Pentax K3 rumor from the plant... shhh...
Started Sep 18, 2013 | Discussions
Gary Martin
Veteran MemberPosts: 3,390Gear list
Re: sooner or later
In reply to janneman02, Sep 19, 2013
janneman02 wrote:
One of the rumored K-3 announcements will actually happen.
Dont knwo about secs though, just that it will, as usual, be called too little too late and the end of Pentax.
Unless it's a *substantial* upgrade, I would rather it come later. Pentax/Ricoh needs to make a strong case for APS-C in the next generation, with the latest Micro4/3 sensors getting closer to the last generation of APS-C imagers. The successor to the K-5 needs to have as big of a jump in image quality that the K-5 did over the K-20/K-7. The Nikon D7100 wasn't a big enough jump, IMO; I hope Pentax can top them. And if they do, they will sell lots of cameras. If they don't, then it will be just another incremental upgrade and they will only maintain but not grow market share.
 Gary Martin's gear list:Gary Martin's gear list
Pentax K-30 Pentax K-01 Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 21mm F3.2 AL Limited +9 more
paulkienitz
Veteran MemberPosts: 5,176Gear list
Re: sooner or later
In reply to Gary Martin, Sep 19, 2013
That's not gonna happen.  Improvements are getting more and more technically difficult, and I doubt a jump that big will ever happen again, unless maybe someone invents a way to have each photosite sense color without losing half of the light to dark filters.  We're getting too close to physical limits.
 paulkienitz's gear list:paulkienitz's gear list
Pentax K-3 Pentax Q Pentax smc DA 50mm F1.8 Pentax smc DA 55-300mm F4.0-5.8 ED Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
solarider
Veteran MemberPosts: 4,174Gear list
Re: What 20MP sensor outperforms the K-5/II/IIS ?
In reply to pixelsmithy, Sep 19, 2013
Boy pixelsmithy you're just regurgitating FUDD. That sucks, especially when others pick up on it and go into a slump and spread the gunky slime around.
Pentax will have likely Sony custom make them a sensor for 14 bit and have it optimized for still photo quality over video.
Whatever they come up with, it will be as good as it gets for the tech.
It might be 20 or it might be 24 MP, we'll see when it's announced.
I don't think they'll be letting anyone down.
pixelsmithy wrote:
DLBlack wrote:
Ricoh rep was in the local camera store. He was excited about the new high-end aps-c camera that is going to be announced in early Oct.
If the OP's rumor is true and it is a 20MP sensor, then who did Pentax go with? Sony (SLT 58) or back to Samsung (NX200/300)? (Canon's sensor is even worse than those two). It looks to me like there is going to be a net LOSS of Dynamic Range to go with the gain in megapixels. Even factoring in that the cameras currently out there using the Sony/Samsung sensors are only 12-bit and the Pentax will presumably be 14-bit, I'm guessing that the Dynamic Range will go backwards 1/2EV.
Frankly, the Dynamic Range is more important to me.
A newspaper is a device for making the ignorant more ignorant, and the crazy, crazier.
- H.L.Mencken
_ _ _ _ _
History would be something extraordinary, if only it were true. Leo Tolstoy
_ _ _ _ _
Any dictator would admire the uniformity and obedience of the U.S. media.
Noam Chomsky
_ _ _ _ _
Science... became scientism, which means it didn't just pursue its own truths, it aggressively denied that there were any other truths at all... Ken Wilbur
_ _ _ _ _
At any given moment, there is a sort of all pervading orthodoxy, a general tacit
agreement not to discuss large and uncomfortable facts… Anyone who
challenges the prevailing orthodoxy finds himself silenced with surprising
effectiveness. - George Orwell
_ _ _ _ _
“It's not a matter of whether the war is not real, or if it is, Victory is not possible. The war is not meant to be won, it is meant to be continuous. … The war is waged by the ruling group against its own subjects and its object is not the victory over [the purported enemy], but to keep the very structure of society intact.” George Orwell, 1984
miles green
Veteran MemberPosts: 4,718Gear list
Re: Pentax K3 rumor from the plant... shhh...
In reply to Roland Karlsson, Sep 19, 2013
I hope you're right!
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +9 more
miles green
Re: Ricoh super-resolution?
that's what i thought....
Miles Green
Corfu, Greece
Roland Karlsson
Forum ProPosts: 23,445Gear list
Re: sooner or later
In reply to paulkienitz, Sep 19, 2013
There are still some things to do.
  1. You could collect all visible photons at each site. Thus you would avoid noise and also have a better sampling, a la Foveon. NOTE - Foveon do not collect RGB and it has a very bad red layer. A real RGB camera would be much better.
  2. You could have a much greater bucket depth, probably then simulated with some clever means. This would increase the DR manifold. So, maybe 24 or 32 stops? This is not only a gimmick. It would improve clipping and also would give you the possibility for long exposures, i.e. at very low ISO.
  3. Four layers, one of them IR. Fun!
  4. More pixels. A 100 MP APS-C sensor will force the lensmakers to lift themselves in the hair to make extra ordinary lenses. The oversampling will also allow for software based filtering, like the filtering in audio equipment, which might result i much smoother images without noise reduction artefacts. It will also mean you can use digital zoom.
  5. Seven layers! Ehhhh ... why not? You can do very strange color manipulations with all that input.
  6. Extremely long exposures. Lets say that the sensor can stay black even if it is exposing for hours in the dark. Just imagine what you can do.
Then we shall not forget that there are other things than the sensor
  1. Rock stable shake reduction. Current improves 2 stops or so and probably never can give the same steadiness as a heavy tripod. But - if it could. Really rock stable SR.
  2. Automatic DOF stacking. Lets say that the sensor can detect sharpness at pixel level. Lets say that it do a quick scan with the focussing and choose the sharpest pixel during that scan.
  3. Sensor based SR. Lets say that you can pan a car, and that the sensor can measure and keep that car razor sharp during panning.
  4. Extreme anti glare LCD that works just fine even in bright sunlight.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sony Cyber-shot DSC-RX100 III Sigma DP3 Merrill Sigma dp2 Quattro Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited +8 more
Jim in Hudson
Senior MemberPosts: 1,649Gear list
Re: sooner or later
This idea will certainly reveal how little I know about light and imaging but here it goes (and at risk of wrong forum):
What if pixel density becomes so high that it's feasible to use a six-color filter... the three primary colors plus the three secondaries?  I imagine color accuracy would have to be noticeably improved.
 Jim in Hudson's gear list:Jim in Hudson's gear list
Pentax K-3 Fujifilm X-T10 Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 35mm F2.4 AL Sigma 10-20mm F4-5.6 EX DC HSM +4 more
klavrack
Regular MemberPosts: 384
Re: sooner or later
Their target needs to be the rumored D400 and D610.  Make buyers choose between the sensor advantages of a D610 and the size/performance speed of a top-tier APS-C.
paulkienitz
Re: sooner or later
In reply to Jim in Hudson, Sep 19, 2013
Six colors won't really help if it's still based on the trichromatic color model.
What I hope becomes feasible someday is if each photosite can not only count photons, but sort them by energy, so the output from each site is a spectral histogram.  Then we could not only have color without a bayer array, we could have color more accurate than that of the human eye.  There's evidence (controversial) that the usual trichromatic model is only adequate for the majority, and some people are able to distinguish shades that the model cannot.  Even without that, current camera sensors make all kinds of small color errors -- deep violet turns into pure blue, and red+green blends often come out unbalanced, making people look like they're under fluorescent light when they're not.  These problems are inherent to trichromatic reproduction.  A spectral photosite would eliminate these problems and all the other kinds of metamerism that throw off color reproduction.
But that's currently a complete pipe dream... it might be achieved someday, but I bet it'll take years and years.  In the meantime, progress on improved sensors is going to be a lot more gradual and incremental than what it used to be.
Q with 02 zoom and Nikkor 180/2.8 ED for birding
K10D, Sig 17-70, DA 55-300, FA 50/1.4 "billy bass"
discards: DA 50-200 "zipper", F 100-300, Sigma 135-400 "piglet", M 400/5.6 "the Great Truncheon"
dnaseigel
New MemberPosts: 18
Re: sooner or later
In reply to klavrack, Sep 19, 2013
And what if the D610 doesn't offer any sensor advantage?  Then the only compelling argument for Nikon will be 75 gajillion lenses Nikon has produced, the dearth of camera stores who would even think to mention a Pentax camera and the reality that we'll all do what Ashton Kutcher  does.
Roland Karlsson
Re: sooner or later
Thats correct. You do not gain anything to have both RGB and CMY, they are just linear combinations of each other.
I would really like that.
I don't know about that. If someone finds how to make a real RGB sensor that collect (nearly) all photons and this in the same location for all three colors, that will be a quite huge step. Also if you remove the annoying highlight clipping by being able to collect some more photons in the bucket would greatly improve things.
DLBlack
Forum ProPosts: 11,720Gear list
In reply to Cane, Sep 19, 2013
No beer from the drinking fountains.  Just Murphy Camera in Louisville, Kentucky.  For the past 6 months or so the Rep has been coming by every few months.  At one time he had Pentax on his bussiness card.  Now it has Ricoh on it.  Still it seems Pentax under Ricoh is getting the Reps out to local camera stores better than Pentax under Hoya.
 DLBlack's gear list:DLBlack's gear list
Pentax K-5 Pentax K-7 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II +29 more
DLBlack
Re: sooner or later
A"little bird" said that the upcoming dslr will be a very big and significant upgrade over the K5ii and will be the best aps-c camera in the market.  The "little bird" was singing a happy song.
janneman02
Forum ProPosts: 15,729Gear list
Re: sooner or later
Gary Martin wrote:Pentax/Ricoh needs to make a strong case for APS-C in the next generation, with the latest Micro4/3 sensors getting closer to the last generation of APS-C imagers.
Interesting idea, if the lastest M4/3 get close to the APS-C, the upcoming  APS-c can very well be closer to FF than many would have thought possible,  probably with exception form the latest FF cameras and the narrow DOF, but that might very well be handled with a software solution.
http://i.pbase.com/t1/73/362673/4/109584377.e8MTmsbX.jpg
http://i.pbase.com/o6/73/362673/1/90215210.jVwGKoPT.bugfv2kq5.gif
> The difference between genius and LBA is that genius has its
> limits.
> - Janneman ( adaptation of the Kings quote from Albert Einstein)
jay_akita
Regular MemberPosts: 242
In reply to britcam, Sep 20, 2013
britcam wrote:
jay_akita wrote:
Simon Devlin wrote:
K_Photo_Teach wrote:
Richard the picture man wrote:
That`s fine, please post a picture or two showing us how your images are losing out without more megapixels.
Regards - Richard
Happy guy with a K5
N.B. All my Images, even the bad ones, are Protected by Copyright
That kind of a question implies that photography can`t benefit from more megapixels.
Do you really believe this?
Some people forget or don't know that if you up the megapixels you also need to up the IQ of your lenses to justify them!
Hence why Nikon have a list of very expensive top end lenses recommended for use with their D800
Just sell the car and buy a 645D and be happy ever after!
Simon
Legacy lens lover
Don't forget the pixel pitch on the K5 is ~equivalent to the D800. Yes you need a full frame lens that's good to the corners but Nikon now has a nice selection of affordable lenses (sometimes cheaper & better featured than Pentax) jthat work great with the D800. I switched from the K5 to the D800 (after shooting with K100D, K20D, K7 & K5) and for $200 you can get a great 50mm F1.8 with a lens hood and full time manual focus over-ride! In fact a big part of the reason I switched is because Pentax's pricing strategy had become so obscene (and aggravating to someone like me watching my investment yo-yo in value constantly) that Nikon looked like a bargain and allowed me to cover my needs with far fewer lenses than I had for Pentax.
I have the 70-200 F4 (used to own the 60-250 DA* and 50-135DA*) and it is the most amazing lens I've ever had my hands on. Being able to easily crop to 400mm equiv. with 9MP of resolution remaining is very liberating. I can walk around with the 24-120 F4 and cover a huge range with ~F2.8 APS-C depth of field (lens is also great, extremely resistant to flare and sharp). I got it for ~ the same price new as Pentax's 16-50!!! Throw in an amazing Yungnuo flash with great build quality for $200(!!!) that supports full wireless slave control/i-TTL/remote flash adjustment via camera body with accurate exposure and lots of power and I consider the D800 a bargain compared to my previous Pentax setup (also picked up Yungnuo wireless RF flash triggers with full i-TTL for $100!- all less than the price of Pentax's cheapest flash that has much to be desired). My wife thinks I use the term "bargain" a little loosely though
For the first time in a long, long time my LBA (and camera upgrade addiction) is well under control because I can finally "have it all" - great optical quality, extremely fast AF with great tracking options, and shallow depth of field in one lens.
It's a shame because the K5 really is a phenomenal camera but I just feel Pentax/Ricoh is continually dropping the ball and almost deliberately sabotaging their most loyal customers...
You say "affordable Nikon lenses", but assuming that you mean the 70-200 f2.8 (not f4), then that lens plus the 24-120 & the D800 come an an eye-watering £4372 at UK prices. Then you will need to add something at the wide angle end, so you need to add something like the 16-35 or the 14-24 into the mix for your "bargain" price ...
The Pentax weakness in this comparison is the absence of a lens with a focal range similar to the 24-120. But even if we substitute the 16-50 to the K5II, and add the 60-250, , the total comes to £2534, with no real gap, so roughly £2k cheaper than the Nikon kit.
"I consider the D800 a bargain compared to my previous Pentax setup"
I don't think it's surprising that you are pleased with your D800 kit, but is it really a "bargain" at those prices?
Kind regards
britcam - Rich S
I was talking about the 70-200 F4...I looked seriously at Nikon before selling my K7 and buying a K5 but at that time it was going to cost a small fortune to get what I wanted in Nikon glass.  Fast forward a couple of years and 4 great, newly released, affordable lenses and I bought the following (USD - sorry  don't know anything about UK prices???):
50 F1.8 for ~$180 (sale)
85 F1.8 for $400 (sale) - amazing lens and way faster AF than my DA*55 (which I loved but for the AF)
24-120 F4 for $1000 (sale) - tried several 24-70 F2.8 lenses and was surprised at how well this lens compares.  Also has incredible flare resistance, I've shot straight into the late afternoon sun with it (I've owned the DA 15mm as well).  Incredibly versitale, my favourite walk around lens ever.  Like having a APS-C 16-80 F2.8 lens.
70-200 F4 - ~1300 - Anybody who photographs toddlers or sports owes it to themselves to throw this thing on a D800 with AF-C or 3D AF and hold down focus with stabilization on while zooming in and out.  This is the lens that sold me on a high resolution body that I can easily crop to 400mm equivalence.  It's like every lens I use has a variable tele-converter built in.
D800 - refurbed with 90 Day Nikon warranty and 1 year Adorama VIP warranty for under $2400USD.  When I say "bargain" it's in part because I no longer feel compelled to monitor camera forums year-round for any rumors of an incremental upgrade that will cost me over $1000 but still not spin my SDM motors any faster, improve C-AF, or add even trivial improvements to the video features.
Previously I had over 10 Pentax lenses, some for convenience and weather-sealing (DA*50-135, DA*60-250) but they had slow AF, so I had to have some that were lighter with faster screw-drive AF (ie DA 35 F2.4, Tamron 17--50 F2.8 etc), and some for shallow depth of field portraiture (ie DA*55, Rokinon 85mm F1.4 etc) - but these were typically so slow AF-wise I hardly ever had the patience to use them with the kids.  I now have my bases pretty well covered in 4 lenses with 5 year warranties, and stable market prices so all said it worked out to be a "bargain" for me.
That said, if I didn't have young kids that make AF and video features very important to me, and still mainly shot landscapes I suspect I'd still be shooting fairly contently with my K5.  But the lens price yo-yo game would still be getting under my skin...
paulkienitz
Re: sooner or later
In reply to DLBlack, Sep 20, 2013
That actually would not be surprising.  C and N appear to be shying away from making any more crop-sensor cameras above the amateur-enthusiast level, and this leaves an opening for Pentax to make a camera that's clearly and blatantly superior within the crop-sensor niche.  This may be an opening for setting up how they can survive as a crop-sensor company in a full-frame future: by emphasizing that C and N now see crop sensor bodies outside the bottom tier solely as bait to suck you towards their full frame systems, and if you actually want a crop sensor, Pentax is the best system.  The APS DSLR will inevitably end up as a niche product, but Pentax has a chance to end up on top of that niche, and it's clear that for them to have a strong future, they have to be seen as taking the format more seriously than C and N do, and so that's exactly where I expect them to aim.
johnami
Contributing MemberPosts: 773Gear list
Re: sooner or later
In reply to janneman02, Sep 20, 2013
Funny how we like to drool about things we know nothing about.  Yep we know near to nothing about the next product launch from RiPentax....................But speculation!!  What fun we have reading the comments of others just because 'an interior voice' gives out some exterior speculation?  Yes more of that stuff.
I sometimes wonder if 'what is newer, more recent is always better?' We know what we have K5* and we complain about this or that or we compare to this or that, (which is something I will really never understand because,  if the grass is greener on the otherside, you move!  Or at least you do eventually, well I would.
I remember in the good old days of mechanical photo boxes MX/ LX stuff, I used to think, 'well if my little button battery dies on me, I will still be able to use my camera simply by using a 125 shutter speed and F 5.6 aperture  and with a bit of chance my pictures will come out'  But I had to buy a film, load it, a delicate procedure, and then send the 36 frames off to a lab to finally see the pictures some time later..................................yes, the good old days.........??
Anyway if a K* is to see the light of day it will probably be an improved K5* or a total revolution. But the problem with improvements is that they will never satisfy everybody completely and as for a revolution, well that can also occur if you change the famous K mount imo but then we will all be complaining..................won't we!
Whoops more speculation.
Cheese
 johnami's gear list:johnami's gear list
Sigma DP2 Panasonic Lumix DMC-LF1 Pentax K-3 Pentax K-5 Pentax K10D +11 more
janneman02
speclation
In reply to johnami, Sep 20, 2013
With all these speculations one thing is certain, whatever comes will fuel more specuation.
> limits.
ASR45
Forum ProPosts: 34,362Gear list
Re: speclation
Time will tell, will have to wait and see.
> limits.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS 6D Canon EOS 5D Mark III +7 more
Roland Karlsson
Re: sooner or later
I have absolutely no need of a "very big" camera. The competition makes their cameras smaller.
Very big cameras are only needed for super teles.
