Lenses for visiting Ayers rock...
Started Sep 16, 2013 | Discussions
cpt kent Regular Member • Posts: 161
Hi all,
Im off on a holiday in a week, to Uluru (Ayers rock)
Uluru
Im taking the 14-54II, 45mm and 60mm macro
Im undecided between the 12mm or the Panasonic 7-14. I can't take both, but I'm leaning towards the 12mm for sone night photos. Panoramas will probably be with the 14-54, and stitched in photoshop. using the E-M5.
Thoughts / suggestions between the two?
Martin.au
Martin.au Forum Pro • Posts: 10,317
Re: Lenses for visiting Ayers rock...
Looks like a good combo. I think the 12 would be wide enough.
 Martin.au's gear list:Martin.au's gear list
Olympus E-M1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Panasonic Lumix G Fisheye 8mm F3.5 +6 more
Acrill
Acrill Senior Member • Posts: 1,901
There isn't a huge difference between 14 and 12mm, especially if you are willing to stitch.
The main reason I can see for taking the 12mm is star photos wide open at 2.0, but you could still manage this just fine with the 14-54mm at 2.8.
I really can't see a need for any of the primes you have mentioned as you can get similar results with just the 14-54mm and macro doesn't seem like a serious consideration for Ayers Rock.
Maybe you only need to take one lens?
 Acrill's gear list:Acrill's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 60mm F2.4 R Macro
cpt kent OP Regular Member • Posts: 161
Thanks,
45mm is coming along because ill be visiting family afterwards, and need it for photos of my nieces / nephews.
60mm is coming along, because I've only just purchased it, it doesn't take up much weight and I'm lovin finding uses for it!
Both of which step me up from my Messenger 100 to Messenger 150 bags, so I may as well fill the small hole left - hence the question.
But in essence your right, my 14-54 will/could do most things I ask of it!
I'm thinking the same.
harveysteeves Regular Member • Posts: 437
7-14 ... 7-14 ... 7-14
sorry, I disagree with your conclusions.  I would leave the 12 at home and bring, yes, the 7-14.  Nowadays, on a trip, I just don't leave home without it. With that angle of view, it can do things no other lens can.
 harveysteeves's gear list:harveysteeves's gear list
Pentax 645Z Olympus E-M1 Nikon D810 Olympus E-M5 II Sony Alpha 7R II
peppermonkey Veteran Member • Posts: 3,790
I'm in the wide angle camp...
cpt kent wrote:
Hi all,
Uluru
so I'll definitely be reaching for the 7-14mm. Specially if you are already bringing the 14-54...since then you would be covered from 7-54mm. If you see yourself taking macro shots, then take the 60mm otherwise, even though it's new, I would rather swap that for the 12mm, though with the 7-14mm I'm not sure you would need it. Course if you want to travel as light as possible, things change
Hubert
My non-digital gear: Agfa Isolette, Fed 2, Konica Auto S2, K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sony RX100 II Sigma DP2 Pentax K110D Panasonic Lumix DMC-GF1 +11 more
Ulric Senior Member • Posts: 3,580
No fisheye?
 Ulric's gear list:Ulric's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +9 more
robonrome
robonrome Senior Member • Posts: 1,899
Lots of macro opportunities so yes the 60. I would also take rhe 7-14
 robonrome's gear list:robonrome's gear list
Sony Cyber-shot DSC-RX100 III Olympus E-M5 II Sony Alpha 7R II Olympus E-M1 Olympus 12-40mm F2.8 +13 more
sinkas Senior Member • Posts: 1,180
Take them all. The 12mm is a small lens....:-)
Regards Daryl
 sinkas's gear list:sinkas's gear list
Olympus OM-D E-M5 Nikon D7200 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +6 more
Considering...
Good point. Thanks
Re: I'm in the wide angle camp...
Thanks?
No fisheye.
Its never been my 'cup of tea', though I have seen some nice pics on this forum recently. Perhaps one day...
fraserhadden Regular Member • Posts: 291
From the standard 'Viewing Uluru at Sunset' position, the 14-54 will be fine, as 35mm fills the frame. As I remember it - from 2005 - wider lenses would simply produce a smaller monolith against a backdrop of nothing much.
I presume that you will, at least, walk around the base at sunrise the following morning. Again, the 14-54 will be fine to capture the interesting contours of rock from this closer range.
Fraser
The wont all fit in the bag I use, but I may be able to stuff it into my jacket pocket for the plane flight!
I had wondered on the field of view / focal length from there. Thanks!
Phil1 Senior Member • Posts: 1,111
I seem to recall that a 28mm lens was fine for getting the whole rock in one shot but that I also used a 40 mm lens to do a stitch from 2 photos. Both lenses were full frame so the equiv in M43 would be 14mm and 20mm.
Of course it depends on where you view from. We did a guided tour at sunrise and could get no closer than the barrier everyone had to stay behind and the above lenses were used from there. I assume the barrier won't have moved but it would be best to get advice from a more recent traveler. Try posting also in the Open Talk forum as you'll reach a wider audience.
The best shots occur when the light (at dawn) is low so I'd be inclined to take the 12mm (f2?) rather than the slower zoom if the rock is important to you. I guess the same would apply in the evening.
Go early as it can get crowded!
Its a great place - have fun & watch out for the flies, mossys & spiders!
Phil
The real important thing is to get up before daylight and start photographing as the sun comes up. Also don't forget the Olgas, and Kings Canyon, just as spectacular IMO.
Regards Daryl
goshigoo Contributing Member • Posts: 750
Re: 7-14 ... 7-14 ... 7-14
Totally agree! always bring 7-14 when going to travel!!!
282QSR New Member • Posts: 8
Hi There
Whatever the lens; do yourself a favor and take the sunset FLIGHT over Uluru and the Olgas (Kata Tjuta).
Actually, come to think, you don't need a wide angle for that.
Pricey,Yes,  $$$$ - but unforgetable!
You already spent all that money to get there, so a few more bucks? Who cares!
Kind Regards
Menno
