DA 55-300 vs DA* 300 f4
Started Sep 16, 2013 | Discussions
paulkienitz
paulkienitz Veteran Member • Posts: 5,188
How much real gain is there in upgrading to the star prime, over the consumer zoom?
I would have assumed the improvement is large, but DxOMark says otherwise. According to their numbers, the 55-300 is optimized to favor the long end, so 300mm is actually the sharpest point in its focal length range, and at that point, it produces the same sharpness score as the 300/4!
Can this really be true, or is it yet another case of DxO not seeing quality that other testers have no trouble seeing?
In a way, though, I'm not that surprised, because of how flawless the images I get from it at the long end continue to be.
Leaving aside other performance qualities such as speed, focusing, vignetting, distortion, lateral CA, and everything else other than sharpness near the center... can those who've used both really say the star lens is significantly better?
. v . v .
After that comes the $2000 question... what about similar lenses from C and N? Are any of them significantly better?  DxO says Canon's 300/4 L is around the same quality as our 300/4...
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
leopold
leopold Forum Pro • Posts: 13,990
Re: DA 55-300 vs DA* 300 f4
Hi,
i have the Canon 70-300mm IS (not the L one) and it's good at 300mm but not as good as a Prime 300mm lens, i did own the FA*300mm/4.5 in the past and the FA*300mm/4.5 was better than what i get from my Canon 70-300mm IS which is probably equal to the Pentax 55-300mm.
I have own different long Prime lenses and a Prime will always be sharper from 300mm and up than a Zoom especially consumer zoom like the DA55-300 and my Canon 70-300mm IS unless you pay for premium Pro lenses like a Pentax FA*250-600mm/5.6 or the Canon 70-300mm IS L or the new 200-400mm/4 L !
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm f/4.0L USM Fujifilm XF 14mm F2.8 R +3 more
GossCTP
GossCTP Veteran Member • Posts: 4,711
I have a hard time believing that. Especially since the 300 f/4 is supposed to be sharp at f/4 and maxes out at f/5.6. I've done test shots with the 55-300, and it is by no means at it's best wide open at 300mm. I think it improved until at least f/9.5, particularly at the corners.
I remember comparison images that were done by one of the veteran forum members back when those lenses were both fairly new - richardday perhaps. Anyway, they were full size pics and in comparing them it looked no contest to me. I have a 55-300, and I don't consider it to be sharpest at 300mm. Perhaps 230mm or so.
So other than that, how was the play, Mrs. Lincoln
Seriously, those are all huge factors. I've never been fond of the rendering of the 55-300. It's certainly miles ahead of the Tamron 70-300, but not in the same ballpark as the DA* 300, which I have been tempted by for some time. The 55-300's OOF specular highlights are generally rendered with purple boarders which makes certain backgrounds kind of nervous. The 50-200 beats it in that regard IMO, although it is not as sharp and doesn't go to 300mm.
The expensive long zooms like the Sigma 120-400 have a hard enough time competing with lenses like the DA* 300 f/4. I don't think the 55-300 is a real challenger.
http://members.cox.net/dpph0t0dump/newsig.jpg
Through the window in the wall
Come streaming in on sunlight wings
A million bright ambassadors of morning
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K20D Pentax K-5 II Pentax smc FA 50mm F1.4 Pentax smc DA 16-45mm F4 ED AL +7 more
Gary2010
Gary2010 Contributing Member • Posts: 526
I have both at this point in time.  Have bought the 55-300mm 3 times and the DA* 300 twice.  As far as IQ, the DA 300* wins by a decent margin.  Mostly to do with subject isolation at F4 vs F5.8.  It also renders finer detail if you like to pixel peep.  Focus on the DA*300 is also better and quiet.  The 55-300mm is noisy and it ratchets back and forth if it misses initial focus. The DA*300 is also water resistant and at F4 you have a possibility of using a Teleconverter with it with decent results.  I use the AFA 1.7x with mine.
All that said.  The DA 55-300 is packed and ready to go with me on a cruise next week which includes a whale watch excursion.  I decided to travel lighter on this trip and plan to get some nice shots with the DA 55-300mm.
When I lived in Louisiana and loaded my pelican cases in the truck and went to the Bayou to take pictures, I did not mind hauling the larger lenses with me.  They are easier to haul around in a vehicle than on your shoulder around town.  Also, after hauling the 60-250 to Alaska, I have decided to try lighter and hope not to give up too much IQ.
As far as other lenses from Nikon or Canon, I believe both have decent lenses in the 55 or 70-300 range but probably more expensive.  Their F 300mm lenses are just s good as ours.
 Gary2010's gear list:Gary2010's gear list
Sony Cyber-shot DSC-RX100 III Olympus Tough TG-4 Olympus E-M1 Pentax K-3 Olympus OM-D E-M10 +15 more
paulkienitz
paulkienitz OP Veteran Member • Posts: 5,188
leopold wrote:
Hi,
In other words, you're guessing?
ozdean
ozdean Forum Pro • Posts: 22,860
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
robbo d
robbo d Senior Member • Posts: 1,730
Hit and miss sometimes....
I own the 55-300 and always sung it's praises from a value for money perspective.
It has always seemed to me to give excellent results across the whole focal range, so much so, that I couldn't really tell where the sweet spot was. I then read an article that stated the sweet spot was at 250mm, but if you read Photozone test, it's emphatically at the 55-100 end where it shines and centre sharpness at 55 is better than the DA*300 could achieve at any aperture!!!, then apparently it dramatically drops off...........this isn't my experience at all. Iv'e had some very sharp images at the long end and beautiful colours to boot.
I guess this is all indicative of lenses giving different results and then also on different cameras. I read of a sigma lens tested on a Canon body giving poor results, but "stellar" results on a Nikon body.........most likely a lens issue.
I think the 55-300 is noisy and hunts for focus, but gives excellent IQ and punches well above it's weight. I would assume the DA* is a better performer, but that many hundreds of $$ better is again up to you to decide what's worth to you. Also better build quality and the overall border performance will give the DA* a better overall look.
These lens tests give a fair indication but not always reliable......not so much from a testing point of view, but perhaps that lenses just seem so fickle in their back and front focusing issues and quality control.
My Kx kit lenses were always sharp in focus....not high IQ, but sharp, my FA 28-105 just seems to be a peach of a lens, but I purchased a DA*50-135 I took to a wedding the other week and had horrible focus issues. Tried my new DA12-24 and so far not impressed either.....seems soft.
Maybe my new K5IIs will change the whole ball game again.........bit frustrating really.
 robbo d's gear list:robbo d's gear list
Pentax K-x Pentax K-01 Pentax K-5 IIs Sigma 50mm F1.4 EX DG HSM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +13 more
paulkienitz
I hope someone can actually locate such a comparison...
For some, yes, but for me, less than you think.
I think its bokeh at the long end is pretty decent.  It gets much worse as you pull back toward the short end.
Considering everything, of course not... but if you judge solely by center sharpness?  As a birder, I often don't care in the slightest what the corners have in them -- you could have impenetrable fog in the first, a smear of feces in the second, a flashing ad for Viagra in the third, and in the fourth a vision of Satan commanding me to kill, and it wouldn't impair my shooting at all.
paulkienitz
wow, that is a dramatic difference.
Thanks.  But I wonder if there's something wrong with the copy in that first shot, because I don't think mine is capable of doing that badly.
Q with 02 zoom and Nikkor 180/2.8 ED for birding
K10D, Sig 17-70, DA 55-300, FA 50/1.4 "billy bass"
discards: DA 50-200 "zipper", F 100-300, Sigma 135-400 "piglet", M 400/5.6 "the Great Truncheon"
leopold
paulkienitz wrote:
leopold wrote:
Hi,
Not guessing that much, the DA55-300mm is a consumer zoom lens and the DA*300mm/4 is a Pro prime lens, so there is no way a consumer zoom will equal a Prime 300mm at it's 300mm settings from my experience and the DA*300mm/4 is said to be a little sharper than my FA*300mm/4.5 i had before, which was quite a sharp lens.
brandrx
brandrx Forum Pro • Posts: 28,107
6
The DA 55-300mm is a very fine consumer zoom lens. One of the best IMO. I bought, checked out, and gave away 7 copies as gifts to relatives. I still have my DA*300/4 pro lens which, IMO, is the best danged 300mm lens in the whole danged universe. Ask me for proof and I will say I cannot prove it. Ask me which lens I would use if I had the choice between the two and I would say the DA*300/4 lens everytime.
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
veroman
veroman Veteran Member • Posts: 4,671
I really don't know how the 55-300 compares to the prime since I've never used the prime. But I do own some sharp, detailed Canon L glass as reference, particularly my 70-200 f/4 L IS.
I purchased my 55-300 specifically for traveling light and still having reach. I used it for the first time yesterday at my granddaughter's 1st birthday party.
The pics are excellent, even at 300mm. I'm impressed and surprised. I had expected compromises in IQ at this price point ... and certainly at that focal length ... but it performed really well.
The downside to the 55-300, as one poster has already pointed out, is noisy focusing and occasional ratcheting if it doesn't catch the focus right away or if it hunts when it can't find enough contrast in the subject.
Other than that, I consider the 55-300 to be an excellent performer.
SteveG
'When love and skill work together, expect a masterpiece.'
— Found in a Chinese Fortune Cookie
www.stephenmichaelgarey.com
 veroman's gear list:veroman's gear list
Leica X Vario Sigma SD9 Olympus PEN E-P5
ozdean
Re: wow, that is a dramatic difference.
I was fond of my 55-300 until I got my DA*300, the stars are in another league.
Gary2010
Ha Dean. I remember those shots.. Are you glad you got the 300 prime?
best I remember, you got some good shots with the 55-300 also.
maybe I should pack heavy. Lol
audiobomber
audiobomber Veteran Member • Posts: 5,241
Two stops+ gain, IME. I own both and have done comparative tests. I'll take the DA*300 @ f4 over the 55-300 at f8. The 55-300 is unacceptably soft at 300mm f5.8, and pretty good at f8. The DA*300 is freakin' amazing at f5.6. I use the star lens with a Kenko 1.5X. The 55-300 is crap with the TC.
NOTE: I am a pixel peeper. I judge sharpness at 100% crop. I was thrilled with the 55-300 on a 6mp camera, not at 14.6 or 16mp. With the DA*300, I can crop to 100%, even with the TC, and still have sharp images. Weather-resistance is hugely important, in my corner of the world. It is an amazing pro quality lens. I value the 55-300 for its good IQ, compact size and range of focal lengths. I use it when I don't expect to crop hard.
I don't know what they're doing. No previous tests have shown max sharpness at 300mm, and that is intuitively wrong.
Dan
 audiobomber's gear list:audiobomber's gear list
Pentax K-3 Sony a6000 Pentax K20D Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +16 more
John Cafarella
John Cafarella Contributing Member • Posts: 985
+ 1 for me.
My wife has the 55-300, it's good, but the *300 is indeed in another league.
John Cafarella
Melbourne, Australia
ozdean
Gary 55-300 is a good general lens I personally think it is better at the short end but if you really want quality at 300 the DA* is it. I compared it with another brand 70-200 which was very good but just not there. I have to agree with Ron it is tops.
ozdean
Hi John, heading down your way next week I hope you put on some good weather!
joseluismx
joseluismx Contributing Member • Posts: 604
Worth every penny.
 joseluismx's gear list:joseluismx's gear list
Pentax K-5 II Pentax K-5 IIs Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +7 more
UtahManSir
UtahManSir Veteran Member • Posts: 4,645
Thanks. Trying to decide what to put on my wish list next, was gonna put the Bigma on there.... now you post these.....
FYI I don't think that my 55-300 is that bad at f10 or so on a tripod... could be wrong...
Lloyd
“For every problem there is a solution which is simple, clean and wrong.” Henry Louis Mencken
http://lloydshell.blogspot.com/
http://lloydshell.zenfolio.com/
WSSA #354
http://lloydshell.zenfolio.com/img/s3/v41/p234497562-3.jpg
