Canon G16 Viewfinder
Started Sep 25, 2013 | Questions
cmc1
Regular MemberPosts: 167Gear list
Sep 25, 2013
Does anyone know what the coverage of the G16 viewfinder is?
The canon website and specifications don't seem to mention it.
I hope it's better than the 3% on my G11
 cmc1's gear list:cmc1's gear list
Sony RX100 Fujifilm X100T Nikon D610 Nikon D7200 Nikon D5 +3 more
GeraldW
Veteran MemberPosts: 6,922Gear list
Re: Canon G16 Viewfinder
In reply to cmc1, Sep 25, 2013
Should be the same as my G15 and the G10, 11, & 12.
3% ???  I don't understand.  Does your finder not zoom as you zoom the lens?
Most reviews list those finders at about 80%.  That would translate to the optical finder showing about 80% of the area that ends up on the recorded image. (about 90% of the height and 90% of the width).  I had the G11 when I bought the G15.  To me, the view looked the same.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon PowerShot A720 IS Canon PowerShot S95 Canon PowerShot ELPH 330 HS Canon PowerShot G15 Canon PowerShot SX50 HS +1 more
Dale Buhanan
Veteran MemberPosts: 3,993Gear list
In reply to GeraldW, Sep 25, 2013
Jerry
Hi Jerry,
I believe I remember reading in one of the announcement pieces from Canon for the G15 that the vewfinder coverage had been increased to 85% -- and since the G16 uses the same viewfinder as the G15 it would also be 85%.  Not much different than 80% actually, but I'll take all I can get.
As near as I can tell, the G16 uses the same lens and viewfinder as the G15, but it uses a BSI CMOS sensor instead of just a CMOS sensor for somewhat better signal to noise ratio.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +34 more
cmc1
cmc1 OP
In reply to Dale Buhanan, Sep 26, 2013
Why can't they do 100%? it would make the camera much more desirable.
Still, 85% puts it on par with the Fuji X20 but the Fuji has information overlay.
unknown member
(unknown member)
In reply to cmc1, Sep 26, 2013
It might make it more desirable in theory but if the price also increased significantly no one would buy it.
To achieve 100% coverage you would need a set of viewfinder optics perfectly calibrated to the focal lengths of the taking lens and able to zoom in tandem with no loss of focal length synchronisation at any point in the zoom range at any focus distance. Since modern lenses are rarely symmetrical in their optical design these days there is often a change in focal length as they are focussed closer than infinity, so that would have to be taken into account as well. In addition the viewfinder would have to be able to compensate for parallax at closer distances since the taking lens and the viewfinder are not pointing at the same part of the subject.
So to really achieve 100% coverage probably the only practical way of doing this would be to have a G16 with two matched taking lenses - one to take the photo and one to act as the viewfinder (which essentially was what TLRs used to do). However I suspect you can now see the downsides of that approach not only in terms of cost but also in size.
cmc1
cmc1 OP
In reply to meland, Sep 26, 2013
So to really achieve 100% coverage probably the only practical way of doing this would be to have a G16 with two matched taking lenses - one to take the photo and one to act as the viewfinder (which essentially was what TLRs used to do). However I suspect you can now see the downsides of that approach not only in terms of cost but also in size.W
OK
plantdoc
Senior MemberPosts: 2,276Gear list
Why not a EVF?
In reply to cmc1, Sep 28, 2013
I can understand the difficulties of an excellent optical finder but why not a superior EFV? The new Nikon, same price, shows that a big price increase argument doesn't hold up. Nikon also adds a swivel LCD, which I am mixed about given the larger size.
Greg
ImagesInstyle
Contributing MemberPosts: 691Gear list
In reply to cmc1, Oct 2, 2013
i just got mines today, and the lens does not block the view at all.
so i would say about 95% viewable.
i can only slightly see a small part of the lens barrell, and that very small.
see my earlier post on the G16 in beverly hills.
 ImagesInstyle's gear list:ImagesInstyle's gear list
Sony a6000
edu T
Senior MemberPosts: 1,174Gear list
Canon G16 viewfinder, why not 100% coverage?
In reply to meland, Oct 2, 2013
Yup.
Not to mention that the user would get royally piçed off when, due to parallax, something seen next the borders of the VF is lost on the pic (not an issue with 85%), nor that the lens barrel would become really conspicuous at WA, nor that for non-reflex compact cameras there exists a more elegant eye-level solution (nikon P7800, panny LF1) called, you know...
 edu T's gear list:edu T's gear list
Fujifilm FinePix F550 EXR
Greg Gebhardt
Forum ProPosts: 25,428Gear list
Glad it does not have swivel LCD
In reply to plantdoc, Oct 2, 2013
Not wanted or needed for my use.
My G16 is slim and light.  Great image quality and focusing is on steroids compared to my G15.
Greg
Jax, FL
 Greg Gebhardt's gear list:Greg Gebhardt's gear list
Sony Cyber-shot DSC-RX10 Leica Q Leica M9 Nikon D4
Mike in NM
New MemberPosts: 1
In reply to ImagesInstyle, Oct 5, 2013
Just received my G16.  Wonderful to have an optical viewfinder again.
I do see a bit of the lens barrel in the finder, but it's not enough to be a problem.
However,  also see a shadow of something midway, way over, along the right edge.  Seems to be internal, and it's the same at all zooms.  After close examination it appears to be rectangular, with sharp corners, so it's not dirt, crack or smudge.  Looks like structure.  Has anybody else seen this, or do I have a problem?  Thanks.
Mike
eajames
Regular MemberPosts: 156
In reply to Mike in NM, Oct 6, 2013
I see the lens barrel in the lower left at 28mm to 35ish; at longer settings it is not visible.  I see nothing like what your are describing on the right side.  It sounds as though something is off with yours.
RedFox88
Forum ProPosts: 24,514Gear list
In reply to cmc1, Oct 6, 2013
Well it's not a TTL viewfinder, so it's through the camera body above the lens.  It would cost too much, requiring high manufacturing process to get a 100% OVF on a P&S camera.  Would you pay $799 to get a 100% OVF?
