Would love PENTAX-A SMC 50mm f1.2 on a full frame!
Started Sep 9, 2013 | Discussions
Simon Devlin
Simon Devlin Senior Member • Posts: 1,274
I'd love to see this combination even on film!
Maybe flickr
Simon
Legacy lens lover
Petroglyph
Petroglyph Senior Member • Posts: 4,886
Re: Would love PENTAX-A SMC 50mm f1.2 on a full frame!
According to my "Pentax Lenses and Accessories" booklet.  It was printed in May of 1984 by Asahi Optical co.  On page 14 they list a SMC Pentax-M 50mm f/1.2.  It says great lens for the ME-Super camera (I bet it was)  They have a 135-600mm f/6.7 tele zoom on page 27!  Sweet!  Where is my time machine?  It was probably about 400$ back then.
Cheers.
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +4 more
steephill Veteran Member • Posts: 9,719
No M series
There isn't an M series version of the f1.2 design. I think you will find that it is the earlier K series lens that appears on your brochure although of course Pentax never referred to their first series of K bayonet mount lenses as K series. The 135-600 zoom is also the earlier "K" series rather than an M.
More goodies below
Steve
www.pbase.com/steephill
It performs very similarly to the other 50mm lenses apart from wide open of course where it has what can kindly be described as a "dreamy" quality. That is to say low contrast and resolution.
SRS sold the last UK stock a few years ago at £400.
Steve
Tom Lusk Senior Member • Posts: 1,382
On my copy of the same booklet, it has the "SMC PENTAX 50mm f/1.2" on the bottom of page 14. The only lens on the two pages of "Standard" lenses without the M designation, so easy to make the mistake.
Nhelnhel Senior Member • Posts: 1,261
I am still holding on my Sony A850 until Pentax release a FF.
I do not have a 50mm 1.2 but i have a 1.4 and here is a photo taken with FF and 1.4
How much more if a lens is 1.2? Just imagine it...
 Nhelnhel's gear list:Nhelnhel's gear list
Panasonic Lumix DMC-FZ1000 Pentax K-3 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +4 more
Petroglyph
Re: No M series
What is the difference between M series and earlier K series since they are both SMC (super multi coat) and neither have any electronics in them? I understand the A series has the ability to allow the camera to electronically set the aperture on the green "A" mark (I have one of those). I can't find any substantial difference between M and the earlier K (which they just leave off the M when they list it I've noticed.
Cheers.
More goodies below
Steve
brandrx Forum Pro • Posts: 28,260
Re: No M series
The M versions are smaller and weigh less than the K version. Also, in certian lenses like the M200/4 has a built in pull-out hood whereas the K200/4 does not.
The A lenses are basically the same as the M version except they have the "A" position setting on the lens.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
rossdoyle Regular Member • Posts: 128
I am lucky to have a Pentax-A 50 f/1.2. It works wonderfully on K-01 with focus peaking. The K-5 actually meters too dark at f/1.2. By about f/1.6 it meters normally. The K-01 doesn't seem to have this problem. There is only a minor difference in DOF wide open when comparing between it and FA 50mm f/1.4. I think this is due to the microlenses or the CMOS surface electronic layers excluding high angle of incidence light (so the light from the greatest apertures is attenuated).
il_alexk Senior Member • Posts: 2,276
Why not used manual Canon 50mm 1.2 on FF?
There are also some really cheap Canon FF film cameras out there to match it...
 il_alexk's gear list:il_alexk's gear list
Ricoh GR Pentax K-5 IIs Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc FA 50mm F1.4 +4 more
noel2 Contributing Member • Posts: 559
Maybe flickr
Simon
Legacy lens lover
Pending a FF, here is an image taken with the SMC F1.2  50mm at full aperture on June 21, 2006. Venus rising with the Pleiades cluster over the Atlantic, seen from the island of La Palma de las Canarias, Pentax ist* DS, 15 sec at ISO 800. Unprocessed.
The lens as it is today:
 noel2's gear list:noel2's gear list
Sony Alpha 7 II Pentax K-5 IIs Pentax K-1 Sony FE 24-240mm F3.5-6.3 OSS Sigma 18-250mm F3.5-6.3 DC Macro OS HSM +22 more
Simon Devlin
Simon Devlin OP Senior Member • Posts: 1,274
Fantastic photo! What a universe eh and the lens isn't too bad either!
Simon
Legacy lens lover
miles green
miles green Veteran Member • Posts: 5,092
Re: No M series
I have the A 1.2/50. Of course, it has the A setting. The A version has 9 blades, the M had 8 if i recall. Not sure about the optical formula.
It's nice for those super-low light situations, or for uber-bokeh portraits. There's plenty of dof control on aps-c, there's no need for more than that (read FF)  imho. Focus is very hard to acheive...
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax K-1 Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +10 more
hanhait Senior Member • Posts: 1,187
Very nice; at 100% you can see the small star trails reflecting the 15 s exposure, and the optical effects around brighter stars (Venus itself becomes rather weird), but no big optical problems, even not in the corners.
 hanhait's gear list:hanhait's gear list
Pentax K-5 Pentax K100D Sigma 70-300mm F4-5.6 APO DG Macro Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Pentax 16-85mm F3.5-5.6 WR +8 more
Barry Pearson
Barry Pearson Veteran Member • Posts: 7,087
I have a booklet with the same name, but no date. It has 42 Pentax lenses in it, including the above.
Pentax really took itself seriously as a professional system, with a reflex lens of 1000mm f/11, another of 2000mm f/13.5, a Shift lens 28mm f/3.5, auto extension tubes, 2x Rear Converter, auto bellows unit & slide copier (I had those), and a 90-degree mirror adapter for discrete photography!
 Barry Pearson's gear list:Barry Pearson's gear list
Panasonic Lumix DMC-LX100 Pentax K-3 II Pentax K-1 Pentax smc DA 12-24mm F4.0 ED AL (IF) Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +18 more
Petroglyph
lol - an "around the corner" lens.  subtle but radical.
miles green
Hmmm, a little harsh. I agree with low contrast wide open, but resolution.... it depends...(read on)
The dreamy quality of the extreme aperture is "enhanced" by the low contrast and by the fact that brighter parts of the image show a halo, when the lens is used wide open or close to that.
Here's a full res pic of my little one with the smc-a 50 f/1.2
This is a moody lens, definitely a "she-lens". Haha! There are things it likes (read: low light) and things it doesn't, like shooting at f/1.2 in sunlight. There is so much glass in this puppy that it must be hard to control internal reflections - which is probably why it never got the star designation. I'm also pretty sure wide open performance was optimized for subjects at portrait distance, 3 to 4 feet away, not subjects 30 yards away (based solely on my experience). On paper it might not look that good - i can imagine it would flunk a resolution chart test.
The lens i have that most resembles the 50/1.2 is the FA 43 Limited, which is also accused of being unsharp wide open, with a moody rendering. The 50 is moodier, no doubt. From a technical aspect, the FA43 will out-class it already at f/1.9. But take them both for a spin and there's no denying that the 50/1.2 definitely has its charm, and some advantages too.
Anyway, if you close it down to a logical f/4ish, it becomes a very well behaved lens (sharp to the edges, contrasty...) with a nice "3D-pop".
Steve
Miles Green
Corfu, Greece
robbo d
robbo d Senior Member • Posts: 1,775
Kind of ironic........
I was filling in some time last night and read an article by ken Rockwell on film vs digital....gather many will have read it. I don't care much whether people regard him, but the principals about film are still ringing true with me.........we do have FF and it's called 35mm film and gazillions of still working cameras at rediculously cheap prices.
No laptops required, no battery chargers, chords, buying new software, waiting for the next model with an extra 4mp plus an enhanced sensor and processor, arguing over which brand is better, spending endless sums of money on upgrading to the latest model.....
I cut my teeth on film and find the discipline and techniques learnt mean I can still pick up a film SLR and get the same sort of results. 35mm translates to fairly high MP count and the detail recorded in film is still very good. Funny how some new film processing plants are re opening!!
Here is my SMC A 50mm f2 on my Kx.......works very nicely and there's something I like about manual focusing. It almost seemed my Kx performed better not having to worry about focusing the lens???
 robbo d's gear list:robbo d's gear list
Pentax K-5 IIs Pentax K-x Pentax K-01 Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 EX DG HSM +14 more
