Entry level headshot lens
Started Sep 28, 2013 | Discussions
thebasharjobs New Member • Posts: 1
Hi there,
I'm an entry level photographer that'd like to explore...entry level headshots. Being entry level unfortunately means I work on something of a budget and have been looking around the internet weighing the various pros and cons of everyone's suggestions.
For awhile I was set on a 50mm 1.8g until progressively more digging uncovered the distortion level to be way too much in certain cases and not an optimal lens for portraits (yet the price point remains haunting).
After that the resounding cry across the internet seems to settle upon anything between a 85-135mm lens that's mostly out of my price range.
I did stumble upon the 70-300mm f4/5.6 thats attractively priced. While it wouldn't offer the crispness of a prime nor does it have the lowest f stop it seems like it might be ok for someone just starting out. Any thoughts?
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 13,102
Re: Entry level headshot lens
thebasharjobs wrote:
Hi there,
The 85mm f/1.8G is probably your best bet unless it's out of your price range. I'm assuming you have a DX Nikon that requires AF-S lenses for autofocus, making it harder to use the somewhat cheaper 85mm f/1.8 D lens. Is this correct? It would have been good if you said what camera you had.
The 70-300 f/4-5.6 is not as good as the popular 70-300 f/4.5-5.6 VR. Also, it is not an AF-S lens. You would probably be using it wide open for portraits, where it would be at its worst.
The absolute best bargain portrait lens is the 105 f/2.5 AI. Now, it's manual focus and your camera probably won't meter with it, but it's relatively inexpensive (used, of course), sensationally sharp and renders beautifully.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +8 more
EKB Regular Member • Posts: 273
Hi there,
Which camera do you have? I'm guessing that it's one of the DX cameras, rather than a D600 or higher-priced model.
If you are worrying about perspective distortion (aka "big nose, small ears") then you need to remember that a DX body has that 1.5 crop factor: Multiply focal lengths by 1.5 to get the full-frame focal length with the equivalent field-of-view and thus the equivalent perspective distortion.
The conventional wisdom is that the 85-135mm range is good for head shots on full frame, which translates to 58-90mm on DX. So that 50mm would translate to 75mm-full-frame-equivalent, which is not completely horrible, but not all that good either.
If your budget is really tight, you need to get creative and deal with the shortcomings of whatever you end up going with. One possibility is to use the 18-105mm or 55-200mm lens that you might already have, and just accept that you can't get the aperture very wide. Another is to get a 50mm, stand further back than you otherwise would (to reduce the perspective distortion), and then crop heavily.
If you have enough budget to cover a ~$500 lens, then two more possibilities are the Nikon 85mm f/1.8g, and the Tamron 60mm f/2 macro. FWIW, Thom Hogan really likes the Tamron as a portrait lens for DX cameras. But there are also a lot of people who swear by the Nikon 85mm, on either DX or FX.
 EKB's gear list:EKB's gear list
Panasonic Lumix DMC-FZ28 Nikon D90 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF Nikkor 50mm f/1.8D +2 more
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,029
50mm for FX, 85mm for DX
Hi there,
Welcome to dpreview!
You can make your headshots virtually with any lens, but I think you can go for a "more classical" approach (translation: my personal preference):
  • For FX (commonly named "full frame") cameras, for full body, torso and head, the usual is 50 mm, 85mm and 105/135mm
  • For DX cameras, the usual for full body, torso and headshots is 35mm, 50mm and 85mm
Once decided for focal length you probably will look for aperture. Bigger aperture will offer you more creative options. Although most of the headshots are made at f/2.8 and smaller, some very interesting effects can be reached with f/2, f/1.8 and even f/1.4 - it is particularly critical when using DX cameras.
Last but not least, the bokeh is particularly important for better portraits, so my suggestion is looking for lenses with better ones.
I shot DX and my preferred lens for that application is Nikkor 85 f/1.4 AFD (and my faithful Nikkor 135 f/2 DC). The newer Nikkor 85 f/1,4 AFS looks marginally better, but sincerely, I think both are overpriced for their performance. If you are looking for the best cost/performance ratio, I think the Nikkor 85 f/1.8 is a better option, mainly if you can get an used sample in good condition.
All the best... and enjoy!
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
Stacey_K
Stacey_K Veteran Member • Posts: 7,774
85mm f1.8G
Buy this lens, you'll be happy!
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
anotherMike Veteran Member • Posts: 8,055
Easy:
85/1.8G if you can afford it, and if that's a bit of a stretch, go manual focus and pick up a good condition used 105/2.5 AIS for a couple hundred. To this day I *seriously* regret selling my 105/2.5; that was one of the dumbest moves I ever made. Either way you go, you are getting something WAY beyond entry level in terms of quality as a lens, for not really that excessive amounts of cash.
-m
Kitacanon Senior Member • Posts: 2,802
Hi there,
I won't recommend lenses outside of your budget...but you're going beyond FL range that you need for an "entry level" portrait lens.
Most portraits, as suggested earlier, are going to be shot between 50mm and 85mm on a DX format body...(equivalent to 75-135mm....)...so why not consider a zoom range between 28 and 85...
It's also been suggested that most portraits are typically shot between F2.8 and F5.6....sooo....look for zooms with 3.5-4 at their widest...again for entry lenses within your budget...I don't know which body you have, but I had the 28-85mm F3.5-4.5 Nikkor (@ less than $100) and found it VERY good...
28-85 Nikkor 28mm @ 5.6 100% crop shot on Canon 30D
and 100% crop @ 85mm @ 5.6...
A step up would be a zoom with F2.8 widest aperture, but they are considerably more...and even if you can't use the AF on this lens (if you body won't AF with it), it will be just fine as a manual focus lens for portraits...
 Kitacanon's gear list:Kitacanon's gear list
Nikon D610 +1 more
PSCL1 Senior Member • Posts: 3,044
To the OP:  85 1.8G  if you can afford it.  If you can't, the discontinued 85 1.8D, available Demo/Used for $350 from time to time at www.adorama.com      Or the legendary 105 2.5 AI or AI-S, MF, with a cheap adaptor if you don't need AF.
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
yray
yray Senior Member • Posts: 1,416
anotherMike wrote:
Easy:
-m
I agree with this general sentiment, look into manual focus Ais lenses, the mentioned 105/2.5 is excellent (and, anotherMike, -- you can often find anotherLens like that used). I would also look into 135/2.8 Ais. Personally, I find 85mm a bit short for headshots, and 105 and 135mm are both better for that purpose IMO. Also, don't be afraid to look into zooms for portrait shots. Both 80-200 and 70-200 f/2.8 zooms make superb portrait lenses, though might be on the pricey side. But, the older Ais zooms, 50-135 f/3.5 and 80-200 f/4 could be acquired on the cheap, and they are very good too, plus you gain the flexibility of a zoom. I would argue that for a headshot you don't need super fast aperture, and f/4 is generally sufficient, or you will often risk having only one eye in focus.
InTheMist
InTheMist Senior Member • Posts: 3,066
Entry level portrait how-to...
Take the 55-200 step back and zoom tight, use some window light for dirt cheap, amazing results.
The trick is using telephoto and nice light.
Ridicule is not C&C nor is it being helpful nor "stating your opinion"
www.flickr.com/InTheMist
 InTheMist's gear list:InTheMist's gear list
Leica M Monochrom (Typ 246) Nikon Df Nikon 1 AW1 Nikon D810 Nikon 1 J5 +18 more
stevo23 Forum Pro • Posts: 10,123
Headshot? I think you can find some really nice scopes at Bass Pro shops.
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF Nikkor 20mm f/2.8D +1 more
hajagosb Regular Member • Posts: 212
Most of the headshots i did are done with an 85 1.8D. It's not the best lens, but works well for this. Quite sharp stopped down. If you can afford get the newer G version. You can find my examples here: http://www.balinthajagos.com/portraits
 hajagosb's gear list:hajagosb's gear list
Nikon D800E Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Sigma 35mm F1.4 DG HSM Art Nikon AF-S Nikkor 85mm f/1.8G +3 more
Kali108 Regular Member • Posts: 267
Hi there,
save your pennies for the 85 f1.8G.  50 f1.8G in the meantime.
Nexu1 Senior Member • Posts: 2,556
You might be able to find an older lens for cheap if you have a camera that can screwdriver focus.  You could buy a lens and manually focus it but I'm not sure I'd recommend that for a beginner, I hate manual focus, I didn't grow up with it :).
The 85mm f1.8G is THE portrait lens of choice on DX and comes in around $500.  You'll soon find out that the lens is so popular that you'll struggle to find it, even used, for much less than $375-400 (sometimes used on ebay go for $440ish).
If you're really budget limited, and there is nothing wrong if you are, another solid option is the Nikon 55-200 VR, you can find this periodically refurbished from a reputable seller like Adorama for around $115-120 (I just looked but right now it is out of stock).
The keys to getting good headshots are having a focal length of 85mm or longer so you can get close and fill the frame without distortion.  Getting close is critical, it will give you the best detail and will help with depth of field (making the background blur out of focus).  Shoot in A mode with the most wide open aperture your lens can handle (smallest F number).  If possible, setup your subject so the background behind them is somewhat far away.  This will allow the background to fade into a soft blur easier with a 55-200 type lens that can't go down to something like f1.8.
bikinchris
bikinchris Forum Pro • Posts: 18,497
Don't forget
You have some good advice here and I didn't read through all of it, but don't forget that you don't need to buy a new lens. A good used lens from a reputable source like KEH will serve you very well and save you money.
You would be surprised what a BGN grade lens from KEH looks and works like. Buy an EX lens and you probably will think it's new.
Get your facts first, then you can distort them as you please.
Mark Twain
 bikinchris's gear list:bikinchris's gear list
Nikon D3 Nikon D4S Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR +1 more
ayt Contributing Member • Posts: 698
if you want an 85mm lens and do not mind it being manual focus, the Samyang 85mm f1.4 (and its clones) is a relatively cheap yet high performing option.
 ayt's gear list:ayt's gear list
Canon PowerShot S95 Sigma DP2 Olympus E-620 Olympus E-1 Olympus E-500 +38 more
CFynn Veteran Member • Posts: 5,224
You don't need an adapter to use an AI/AIS lens on a Nikon body.
 CFynn's gear list:CFynn's gear list
Fujifilm X10 Nikon D800E Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 180mm f/2.8D ED-IF Nikon AF Nikkor 105mm f/2D DC +14 more
vepar Regular Member • Posts: 147
I assume you're on dx body. nikkor 105mm 2.5 ai or ais is entry level lens for price, but top level performance lens for headshots. However on crop body it can be bit too long for general portrait photography.
If your camera body can AF with screw driven lenses - in my experience 35-70 2.8 AF-D is best solution for portraiture combined with crop sensor, even though it was designed for completely different purpose - as normal zoom on film bodies. This lens renders women skin simply amazing.
I never used 85mm 1.8g, but from what I saw, it could be excellent for your intended use.
 vepar's gear list:vepar's gear list
Fujifilm FinePix E900 Zoom Nikon D7000 Nikon D800 Nikon AF-S Nikkor 50mm f/1.8G Carl Zeiss Distagon T* 2/35 +13 more
romfordbluenose Senior Member • Posts: 2,004
For best bangs for a buck on DX buy the 50mm f1.8 , frame your shot, take 2 steps back then crop the image. With todays cameras you can even do the crop in camera, or buy a 85mm f1.8D second hand.
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +8 more
