thread is then used to screw on such as an adaptor Hood that encircles the lens itself and enables you to screw into the front end any sort of Filters you may wish to use.. you cannot do this of course on the LENS itself.
/eric
Staffordshire, UK
Dan Hudson
In reply to ericN2, Sep 28, 2013
Thanks, you have answered my question....Dan
