anyone have more then one merrill
Started Sep 26, 2013 | Discussions
ken
ken
Contributing MemberPosts: 614Gear list
Sep 26, 2013
or have you used more then one model what one gives the best results ? what one do you use the most if you own more then one thanks in advance i will purchase one tonight
Scott Greiff
Senior MemberPosts: 1,617Gear list
Re: anyone have more then one merrill
In reply to ken, Sep 26, 2013
You'll enjoy them.
I have the DP1 and DP3 Merrill cameras.  I have the two for the different focal lengths, but if I had to say which one I use more it's probably the DP3.  I just love the long lens.  It lets me be a bit farther away from my subject.  The DP1 always surprises me, however. It's often wide enough for most everything when you're close to the subject.  I don't know if I've ever wished I'd have a 24mm equivalent or wider.
-Scott
 Scott Greiff's gear list:Scott Greiff's gear list
Sony RX100 II Sigma dp2 Quattro Sigma dp0 Quattro Sigma SD15 Sony a6000
idillic
Regular MemberPosts: 144Gear list
In reply to ken, Sep 27, 2013
Three - SD1, DP2M & DP1M.
Almost without exception, I get the best results from the SD1M.  The colours & contrast are almost always better with it, no matter which lens I use.
 idillic's gear list:idillic's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Pentax 645D Sigma SD1 Merrill Sigma 50mm F2.8 EX DG Macro +8 more
ken
ken OP
In reply to idillic, Sep 27, 2013
what about between the dp1 and dp2 cant afford the sd1
Rand 47
Regular MemberPosts: 378Gear list
DP2 & 3
Rand
 Rand 47's gear list:Rand 47's gear list
Fujifilm XF 56mm F1.2 R
ken
ken OP
In reply to Rand 47, Sep 27, 2013
what one do you use more and why ?
xpatUSA
Senior MemberPosts: 6,362Gear list
Since each DP*M model has a different (fixed) focal length you need to examine which one has the angle of view that  best suits your photography.
Ted http://kronometric.org
SD9, GH1
Panasonic Lumix DMC-LX7 Sigma SD10 Sigma SD14 Sigma SD1 Merrill Sigma 50mm F2.8 EX DG Macro +3 more
Roger
Senior MemberPosts: 2,030Gear list
YA 3
Greetings
Ya, DP2m DP3m SD1m   They're all good depending on your needs.  What do I use most?  My SD15 with a 50 1.4 lens goes with me every where.  The DP uses batteries about 1 for every 36 shots and no flash.  All the M series have large file.
The job picks the camera but the SD15 or one of them fits the bill most of the time.  The SD1 for the studio DP's for out walking around. SD14 just for fun to play with.
Good luck
Roger J.
Chrissearle23
New MemberPosts: 8
Re: YA 3
In reply to Roger, Sep 27, 2013
I have DP2 and 3M. I can't choose between them, they are both incredible, the '3' is just fantastic for flower and insect shots but is also nice for tight angle landscape shots. Interested to here comments about the SD1M being better than the DP's. If that were the case I might seriously consider one with a 300 f2.8 tele.... Droool...
Robert F. Tobler
Senior MemberPosts: 1,140Gear list
Owning all 3 DPxMs...
... my usage is DP1M > DP3M > DP2M.
But as others have said, this is mostly due to personal preference.
I am a wide-angle/landscape/city-scape guy, therefore I use the
DP1M most often. The DP3M gets a gut workout for macros and
flowers. I use the DP2M as necessary in cases where the DP1M or
DP3M do not work.
Here are 2 of my galleries as examples:
Donau-City, a part of Vienna, Austria (first 38 photos)
Flowers and Plants (first 24 photos)
Greetings,
Robert
 Robert F. Tobler's gear list:Robert F. Tobler's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus E-M5 II Olympus Zuiko Digital 1.4x Teleconverter EC-14 +2 more
