The F2.8 choice, 12-40mm vs 12-35mm
Started Sep 9, 2013 | Discussions
naftade Regular Member • Posts: 282
Re: 12-35mm (24-70mm FF) FoV is pretty much standard.
drj3 wrote:
Cipher wrote:
drj3 wrote:
bluelemmy wrote:
> whereas the 12-35 takes a 58mm filter.
As do the 35-100 f2.8 and the 14-140mm f3.5-5.6. A very professional move on the part of Panasonic.
David
www.dthorpe.net
I am certain that if Olympus wanted to offer a 12-35mm lens they could have used a 58mm filter. It has nothing to do with being professional. Panasonic chose a more limited zoom range design which allowed them to use a smaller front element for the lens.
Panasonic offered 12-35mm because it gives the same FoV as:
Nikon 24-70mm
Canon 24-70mm
Sigma 24-70mm
Sony 24-70mm
Tamron 24-70mm
The 24-70 FoV is pretty much a standard and so is 70-200mm FoV and thus we have the Panasonic 35-100mm.
The fact that there are lots of 24-70mm equivalents is of no importance to me, if the 24-80mm equivalent has equal quality, is essentially the same size and price then I would find it to be more useful. If the new 40-150 equals the 35-100 Panasonic then I would prefer the extra flexibility that combination offers. Actually I will probably prefer my 12-60mm 2.8-4 (24-120), since the extra zoom range means that I do not need to change lenses as often and assuming it focuses well on the EM-1, it will probably be the lens I use most often.
drj3
This 12-60 really is a very interesting lens (combined with a 43 or mft - hybrid camera). But it is a little  bigger than the 12-40 isn't it?
 naftade's gear list:naftade's gear list
Fujifilm X-E2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R
Silvernitrate Regular Member • Posts: 212
Re: Two reasons why I'll probably buy the 12-35mm
NZ Scott wrote:
ntsan wrote:
So the spec for 12-40mm has been out
M.ZUIKO DIGITAL ED 12-40mm F2.8 PRO
- Linear motor, MSC mechanism, AF inner focus
- Manual focus clutch mechanism
- 20cm minimum focusing distance (maximum magnification of 0.3 times, 35mm equivalent 0.6 times) throughout the entire zoom range
- Dust-proof drip
- Filter size: 62mm
- Total length: 84mm, maximum diameter 69.9mm
- Weight: 382g
- late November release
Panasonic 12-35mm F2.8
- 25cm minimum focusing distance (maximum magnification of 0.17 times, 35mm equivalent 0.34 times)
- Weathersealed
- Filter size: 58mm
- Total length: 73.8mm, maximum diameter 67.6mm
- Weight: 305g
12-40mm being being more larger/heavier than 12-35mm and come without OIS, should make Pana user and maybe some Oly user sticking with 12-35mm instead for the size and without looking ridiculous on their camera.
Though the magnification of 12-40 screams Macro to me, that is even higher than Voigtlander's 0.25x/0.5x magnificaiton which I found to be plentiful for my need without getting dedicated Macro lens.
I've held off buying a pro zoom until now, as I've been waiting to see what Oly will bring to the table to compete with Panny's 12-35 and 35-100.
Even though I'm an Olympus shooter, I'll probably end up buying the Panny 12-35 based on these specs.
There are two main reasons for this:
1) The Oly is 77g heavier, which is a significant amount.
2) Its filter size is 62mm, whereas the 12-35 takes a 58mm filter. I already own several 58mm filters, as they are compatible with my Oly 40-150 ED and Oly 75-300 II. I'm a big filter user, and am a bit annoyed at Oly's inconsistency with filter sizes. They are using 37mm, 46mm, 58mm and now 62mm. There may even be other sizes - for example, the original kit lens used a different filter size, I think.
The price is about the same, at US $900 via ebay. The Oly supposedly has better image quality, but this is of secondary importance for me, as the 12-35 is apparently already good enough. I can't imagine that the 12-40 will be dramatically better.
S.
Same here I`ve held off from buying the Pany 12-35mm.
I`d probably wait until I can handle the 12-40mm attached to the EM1, not that I`m currently interested in the new body yet but you never know
dv312
dv312 Veteran Member • Posts: 3,166
choice is clear for me
the extra 5mm does make lots of difference
Been shooting with the FF 24-70mm and 70mm is just too short for decent portraits
the fact that the Oly focuses closer is a boon
size wise it's still small as compared to the FF 24-70mm
The weight could be due to a more complex lens design
 dv312's gear list:dv312's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus PEN-F Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
dennis tennis Veteran Member • Posts: 3,317
Re: 12-40 ginormous
with this crowd,  every mm every gram is a huge deal.  Size is everything.  Image is nothing.
12-40 is too big too heavy for normal Navy SEAL operators to use in combat.  You need one of those robots thingy from the movie Pacific Rim
Don't you know smallness is everything to mFT fanboys?
drj3 Veteran Member • Posts: 3,781
naftade wrote:
drj3 wrote:
Cipher wrote:
David
www.dthorpe.net
Nikon 24-70mm
Canon 24-70mm
Sigma 24-70mm
Sony 24-70mm
Tamron 24-70mm
drj3
It is larger (575g vs 382g) but since I currently use it on an E5, the total lens camera weight would be reduced by 395g if I switched to the EM-1 and use the 12-60.  I may get my wife the EM-1 with the 12-40 if she likes mine.  She does care more about size and weight than I do.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +6 more
jim stirling
jim stirling Veteran Member • Posts: 7,356
Re: 12-40 ginormous
It may not be everything but for many myself included it is probably the single most important advantage of mFT over other formats. Frankly if you choose to exclude the size and weight of equipment from your system valuation with image quality being your top criteria there are an awful lot of better options available many of which are in fact less expensive.
I own the D800 with a number of excellent lenses and the image quality in every situation is simply better than mFT. However I use my mFT gear far more simply because of the size and weight , if I am going to something where photography is my specific goal then the D800 comes along. For everything else social events/holidays/family etc mFT is my choice. Size and weight are critical points for  mFT users the exchange is a bit poorer image quality for a massive size reduction.
 jim stirling's gear list:jim stirling's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Nikon D810 +12 more
Anthony Curcione Regular Member • Posts: 287
Too soon to tell
I've had the 12-35 on my OMD since the day I bought it.  My only complaints are with CA and distortion (on the wide end).  CA is easy enough to counter in Lightroom although it can sometimes be a pain.  Other than those tidbits, I love the lens.
Depending on test results with the 12-40, I would consider replacing the 12-35 with it, but ONLY if there are significant improvements in the 2 areas above AND if it's at least as sharp as the Panny.  Size and weight difference is negligible especially if it has internal zoom (which I heard it did, but haven't seen that confirmed yet).  Guess we'll see about all that.
 Anthony Curcione's gear list:Anthony Curcione's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro
SkiHound Senior Member • Posts: 2,059
Re: Panny lens, Oly body
I rented the 12-35 and liked it quite well. I have a Zuiko 12-60 and I think the overall IQ from it is a tad better. It doesn't AF worth a damn on the E-M5 and it's pretty chunky but I've been waiting for Olympus to release something in this class. For me it'll come down to IQ. If the IQ isn't better than the 12-35 I'd probably go with the 12-35. And, if the E-M1 handles lenses like the 12-60 well, I may just buy the body.
Acrill
Acrill Senior Member • Posts: 1,864
Re: The F2.8 choice, 12-40mm vs 12-35mm
MarcusBrody wrote:
I have a Panasonic camera now, so I'd be likely to opt for the Panny lens for the OIS.
This is also what I would do. Use the 12-35mm with a Panasonic camera. Yes, future models may have IBIS but it is nice having the option to use less expensive bodies such as a GX1 and still have OIS.
The Olympus 12-40 has a 20cm close-focus distance throughout the zoom range, so it should be very useable as a semi-macro lens.
 Acrill's gear list:Acrill's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R
sgoldswo
sgoldswo Senior Member • Posts: 5,468
Re: A small correction or two
NZ Scott wrote:
azazel1024 wrote:
Without having used any of the discussed lenses, the Pany 12-35 seems pretty solid, but from what I have seen the 35-100 is a little weak, especially wide open and on the longer end.
I haven't used the lenses for any significant amount of time either (I played with the 12-35 in a shop and was quite impressed), but from what I've read in reviews it's actually the 35-100 which is the stronger performer of the two.
Agreed - the 12-35 is great, but the 35-100 rivals the Oly 75mm for image quality sometimes. It isn't as good at 100mm as it is at 80, but it's still extremely good. Here are two samples
44mm
100mm
 sgoldswo's gear list:sgoldswo's gear list
Leica Q Leica M Typ 240 Nikon Df Nikon D810 Nikon D750 +1 more
Pikme Senior Member • Posts: 1,936
different question for me
My question will be - does the 12-60 work well enough on EM1 or do I need to buy the 12-40 or 12-35?
Roberto M.
Jeff Tokayer Veteran Member • Posts: 6,202
Re: different question for me
Roberto M.
I'm willing to take a chance, and order the E-M1 body only. The value of the 12-60 jumped up $100 in value, since the early 12-40 price prediction.
My nickel, since the penny is being discontinued...
Jeff.
dv312
12-60mm
the 12-60mm is a huge lens compared to the 12-40mm and heavier and you'll need an adapter too
good thing you don't have to buy another lens if you already have it
Remains to be seen whether or not it AF as fast as the 12-40mm
I don't have to think; I sold all my FT lenses a few moons back
Cheers
NZ Scott
NZ Scott Senior Member • Posts: 4,077
Re: The weight difference = same as between 14-42 IIR and 40-150 ED
RealPancho wrote:
NZ Scott wrote:
Zenjitsuman wrote:
77g + 2.71 ounces I doubt you could tell one lens from the other when mounted
on the camera.
The difference between the M. Zuiko 12-42 IIR and the M. Zuiko 40-150 ED is also exactly 77g - and the change in weight is quite noticeable when switching between those two lenses on my E-P3.
Perhaps you are an HSP - Highly Sensitive Photographer.
Seriously, though, do you find that extra weight too ponderous and unwieldy?
No, I don't find it "too ponderous and unwieldy". However, I do find it noticeable.
I was also hoping the 12-40 would be smaller than the 12-35, but I think I'll probably be alright with it.
The E-P5 weighs weighs 15 oz. with battery. The total weight is just
over one pound. Weighs less than my gym water bottle that I carry around all the time.
Frank
 NZ Scott's gear list:NZ Scott's gear list
Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +13 more
Zenjitsuman Contributing Member • Posts: 790
I agree with Jim, I carry a Nikon D7100 and some pretty pricey big lenses in my kit only
when I am using my car nearby and going their to take a the D7100 with lens mounted, hanging
from a speed carry, and the other two lenses in pouches hung off my shoulder or in a photovest.
If I am going out and want to just have a small kit, then I use either a Nex 5n with old Leica lenses
or a few cheap Sigma 19 & 30mm lenses, and an old Minolta 35-70mm zoom that was made by
Minolta for Leica R mount when those companies were working on joint ventures.
So sometimes I use a photographers neck strap made by Optech that holds both the Pen and
the Nex 5n, and I have some smaller lenses but still sharp 16mp in low light.
The answer is the size of the lens plus the body, the Nex is in some dimensions smaller
than the Pen is, but not in all measurements.  The Olympus has smaller lenses but a heavier
body.  The P5 has much nicer controls, and good use of the tilt screen, the Nex has both.
One lens I bought that I would like to recommend is the Voigtlander SLII  58mm f/1.4.
My version is in Nikon mount.  Its a FF lens, and I use in on the D7100 body as a portrait
lens, Ditto, with Nikon adapter as portrait lens on Nex.  Its FOV is 87mm on both of those
cameras, its small and because its designed for FF it has little distortion, vignetting or soft corners
mounted on APS-C.
I suppose since its a pretty expensive lens it should be also used as a super fast 116mm lens
on the Olympus P5 as a long portrait lens.  With in body image stabilization and fast aperture
its a perfect lens for this purpose.  Focus peaking is very good on both the Olympus and Nex
and manual control on the P5 is especially convenient.  The lens has an aperture ring and the most
smooth focus you can find.
I like (have)  the Leica/Pany 25mm f1.4 and the Olympus 45mm f1.8 so for me the 12-40mm would
be nice if it had good IQ at 12mm otherwise its not a good lens for landscape.
I don't hear great things about the fast 12mm f2 lens, barrel distortion and soft, not good for
landscapes.  Can you guys tell me what to use for equivalent of 24mm on a 35mm format for
landscapes.   On my Nikon I use the Tokina 11-16mm f2.8 MkII, very good IQ and fast enough
using ISO 3200 for indoors shots without flash.
One more comment, I go to a gym and use dumbbell curls 35 -45lbs. 3x 10 reps.  so 2 or 4 oz.
more or less I don't notice, can't understand this being a big deal.  Its the size of the total package
lens + body that drew me to use a Leica rangefinder for decades.  That is why I ain't interested
in FF DSLR, not their weight but their size with FF lenses.
 Zenjitsuman's gear list:Zenjitsuman's gear list
Carl Zeiss Biogon T* 2,8/25 ZM Voigtlander 15mm F4.5 Super Wide Heliar Voigtlander 21mm F1.8 Ultron
Gregm61 Forum Pro • Posts: 14,473
- Dust-proof drip
- Filter size: 62mm
- Weight: 382g
- Weathersealed
- Filter size: 58mm
- Weight: 305g
I just picked up the Panny 12-35 to use with my E-M5 for some upcoming trips and events where I knew the 12-40 Olympus would not yet be available. The 12-35 balances beautifully on a grip less E-M5 and the image quality is excellent.
That's good to hear.
I played with a 12-35 in a shop a couple of weeks ago, mounted on my E-P3 with large grip. I liked the handling of the lens. The length was okay and it didn't feel as heavy as I expected it would.
It is an excellent compromise of size vs. speed and quality.
Some reviews say that CA is a problem with the 12-35 lens on Olympus bodies, which would mean a few extra clicks in post. I find CA to be annoying because I often forget to correct it - only to notice it again later when viewing the finished product.
That's happened to me more than once or twice.
I just check the CA book on every image in ACR, but a few files also require using the sliders for even stronger corrections. If there's any area of high contrast in the image, I just know there's going to be something there to correct.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
 Gregm61's gear list:Gregm61's gear list
Leica M9 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Leica M (Typ 262) +21 more
sbszine
sbszine Regular Member • Posts: 477
12-40 for sure
Just for the Lfn button.
 sbszine's gear list:sbszine's gear list
Olympus Tough TG-2 Olympus OM-D E-M5 Olympus PEN E-PM2 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +4 more
GlennAA11 Regular Member • Posts: 175
NZ Scott wrote:
GlennAA11 wrote:
Does the Oly have an on-sale date yet?
Yes - late November.
Has it even been officially announced?
It will be officially announced later today (Tuesday, 6am, London time).
And is this 40-150mm f2.8 talk substantiated somewhere or just wishful thinking?
It is "substantiated" in terms of being confirmed by 43rumours.com. Make of that what you will, but they seem pretty sure of themselves about this one. Supposedly, it will ship (or at the very least be announced) by the end of March.
S
Thanks.
Bummer it's not going to be out until then. I am headed to Asia in about 6 weeks so now I am in a bit of a quandry. I was heading towards the Panny 35-100 2.8 and considering the 12-35 2.8 as a nice travel kit with my OM-D. But it's a lot of cash to lay out if the Olympus options will be out in the medium term....
 GlennAA11's gear list:GlennAA11's gear list
Nikon 1 V1 Olympus OM-D E-M5 Nikon D600 Olympus E-M1 Nikon AF Nikkor 50mm f/1.8D +15 more
NZ Scott
Tell me about it!
S
Thanks.
Tell me about it!
In a couple of weeks I'm heading off to the Middle East and Africa for a three-month backpacking trip, including two months on safari. It won't be possible to get hold of an E-M1 or 12-40 by then.
I'll be shooting with an E-P3, a bunch of primes, and the 75-300 II.
Which part of Asia will you be visiting?
S
Optical1
Optical1 Senior Member • Posts: 1,074
When the 40-150/F2.8 is announced...
- Dust-proof drip
- Filter size: 62mm
- Weight: 382g
- Weathersealed
- Filter size: 58mm
- Weight: 305g
I'm interested in the 12-40, but only when the lens "set" is available. I currently have the 7-14, 12-35 and 35-100 which is a very functional cohesive set of lenses. I likely won't purchase until at least the 40-150/F2.8 is announced. The problem with a mixed set of lenses is the difference in zoom/focus direction between Oly/Panny. Honestly, I wish that had been agreed to as a part of the standard...
I'm very happy with my panny "holy trinity", but if the Olympus offers better image quality, it will be hard to ignore - especially with the added range. My only hope is that the 40-150/F2.8 is small enough to compare with the 35-100 - even if it had to be a 40-150/F2.8-4 lens (maintaining F2.8 from 40-100 at a minimum).
No matter what, I'm excited to see what the E-M1 has to offer...
 Optical1's gear list:Optical1's gear list
Canon PowerShot S95 Sony RX100 Sony RX1 Ricoh GR Olympus PEN E-PM1 +17 more
