How are lenses on AW1 sealed - any ideas
Started Sep 20, 2013 | Discussions
tundracamper Senior Member • Posts: 1,818
I just recently started dabbling in underwater photography and quickly learned why it costs so much. So much worry about o-rings leaking and expensive housings that allow access to the controls. Obviously, there are housings that have removable lens ports. However, those seem to have big o-rings and locking mechanisms. Does anyone have any images of how the AW-1 lenses will seal to the chassis? I wonder if users will be required to lubricate the seals, etc. Seams like a recipe for getting all sorts of garbage inside the camera - and ultimately on the sensor.
DesertCat Contributing Member • Posts: 655
System Diagram
This image just became available on the web.  I think it may help answer your question.
 DesertCat's gear list:DesertCat's gear list
Nikon 1 V2 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +1 more
Re: System Diagram
In addition, the nikonusa.com site has a "waterproof accessories" tab for this system. It includes silicon grease and replacement o-rings. So, I think your concerns are justified with regards to managing the "gunk".  I think that's kind of the one of the costs of ownership with such a system.  Especially given the current lenses, I think lots of people would just choose one of the two lenses and leave it on most of the time, though I'm sure someone will prove me wrong. The big decision for many may be whether they want the flexibility of zoom with a bit less let gathering capability or if they want a little more light gathering, a fixed focal length, and potentially a bit more seal depth (20m instead of 15m).
AW1 Waterproof Accessories
SunnyFlorida Contributing Member • Posts: 831
Re: How are lenses on AW1 sealed - any ideas
Duct  Tape
tundracamper OP Senior Member • Posts: 1,818
Re: System Diagram
Thanks for the image.  That certainly helps.  Of course, there sure are a lot of o-rings.  Granted, a regular underwater housing has lots of o-rings as well, though some of them are quite small and can be very tight around the buttons.  Here, the rings within the lens would be difficult to maintain, if not impossible.  Just based on some high-level observations of the schematic, of course.
GodSpeaks
GodSpeaks Forum Pro • Posts: 11,586
Re: System Diagram
Even if you just have one lens and 'leave it on all the time', your O rings will still need to be lubricated and replaced periodically, if you hope to maintain watertight integrity.  O rings will dry out and crack if not properly maintained.
I used Nikonos cameras back in the 70's and 80's, and O ring maintainence was a must if you did not want your camera to flood.
Still have two of them, and still fully operational.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-FZ1000 Kodak DCS Pro SLR/n Sony Alpha DSLR-A850 Panasonic Lumix DMC-GX1 +45 more
GodSpeaks
Re: System Diagram
You normally send the lenses in to a service facility for replacement and relubing.
- Rayna Butler
Sonyshine
Sonyshine Senior Member • Posts: 7,832
Re: System Diagram
As a plumber I'm very used to seeing O rings working perfectly for years on high pressure systems. Have confidence the seals will be fine.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
Bailey151 Senior Member • Posts: 1,139
Re: System Diagram
Yep, and it's not like it's all that complicated (lenses aside). If you happen to own a dive watch......same-same. O-rings & silicone.
happypoppeye
happypoppeye Veteran Member • Posts: 3,878
SunnyFlorida wrote:
Duct Tape
Use that sh*t for anything...
Duct Tape is also the cure for the problems in the Middle East.
 happypoppeye's gear list:happypoppeye's gear list
Panasonic Lumix DMC-TS30 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS
GodSpeaks
Re: System Diagram
And I have experience from my Nikonos days.  Periodic replacement and relubing is a must.
As a plumber, you can wait for the seal to start dripping a little before taking any action.  With underwater cameras and lenses, waiting that long results in ruined equipment.
- Rayna Butler
Sonyshine
Re: System Diagram
- Rayna Butler
It depends what the O rings are made of. Many modern O rings must not be lubricated with anything as  they will be damaged by silicon lubes etc. No doubt Nikon will include advice on care in the owners manual!
Sonyshine
An interesting article here that goes into a lot of detail on the seal and even the grease is supplied!
http://www.photoclubalpha.com
Jan Toude
Jan Toude Regular Member • Posts: 195
A clearer photo of the AW1 CX mount
 Jan Toude's gear list:Jan Toude's gear list
Panasonic Lumix DMC-LZ8 Panasonic Lumix DMC-TS1 Canon PowerShot A1300 Canon PowerShot D30 Nikon 1 J1 +11 more
