Variable Neutral Density Filters
Started Sep 23, 2013 | Questions
foody1000 Forum Member • Posts: 73
Has anyone used Variable Neutral Density Filters?  They seem very convenient but online reviews are mixed and there are some concerns about them degrading the IQ of images.  I'm just a hobbyist casual shooter and don't need my photos to be tack sharp.  I'm looking for a cheap one for $50 or below.  Can you please share your experience - good or bad?  Thanks.
Jogger
Jogger Veteran Member • Posts: 8,441
Re: Variable Neutral Density Filters
There is no such thing as a good and cheap VariND filter.
In any case, these filters are really meant for video/film production, where you need precise exposure control using slow shutter speeds (1/48, 1/60, etc) and large apertures in bright light.
If you are just using this for photos, its far better and cheaper to get a set of ND filters.
 Jogger's gear list:Jogger's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
Lightshow
Lightshow Senior Member • Posts: 4,375
+1
I bought a Singh ray Vari-ND Because most of the bad reviews came from the cheap ones.
http://www.singh-ray.com/varind.html
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony Alpha 7R +1 more
Nate Dogg Regular Member • Posts: 253
I actually use a cheap Promaster variable ND filter on my SEL=18200, with what I feel very good results: Here are a few shots I took awhile back, using this combo:
On a side note, it should be noted that variable neutral density filters tend not to work well on wide-angle lenses, regardless of brand. See here:
http://photo.stackexchange.com/questions/34696/why-are-my-results-with-a-variable-neutral-density-filter-poor
-Nate
Lightshow
My Singh Ray doesn't cause X's like that.
Per the Singh-Ray website:
"NOTE 2: The design of the Vari-ND Filter may introduce irregularities when used with very wide angle lenses, especially on full-frame cameras. Adjust your focal length and reduce the filter density setting until the irregularities disappear."
Fulll page found here:
Furthermore, here is an example of someone having the exact same issue with a Singh-Ray filter, as well as a discussion about the subject as a whole:
http://www.flickr.com/groups/neutraldensity/discuss/72157625823550713/
I'm curious, what wide-angle lens have you used it on without issue? I've tried a few variable ND filters (both budget and expensive) on my E-mount 10-18mm f/4, and they've all produced that effect.
Nate
-Nate
Lightshow
Nate
-Nate
I have the 82mm version and used it on my Canon 16-35LII and 1DIII(1.3x)
foody1000 OP Forum Member • Posts: 73
I'm not planning on use the Variable ND filter on wide angle lenses.  It would mainly be for outdoor shooting on the SEL35F18 and SEL24F18Z where I want shallow DOF when shooting people shots.  I don't really consider the 24mm to be wide angle - right?
I should have better clarified my understanding of the issue between variable ND filters and wide-angle lenses. As far as I know, it’s only on “ultra” wide angle lenses. From my experience, I’ve not had any issue at 18mm on my zoom lenses; therefore, I’m pretty sure there would be no issue on a 24mm prime.
Hope this helps,
Nate
