Should I switch from Pro1 to M1?
Started Sep 11, 2013 | Questions
ggsphoto
ggsphoto Forum Member • Posts: 54
I would like to replace my pro1 with an m1 for size reasons but would miss pro-neg lo and hi.  Anyone know
a) taking an astia shot how to turn it into pro-neg hi or low in post processing (or do you know if they will be available in a firmware upgrade in the future ?
b) Not so sure I'dmiss the viewfinder, in bright light I hear the lcd can be turned up at the expense of clipped highlights (doesn't sound so bad)
c) no switch for manua/c/s focus switching.
Articulated lcd is a big plus, I miss this from my oly c5050z
Anyone migrated from pro-1 to m-1 and like to share the experience ?
Thanks.
ryan2007
ryan2007 Forum Pro • Posts: 12,001
Re: Should I switch from Pro1 to M1?
Thanks.
Why is XE-1 not an option?
OR
switch to Micro Four Thirds.
bowportes
bowportes Senior Member • Posts: 2,529
Thanks.
Three months ago you referred to your pro1 as a "dream camera" with much to master. Now you are considering downgrading to a lower tier in the Fuji lineup.
I'm sure you're aware that Astia, Pro-neg, etc. are simply digital filters to render different JPEGs from the same raw data. The only way I know that you might get Pro-Neg look from an X-M1 is to shoot raw + JPEG, hang on to your XP1, insert the card from your X-M1 into your X-P1, and re-convert the raw file to the Pro-Neg look. Short of that, you can play with settings now by shooting Raw+JPEG (Pro-Neg) with your XP1, and then attempting to PP the raw file until you achieve the look given by your OOC Pro-Neg JPEG. Once you have arrived at those settings, they could be applied to any X-M1 raw file.
If you want to achieve a Pro-Neg JPEG look from the X-M1, a raw file would be a much better beginning point than an OOC Astia JPEG.
I expect that few have "migrated" from the top-of-the-line Pro-1 to the bottom-of-the-line M-1, even though some have certainly picked up an M-1 as a smaller companion to their Pro-1.
 bowportes's gear list:bowportes's gear list
Fujifilm X-M1 Panasonic Lumix DMC-G5 Fujifilm X-T1 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +9 more
ggsphoto
ggsphoto OP Forum Member • Posts: 54
Ok - let me give you the background....before I bought the pro1 I had bought the x10.  I liked this but the quality was good but not exceptional.  Its hung around on my shelf for a year and I'm currently selling it on ebay, and have actually bought an M1 now and am waiting for it to arrive.
Ok - so - the M1 is really a replacement of the x10 I have - i.e. light and the same pro1 sensor, fantastic, I can put it in my pocket and it can come everywhere with me.  But then I got to thinking, its the same sensor as my pro1, so are the features I like on the pro1 good engouh to justify keeping it.  I could sell it for around £550 on ebay and that can go to my future fund.
My no1 priority is IQ - so for me the pro1 pretty much equals the M1...yes, I love my pro1 and I'm hoping I'll love the M1.  If I had one single criticism of the pro1 is I cannot get it in my trouser pocket !
X-E1 is not an option because its still too big, and micro 4/3 isn't really an option now I have the lenses I want for the X range...I think the IQ on the x-trans is better than the 4/3rds...
So I just wanted to get a feel for what others though about the M1 in case I do something rash and sell the pro1 without using the M1 enough !
Red5TX
Red5TX Senior Member • Posts: 1,586
X-M1 won't fit in your trouser pocket, either, except MAYBE with the pancake lens.
Alexander2505
Alexander2505 New Member • Posts: 24
It depends on the size of a pocket, heavy pro requires strong belt then...
 Alexander2505's gear list:Alexander2505's gear list
Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS
ggsphoto
Of course you are right - it has to be the pancake or I think the 18mm (which I have) should be okay.  The X10 fits no problem.
I reckon I could get away with the 35 in one pocket, x-m1 body in the other, eh?  now we're talking....
JayK_dpreview
JayK_dpreview Forum Member • Posts: 90
This is just a personal opinion but is is still going to be big and uncomfortable to walk around with. Also being able to carry in pockets means you want it to be handy and depending on what kind of shooting you are targeting its not a great idea to take body from one pocket, lens from other, put it on, turn it on, meter it, compose and click.
You might be better served with something like a Richo GR or Canon S95/S100.
slowhand73
slowhand73 Regular Member • Posts: 165
jjsphoto was apparently happy with the size of the X10. The X10 and M1 body are almost the same size. The difference will be in the length he'll choose.
I, myself, thinking of replacing my X20 with M1+27mm pancake (and one of the zoom lens 16-50 or 18-55).
 slowhand73's gear list:slowhand73's gear list
Fujifilm X-T1 Fujifilm XF 27mm F2.8 Samyang 8mm F2.8 UMC Fisheye Fujifilm X-M1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
ggsphoto
The Ricoh gr is certainly a very interesting camera  - but for many reasons I think the M1 is better.  Plus I have the X lenses I can snap onto it.  Sure, once at youre destination pulling out the 35mm and snapping it on the body is not a 2 second job, but its pretty fast and it can be carried from then on.  It doesnt' really matter, piont is its really really convenient...
If you check out camerasize.com, the m1 is the same size as the x10 - perhaps slightly bigger with the 18mm lens.  I was able to take this camera out and use it - parks, countryside, walks, commute up to london etc - and having it in your pocket is just fantastic.  Yes, its not small but very convenient.  Its not iphone sized...but get this - 8 years ago I lugged around a D300 and a sigma lens the size of a tank, and i'll be getting better images out of my m1 and its in my pocket !
gerard boulanger
gerard boulanger Senior Member • Posts: 2,262
X-M 1: 4.6 x 2.62 x 1.54″
X-PRO 1: 5.5 x 3.2 x 1.7"
Yes, smaller...
 gerard boulanger's gear list:gerard boulanger's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8
JYPfoto
JYPfoto Contributing Member • Posts: 718
Why downgrade to a lesser camera just to fit in your pocket?  Just get an appropriately sized bag.
 JYPfoto's gear list:JYPfoto's gear list
Olympus E-M1 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 12-40mm F2.8 Olympus M.Zuiko Digital 25mm F1.8
Red5TX
To be honest, I was surprised to see how much smaller the X-M1 is.  Still have to deal with lens size, though...
JYPfoto
It certainly is smaller but ability to put into one's pocket should be the last thing to come into consideration when dealing with a MILC.  Maybe if you're talking about compact P&S, but for a interchangeable system then no.  There's far too many trade offs with the obvious downgrade (losing superior build, viewfinder, etc).  Even more silly is the OP's suggestion of carrying a 35 1.4 in one pocket and the camera in another.
javaone360
javaone360 Regular Member • Posts: 116
I got the X-M1 and X-Pro1.  X-M1 is good, but it doesn't have the OVF/EVF.  It is not small enough compared to my Ricoh GR.  X-M1 with 18mm/27mm may be good for winter jacket's pocket.
The X-M1 AF such as face recognition and continuous tracking is not avaliable on X-Pro1.  It gives us some ideas what the future X-Pro camera will be like.  If you want to carry a small camera with a prime lens, the X-M1 is not a bad option.  I still prefer my Ricoh GR.  I believe the IQ is the same as X-Pro1.
The WiFi function saves you some money to buy a WiFi SD card.  It also has a built-in flash.
 javaone360's gear list:javaone360's gear list
Ricoh GR Sony Cyber-shot DSC-RX100 III Fujifilm X-Pro1 Nikon D800 Nikon 1 V1 +31 more
ggsphoto
Just to recap - sounds like the m1 will work for me.   Interesting points but fitting in trouser pocket really is important - it transitions a the camer from (still) something I'm concious of taking out on trips out anywhere to something I will probably always carry.   the evf/ovf sure is good, but really, I could live without it...and the tilting lcd really is very very useful.
Keeping a lens in one pocket/camera in the other ?  Sure its daft, but not that daft.  I love the fact this kits so small, I love the fact my pro1 is so so much smaller than my old d300, this kidn if thing is important.  Build qualty?   Really?  I don't care, I want the camera to last 3 years at most by that time I'll be buying the x-pro2 or x-m2.
I'll do a comparison of the two when it comes and let you all know....
JYPfoto
If it works for you, then great.  Just sounds kind of crazy to want to carry a body in one pocket and a lens in the other.  Make sure you keep track of the rear lens cap as well as the body cap.
Travelshooter
Travelshooter Senior Member • Posts: 1,976
Why don't you just use a photog vest?  Put the X P 1 in a pocket with the pancake and the other lens in the other pocket.  You can slip your X10 in the breast pocket for a backup.
www.MartinDareff.com
 Travelshooter's gear list:Travelshooter's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 23mm F1.4 R +15 more
rxbot
rxbot Contributing Member • Posts: 666
While I think the XM  1  is overpriced I think it would go very well with the 27mm pancake and wonder if there is an aftermarket optical viewfinder that would work with it. The 40mm equivalent lens would be great as a walkaround streetshooter lens and would be the smallest package. Think cargo pants pocket. And trade the pro1 when the X-E1s comes out.
Torch
Torch Senior Member • Posts: 1,979
A
ok go with the M1 and know the quality differerence will make you feel the M1 is a temporary camera, but you will enjoy the articulated LCD like a c5050z. In its day that cam was as much as a X100s. You will keep in X-trans and carry on.
It's tough to leave a flagship camera and not notice what's lost, yet if newer is better then so be it. Oly may be improved, but enough to match X-trans is up to you.
Torch
