RX100/2 Flash in hot shoe?
Started Sep 18, 2013 | Questions
ECT
ECT Regular Member • Posts: 112
How do you avoid build-in flash to pup up and hit a low flash in the hot shoe?
Can't find any possibilities in the menu.
Erik
 ECT's gear list:ECT's gear list
Leica Digilux 2 Sony RX100 II Leica D-Lux (Typ 109) Leica M9 Leica Elmarit-M 28mm f/2.8 ASPH +7 more
Sony RX100
LesHoug Forum Member • Posts: 66
Re: RX100/2 Flash in hot shoe?
Erik
The contacts in the hot shoe are always active when the camera is turned on, so if you put an external flash in it, it will fire every time you trip the shutter, so you need to turn the built-in flash off from it's menu setting to stop it popping up.
Hope this helps
Les
 LesHoug's gear list:LesHoug's gear list
Sony RX100 II Panasonic Lumix DMC-LX100
aaanouel
aaanouel Senior Member • Posts: 5,107
Wireless Flash?
Read this:
Wireless Flash with the RX-100 MK II?
Gary Friedman Archives
aaanouel
Truth is a pathless land.
The dead past darkens the ever living present.
Corrections and critics are more than very welcome, desirables.
 aaanouel's gear list:aaanouel's gear list
Sony Cyber-shot DSC-P73 Sony Cyber-shot DSC-HX100V Sony SLT-A65 Sony DT 18-250mm F3.5-6.3 Adobe Photoshop CS6 +21 more
Bill Bill New Member • Posts: 6
I am having the same problem- the internal flash fires AND the hot shoe flash fires when it is connected. Turning the flash off in the menu does not fix the problem, it just turns off all the flashes.
Hi Bill Bill
I haven't got a Sony dedicated flash, so i've only tried it with my old flash e.g= Metz 34 CS-2 digital, this works all time, even with the built-in flash turned off, sorry if this confused the issue.
Les
