Two FZ200 Questions
Started Sep 10, 2013 | Questions
PC Wheeler
PC Wheeler Forum Pro • Posts: 16,028
Two FZ200 Questions
I just received my new FZ200, replacing the one I sold in Feb or March. I have two questions:
  • Does the camera come with a battery cover? Replacement batteries tend to and (as I recall) some Panasonic cameras/bodies do and some don't. What was your experience with FZ200?
  • I like to use the single area focus, and the smallest area. Is there a way to keep the area from resetting when the camera is turned off then on? This may have been an issue with my first FZ200 (or not) but is not an issue with my GH3.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS +5 more
Panasonic Lumix DMC-GH3
richj20 Veteran Member • Posts: 3,504
Re: Two FZ200 Questions
No. I purchased a backup battery, Wasabi BTR-BLC12-JWP which does have a cover
Unfortunately, no.
- Richard
"Careful photographers run their own tests." - Fred Picker
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Leica 100-400mm F4.0-6.3 ASPH +1 more
PC Wheeler
PC Wheeler OP Forum Pro • Posts: 16,028
Oh Drat re the AF area size. Looks like it can easily be resized by hitting left rocker button and moving the dial. Hmm .. wonder if it can be stored in C1 or C2? I'll give that a look.
Thanks for the quick reply, Richard.
Phil
cainn24 Senior Member • Posts: 4,882
That doesn't work either, as you've probably discovered yourself by now.
My LF1 saves the size and position automatically, and now that I am getting used to a camera that does, the absence of this simple feature on the FZ200 is even more irritating.
Here's hoping this gets fixed with a firmware update some time soon.
PC Wheeler
Yup, I did. However, I found a quicker (for me) way to change the size: Tap the Focus button on the lens, move the dial, and then re-tap that button. Using the rocker button is less certain with all the other things to hit in that area. Anyway, I'll try shooting with the default area for a while (probably did that with FZ200 #1); perhaps it focuses faster that way..
I re-bought the FZ200 because having 25-600 mm of really good IQ with an f/2.8 is so much more convenient than hauling my GH3, 100-300 and at least one other lens. So far I'm quite pleased with this new FZ200, IQ-wise and otherwise
Yes, I'm sure my lowly TZ5 of long ago saved the size and position, too. Surprising they didn't get it right with the FZ200.
Hoping but with limited expectation
Phil
RayUK Senior Member • Posts: 1,028
Phil
This is something which also really annoys me. I guess that  most of us wanting to use the 1-area focus do so because we want the smallest possible focus area. But Panny obviously think using the default larger area is the norm. Please have a re-think Panny - the norm should be the smallest possible area, with the option of increasing it's size if wanted - but why would you?
Ray
GeraldW Veteran Member • Posts: 6,988
Glad you went back to the FZ200.  I did much the same thing.  Be very careful with the hood.  The ones on my FZ200's were VERY stiff to mount or dismount and I'm pretty sure that mounting and/or dismounting with the lens extended screwed up my first one.  I fixed that with the current one by filing and sanding down the locking lugs until I had a positve lock; but with very little torque required to seat and unseat.  In the meantime, don't mount/dismount, store/unstore the hood with the camera ON, unless yours needs low torque - some apparently do; but mine didn't.  The FZ150 was perfect right out of the box, and served as my model for the feel on wanted on the 200.
I swear my current one acts differently than the early one I had.  I'd be very interested to see how you think your two compare.
Enjoy.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon PowerShot SD950 IS Canon PowerShot Pro1 Canon PowerShot S95 Canon PowerShot ELPH 330 HS Panasonic Lumix DMC-FZ200 +2 more
Holmes375
Holmes375 Veteran Member • Posts: 3,790
I did similar mods to mine.  Out of the box it was certainly more stiff than I was comfortable with.
 Holmes375's gear list:Holmes375's gear list
PC Wheeler
I use Wasabis, too, Rich. I generally buy two with charger, which also gives me a car charging capability. I've had very good luck with that brand -- and have two for the FZ200 (and my GH3). Mine came with the battery covers, too -- and so did a Panasonic spare for my GX1.
Maybe Panasonic figures that one battery will always be in the camera and needs no cover. But one earlier Panny (GH1?) did come with a cover for the battery supplied with the camera.
Phil
PC Wheeler
Ditto, Jerry. My FZ150 was a better fit. Both FZ200s were stiff. But I never remove the hood, well have not as yet. The two bags I use hold the camera with hood in shooting position, just. Hmm .. I do plan to order a 52 mm Canon 500D close up lens. Installing that will require the mod you did,, so I may be back with another question if I can't dope out how to do the mod.
Acts differently: In what way? I'm not seeing any diffs, but then I didn't recall about the size of the focus area resetting so ... . I'm at the age where too many brain cells are going bye-bye
Phil
Phil,
I purchased that 2 battery/charger kit for my G3 because that camera really drains batteries! But with the FZ200, I went 3 1/2 days on one battery when I first got the camera, so I didn't think I needed more than one extra battery.
On a recent trip to the Sequoia National Forest, taking many shots (2 or 3 for each flower) I never used up the Panasonic Battery iin one day. One time, the Wasabi battery went down to 1 bar.
I'm *very* happy about the battery life for the FZ200!
- Richard
