America's Cup: OMD E5 and 75-300
Started Sep 15, 2013 | Discussions
Calinature Regular Member • Posts: 463
I made an expedition into the "city" (San Francisco) yesterday to try and capture the sailing races. I drove my car to the nearest Bart (Bay Area Rapid Transit), took the train to the Embarcadero Station, and then made a rather long walk to where the races were being held. Well, I am glad that I took the uM4/3 system and did not lug around my big DSLR system (E5 and big SHG lens, give me a break). Here are some photos taken from the shoreline, most of the boats were about a mile away, and I generally shot at 300 plus 2x digital converter (=1200 mm for FFs), all hand held. Given the distance, I am satisfied with the results, plus I had enough energy to walk back to the Bart Station.
BTW, most of the folks with cameras were Canakons, generally small to medium sized, and fitted with smallish zooms, so I don't think they were getting as close.
I am looking forward to the E1 which will be home to some of the wonderful SHG lenses, so maybe we are getting close to "one beautiful system" (not that there aren't others out there as well). Jeff
Fleabag
Fleabag Senior Member • Posts: 2,378
Re: America's Cup: OMD E5 and 75-300
Looks like they came out pretty good...
Pete Berry Senior Member • Posts: 2,584
Nicely done, with very nice quality at this size. The 1200mm EFL shots of the cats against Alcatraz, and the tight bow shot of Emirates NZ are impressive!
I watched the first race in real time yesterday, and my heart damned near stopped with the near capsize of E-NZ! Which would probably have been "end of story" for them with wing damage or worse, and about the only way, it seems, for Oracle USA to win the cup as they will need nine wins vs. E-NZ's only needing three more.
PB
Calinature OP Regular Member • Posts: 463
Thanks for looking. I missed the near flip of the Kiwi boat...the rock pier was in the way. It would have been nice to have captured that.
It's amazing that these boats travel at speeds close to 50 mph!
bidule5 Regular Member • Posts: 112
I like the 3 in front of Alcatraz.
Race 9 starting now.
yvan
 bidule5's gear list:bidule5's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +1 more
BlueJakester
BlueJakester Senior Member • Posts: 2,086
Excellent photos and you really captured and conveyed the feeling of speed. It's amazing how fast these cats get going!
If I might offer one small comment ... some of the photos would look even nicer if the horizon were leveled in post processing. It's not usually distracting unless water is in the landscape. It would bump your photos from a 9.5 up to a 10 IMO.
Thanks for posting!
Jake
nzmacro
nzmacro Forum Pro • Posts: 12,680
Very nice. I would love to be there, I'm a Kiwi and watching this on TV here every race day
Great shots, but you need to watch those horizon lines, rotate them.
All the best and great to see these shots.
Danny.
peevee1 Senior Member • Posts: 6,247
Technically there are some problems. Shutter speed seems too fast, and ISO as a consequence is too high. Stopping down to f/8 in the middle of the range when f/5.6 is perfectly good was unnecessary, as well as f/11 at 300mm. Due to long distance/haze, processing IMO would benefit from some extra contrast.
BTW, was it original 75-300 or 75-300 II?
Martin.au
Martin.au Forum Pro • Posts: 10,271
Well spotted. Good points. OP, next time perhaps try for F6.7 (the 75-300 should be almost exactly the same between f6.7 and f8), 1/1250 and keep ISO low and auto. These are the settings I use for birding, with pretty good results.
ISO 1000 should be fine usually, unless the subject is fairly small and fine details. I think these boats often qualify.
Other than that, great shots. Wish I could come and watch.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
Actually, at 300mm stopping down a little to f/8 increases sharpness a bit, and with digital teleconverter (crop) there is not such thing as too much sharpness:
75-300 @300mm
Further stopping down though just degrades the picture, both due to diffraction and higher ISO.
We are talking about 2x tele sometimes here, meaning ISO1000 as bad as ISO4000 when using full frame when downscaled to the same size.
Thin_Ice Regular Member • Posts: 175
I like the combination of the boats racing in front of Alcatraz and the zoomed in frontal view of the cat in the spray of the waves.
For smaller racing dinghies, i try the same: focus on the athlete, the lower part of the mast and the spray of the bow wave.  This emphasizes the speed.  I use the OMD and the 45mm and try to get real close with the coach boat - not an option at the AC.
The speeds at the AC72's are insane and the amount of money  involved is way over the top.  I prefer the normal one design dinghies and cats, that are already extremely fast and athletic to sail compared to a 40 ft Yacht.
 Thin_Ice's gear list:Thin_Ice's gear list
Olympus E-420 Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Voigtlander Nokton 17.5mm F0.95 Aspherical
What, water is horizontal?
Good point!  Here's some straightened up. Thanks!
This is the original 75-300. I thought that F8 would be a good compromise, with enough sharpness and dynamic range but emphasizing speed as I was hand holding and the boats were very, very far away?
Yes, I see your point...very fast, very expensive...is this really sailing in the water or flying above it?
So you think my settings (f8) were ok?
Martin.au
75-300 @300mm
Depends on lens variation I suspect. My copy has no discernible difference between f6.7 and f8.
Yes, at 300mm it is the best on this lens. But at 150mm, f/5.6 is just as good and would let you keep ISO lower.
75-300 @150mm
I know, with variable-aperture zoom it is a hassle to keep aperture at what you want while zooming.
Hand-holding would usually keep the pictures reasonably sharp at 300mm with 2x at 1/1200 even without IBIS, probably 1/200 with Oly IBIS. I have seen you using 1/3200 and 1/4000 which seemed unnecessary excessive to me. Although I did not see the action so might be wrong, but usually the movement I can actually track in the viewfinder can be frozen even at 1/500s, except the extremities (which the boats lack). Just in case 1/1000 should be safe.
I hope my comments do not offend you in any way. I come to the forums to learn (equipment and techniques) and entertain myself, and assume others are too.
Here are my 8 and 14 year old grandsons planing on a close reach in their ancient, beat up Laser-II dinghy - a tight crop at 150mm with the P-L 14-150 3.5-5.6. In far northern CA lagoon. Sail trim looks pretty good!
PB
billbourd Contributing Member • Posts: 553
Would love to see how they would look with a little more contrast. All great action shots.
 billbourd's gear list:billbourd's gear list
Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus 12-40mm F2.8
Bruce Clarke
Bruce Clarke Senior Member • Posts: 2,650
Nice shots. I've been watching the superb TV coverage which we are getting on the BBC in the UK. Very clever software overlays showing wind and tide. Really brings it alive. Terrifying machines!
Bruce
 Bruce Clarke's gear list:Bruce Clarke's gear list
Olympus E-5 Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 7-14mm 1:4.0 +5 more
