NEX Anti-reflection coating failure
Started Sep 24, 2013 | Questions
DistantView Forum Member • Posts: 53
The screen protector on my nearly 2 yr old NEX5N started coming off so I completed the process only to find that the anti-reflection (or some lind of coating) has come away ina pretty random fashion. I have a photo but not at work & will try to post later.
I contacted the screen protection supplier who said "not us, it's a common fault with NEX's & Sony will replace it FOC". Contacted Sony UK who said "no, not common send it in & we will repair it at a cost to be advised"
Has anyone else had this problem & if so how were you treated - any thoughts ?
Many thanks
RT
boardsy Senior Member • Posts: 2,215
Re: NEX Anti-reflection coating failure
Many thanks
RT
After the coating started to flake off my old NEX-5 after a couple of years daily use, I stuck a sharp blade  (or maybe the tip of a jeweller's flat-head screwdriver?) under the edge of it carefully, and it peeled off cleanly in one, leaving a pristine, clear (and reflective) glass surface underneath! I wonder if you got underneath the coating properly to remove it?
Alan
my Flickr
Chris 1 Regular Member • Posts: 148
Yep it's a known issue, people have said Sony will repair under warranty, there also are some aftermarket replacements. I will be sending mine in before the warranty expires, then try to find an anti reflective protector on top to protect it
 Chris 1's gear list:Chris 1's gear list
Nikon 1 J1 Sony a6000 Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN Nikon 1 Nikkor 18.5mm f/1.8 +1 more
martindesu
martindesu Senior Member • Posts: 1,245
I also stumbled across this "common fault", and repaired it myself.
I documented the procedure:
http://www.martinirwinphotography.com/reviews/2013/8/19/repairing-the-nex-c3
I hope that helps anyone with this issue (and Sony won't fix it).
 martindesu's gear list:martindesu's gear list
Sony RX1 Sony Alpha NEX-C3 Voigtlander 35mm F1.4 Nokton Sony FE 55mm F1.8 +1 more
Karsten Meyer
Karsten Meyer Contributing Member • Posts: 732
When I had peeled off this with my NEX-5, I had a very ugly screen where parts were reflecting and other parts not.
I got the whole screen as replacement for unter 40 Euro off ebay. It came with a short instruction guide and even with the fitting screwdriver.
--> See my photos on http://gplus.to/KarstenMeyer
DistantView OP Forum Member • Posts: 53
Thanks for the help guys, I've also been pointed to David KP's article (on another site which can't be mentioned :-D)  which also goes down the replacement route.
So even though I'm a bit of a "Charlie Allthumbs" I'll probably try !
Many thanks again
Best wishes
RT
