EM1 vs EM5 on Camera Size Comparison website.
Started Sep 12, 2013 | Discussions
David 247
David 247 Senior Member • Posts: 2,981
Camer Size Comparison now has the EM1 in their system. This is a link to a comparison in size and weight between the EM1 and the EM5
http://camerasize.com/compare/#482,289
And compared to the GH3.
http://camerasize.com/compare/#482,381
As I suspected, the EM1 falls right in between the two.   Since I have handled the EM5 and the GH3 it gives me a reference point.  The EM5, even with horizontal grip was a just a bit too small for my comfort and hands.  The GH3 was just a little big.  So if all goes well, the EM1 should be just about right.   From appearances, ergonomics also look just about right for the EM1, but I won't be able to tell until I get a chance to actually handle one.
Looking good though.
- David
'The most important feature of any camera is 'Will you have it with you when you need it."
http://lightweaver.zenfolio.com
http://lightweaversblog.blogspot.com
http://www.youtube.com/my_videos?o=U
 David 247's gear list:David 247's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-FZ300 Olympus E-M5 II Olympus 12-40mm F2.8 Olympus 9mm F8 Fish-Eye Body Cap Lens +1 more
Olympus E-M1 Panasonic Lumix DMC-GH3
David 247
David 247 OP Senior Member • Posts: 2,981
Re: EM1 vs EM5 vs GH3 with lenses
And just for fun, all three together with lenses, from the top. Unfortunately they don't yet have the Oly 12-40 F2.8 in their database. Maybe soon
http://camerasize.com/compact/#289.332,482.336,381.336,ha,t
- David
Corkcampbell
Corkcampbell Forum Pro • Posts: 15,055
Thanks for this. I'm aware of that website, but hadn't bothered to check.
I have the GH3 and OM-D, both with grip, and happy with both. As you pointed out, the new Oly fits between them somewhere. I am also surprised at how much bigger in size and weight the EM1 is over the EM5.
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-RX100 III Sony Cyber-shot DSC-RX10 III Panasonic Lumix DMC-GH3 +4 more
John Kubler Regular Member • Posts: 291
Re: Thanks for this. I'm aware of that website, but hadn't bothered to check.
If you add the optional grip to the EM5, it will measure (height and length) almost identical to the EM1. The weight will be the same.
JMK
 John Kubler's gear list:John Kubler's gear list
Olympus E-3 Olympus PEN E-PL1 Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus E-M1 +16 more
peevee1 Senior Member • Posts: 6,247
One of the disappointments that they did not use that extra weight and space in the grip for bigger battery - unlike Panasonic with GH3.
knickerhawk Veteran Member • Posts: 4,473
Re: EM1 vs EM5 on Camera Size Comparison website.
A better visual comparison can be seen on Ming Thein's review. He's lined up the EM-5 with the horizontal grip next to the EM-1. They're almost exactly the same height. The EM-1 is a smidgen wider. He also shows both with the vertical grip. Again, they're very similar in size except the EM-1 is a little wider. I ALWAYS have my horizontal grip on the EM-5. It's just too small and difficult to hold without it. I expect the gripless EM-1 will feel very similar in size and weight to that configuration.
The EM-1 seems to be getting lots of kudos for ergonomics, which wasnt the case for the EM-5.
jack Hoggard
jack Hoggard Contributing Member • Posts: 825
You sound like Goldilocks.
jaxupra
 jack Hoggard's gear list:jack Hoggard's gear list
Olympus Stylus 1 Sony Xperia Z Ultra Google Nexus 7 +1 more
David 247
jaxupra
You read my mind.
- David
David 247
I agree.  And design the horizontal grip so it could hold 2 batteries.    But as much as I would have liked that, it isn't a major issue for me.
- David
dwhitekc New Member • Posts: 19
Coincidentally, the new Pro O12-40 has exactly the same dimensions as the first generation P14-140 lens. So you can easily compare size; just not "the look."
Here's an updated comparison .
 dwhitekc's gear list:dwhitekc's gear list
Sony RX100 II Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +2 more
David 247
I hadn't realized that.  Thanks for sharing.
- David
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,258
Looks like the E-M1 is the same size as the Em-5 with a RSS grip attached.
Cool.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
Corkcampbell
Yes, totally agree. I really like the duration of the GH3 batteries compared
to those of my GH2s - over two hours of non-stop video from one battery! Before, I use to worry about losing power when shooting from an unattended tripod; now, I must remember to put in a large-enough card.
Of course, if Oly had done that, then we would be seeing threads complaining about non-compatibility with the previous OMD batteries... with good third-party batteries at about $30 (B&H for GH3), I don't see an issue.
TrapperJohn Forum Pro • Posts: 13,796
But if you put the vertical grip on the EM5...
As a lot of us do, they're about the same size.
Still very small. As are the lenses.
justmeMN Veteran Member • Posts: 3,573
EM1 vs Canon SL1/100D Size comparison
http://camerasize.com/compare/#482,448
They are in different price classes, but I find it ironic that the mirrorless camera is wider, taller, and heavier than the DSLR.
(I say ironic, because some mirrorless enthusiasts carry on about DSLRs being big, bulky, and heavy, compared to mirrorless.)
cmpatti Regular Member • Posts: 254
Bloat
It seems almost a law of nature that new versions of products must become larger and larger and that the original value of compactness will be forgotten as manufacturers seek to cram more features into each successive product generation to justify a new purchase to customers. I love the small size of the EM-5 (even at the possible cost of handling) and wouldn't think to add to its bulk with the add-on grip. The additional size of the EM-1 is the primary reason I won't consider buying that camera. I hope the replacement for the EM-5 retains its smaller dimensions.
 cmpatti's gear list:cmpatti's gear list
Sony Cyber-shot DSC-RX100 III Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus 12-40mm F2.8
Martin.au
Martin.au Forum Pro • Posts: 10,317
Re: EM1 vs Canon SL1/100D Size comparison
I think you're confused. Very few people assess a camera alone. That's kinda pointless. I've seen a few people comparing camera + 1 lens, which is also kinda pointless, imo. To do it properly, you need to compare systems, or the usual array of stuff that you carry.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
jalywol
jalywol Veteran Member • Posts: 7,386
Oh come on now.  Mirrorless is a system, and as it develops, it covers a wider range of functionality....This camera is designed to be compatible with larger and heavier lenses from the four thirds series; it's built for heavy use; it has a top notch huge EVF and extremely fast focusing; and it is targeted at a pro or semi pro user.  If you wanted to compare apples with apples, you would be looking at a much higher level camera in Canon's line up, and I guarantee you it would be a heck of a lot bigger....
Plus, no matter what the body size of an M43 camera, the native lenses are ALL smaller and lighter than the ones for a comparable Canikon....
If you wanted a more appropriate comparison, you should look at, say, a G5 vs the SL1, instead....and even then, the lenses will be smaller....
-J
Ulric Senior Member • Posts: 3,580
This is a comparison of a cheap, entry-level DSLR and a substantial, top of the line mirrorless. Here is comparison of camera bodies with more corresponding feature sets:
http://camerasize.com/compare/#387,448
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
