How to set flash 43 to manual with A77
Started Sep 19, 2013 | Discussions
Condor
Condor Senior Member • Posts: 1,768
Trying to use my flash x-tender (better beamer) device, I need to set my Sony 43 flash unit to manual. I do it in the flash, but as soon as I halfpress the shutter it changes to TTL. And with the unit attached, A77's menu does not offer manual mode as with its built-in flash.
Thanks in advance,
Ed
sybersitizen
sybersitizen Veteran Member • Posts: 5,625
What exposure mode are you using?
Sounds like you have some restrictive Auto setting enabled in the camera. Put the top dial in M mode and try it.
The camera menu's 'Manual' flash setting has no influence over external flashes at all - it only affects the pop-up flash.
Condor
Condor OP Senior Member • Posts: 1,768
Re: What exposure mode are you using?
Thanks,
M dial mode solved the problem of TTL overwriting Manual Flash control.
But I lost all auto settings, specially ISO Auto.
is there a way to keep flash in manual and let the camera to auto set all other parameters?
Ed
sybersitizen
That's right. Most models including the A77 don't support Auto ISO in M mode.
You should be free to use manual flash in all normal PASM modes. Just avoid any 'Auto' labeled mode, which you have apparently been using. I recommend gradually weaning yourself away from them. They're very limiting.
Condor
Found flash Fn that allowds Manual in all PASM camerad modes
Looking for a better solution to my problem, Ifound that flash's  "Fn" 04 option allows you to set the flash unit to Manual even in P, A or S camera's mode (M included), default Fn 04 setting just allows it in M mode.
For what it could be worth it (like using the BETTER BEAMER "flash x-tender").
Ed
headfirst
headfirst Contributing Member • Posts: 670
Re: Found flash Fn that allowds Manual in all PASM camerad modes
ah, yes - when all else fails read the manual
 headfirst's gear list:headfirst's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A200 Sony Alpha DSLR-A700 Sony Alpha DSLR-A580 Sony SLT-A77 +8 more
ChunWookie
ChunWookie Junior Member • Posts: 44
Re: How to set flash 43 to manual with A77
What manual!!
