DMC-FZ70 Lens Hood - Semi Homemade
Started Sep 14, 2013 | Discussions
Hiker Dood
Hiker Dood Junior Member • Posts: 35
I recently got my paws on an FZ70 but it doesn't come with a lens hood.  It's not even offered as an accessory, probably because at 20 mm zoom almost any hood will vignette.  Being the stubborn cuss that I am I decided to see what I could do and this is what I came up with.
Parts:
1 Sunpak CF-7033-UV 55 mm UV filter
1 Bower HRW55 wide angle lens hood
Glue - I like Loctite Repair Extreme All Temprature
Steps: remove the rubber lens hood from the metal ring that threads onto the lend.  It's too deep and will cause vignetting (trust me, I tried it).  Carefully fit the rubber hood onto the Sunpak UV filter.  Be careful to position it so that it doesn't vignette.  Apply a thin bead of glue using a toothpick or end of a paper clip both inside and outside of where the hood meets the filter.  Position it on the camera and make sure it doesn't vignette.  Carefully remove it and let the glue set completely.  And you have this.  I also used a piece of EZPass Velcro to secure the lens cap when not in use.  Works great and doesn't wear out.
Ta-daaaaaaaa!
Jeff
The Hiker Dood
 Hiker Dood's gear list:Hiker Dood's gear list
Panasonic Lumix DMC-TS20 Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ70 +2 more
Rodger1943
Rodger1943 Senior Member • Posts: 7,784
Re: DMC-FZ70 Lens Hood - Semi Homemade
Where there's a way Jeff. It looks to me like you did a great job. I'm also amazed that the FZ70 didn't come with a lens hood, all the other FZ series cameras had one.
Panasonic FZ200
 Rodger1943's gear list:Rodger1943's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ1000 +2 more
Robiro Veteran Member • Posts: 5,935
Did you keep UV glass?
Did you keep the UV glass inside the filter ring? Or did you remove it?
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 Panasonic 12-35mm F2.8 +4 more
Hiker Dood
Hiker Dood OP Junior Member • Posts: 35
Thanks.  I took it for a test run yesterday in Norvin Green State Forest and it seemed to work pretty well.  I've included a sample below.
The Blue Mine in Norvin Green State Forest, Ringwood NJ.
Jeff
The Hiker Dood
Hiker Dood
Re: Did you keep UV glass?
I kept it since I do a lot of hiking with my camera and I wanted a bit of protection for the lens.
Jeff
The Hiker Dood
PC Wheeler
PC Wheeler Forum Pro • Posts: 15,929
I'm surprised the FZ70 comes with no hood. Apparently they have done all they can to keep the price point low, not a pleasing trend.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot SX50 HS Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +7 more
Jeff
The Hiker Dood
Try making comparison shots at full zoom on a pixel level. With and without the UV glass. At these magnifications ANY glass put in front of such lens could be causing troubles. I would definitely check this before having a UV filter constantly on. You could be losing resolution.
Vandyu Veteran Member • Posts: 8,768
Nice workaround. Thanks for sharing the photo and instructions. Sounds like the lens hood was left off as another way to save a few cents, but to tell the truth, I've got them for all of my cameras and lenses and seldom use them anymore. They can serve a good purpose, though, and your idea is well thought out. I used the collapseable rubber hoods that screw on with my older film lenses, but also have collection of plastic ones with the newer lenses and they sit in the bag.
I got to thinking about your post some more and went to B&H's website. The FZ70 has a 55mm filter size and I'm wondering if this rubber hood wouldn't fit it:
http://www.bhphotovideo.com/c/product/11152-REG/B_W_65069603_55mm_Screw_In_Folding_Rubber.html
This one above, however, is more for normal or short zoom lenses. This one says it's for wide angle:
http://www.bhphotovideo.com/c/product/70740-REG/General_Brand_NP11155_55mm_Screw_In_Rubber_Wide.html
Other choices in the 55mm range:
http://www.bhphotovideo.com/c/search?atclk=Size_55mm&ci=2226&N=4077634523+4294957251
"Promise me you'll always remember: You're braver than you believe, and stronger than you seem, and smarter than you think." (A.A. Milne)
 Vandyu's gear list:Vandyu's gear list
Panasonic Lumix DMC-FZ200 Nikon D80 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +9 more
Phil
Phil, I guess Panasonic has decided it's survival of the thriftiest!
Hiker Dood
So far so good.  I'm very pleased with the performance so far.
Jeff
The Hiker Dood
Hiker Dood
Maybe, but you will need something where the metal part isn't very deep or you'll get vignetting.
Jeff
The Hiker Dood
genece Forum Pro • Posts: 15,400
If anyone tries this hood , I wonder if they would be so kind as to let us know  how it works......or perhaps send me a message.......the Fz70 has my attention , but no hood is a problem.
Thanks.
Gene from Western Pa
http://imageevent.com/grc6
http://grc225.zenfolio.com/
FZ 30
D50 ....D80.....D7000 - 18 to 200VR- 50mm 1.8 - 80 to 400 OS
http://photos.imageevent.com/grc6/toshareonnet/topost/gene1111a.jpg
Just trying to learn and it's slow going!
 genece's gear list:genece's gear list
Panasonic Lumix DMC-FZ30 Nikon D50 Nikon D7000 Nikon D7100
