Tripod vs Monopod
Started Sep 8, 2013 | Discussions
sacentre Senior Member • Posts: 1,599
Tripod vs Monopod
Is there any specific reason for using a monopod instead of a tripod other than just convenience or situations where using a tripod would impossible? I have both but rarely use them apart from the tripod  for indoor  "studio" stuff.
Trevor
 sacentre's gear list:sacentre's gear list
Canon EOS 5D Mark II Canon EF 85mm f/1.2L II USM Canon EF 200mm f/2L IS USM Canon TS-E 17mm f/4L Canon EF 100mm f/2.8 Macro USM +5 more
ARShutterbug
ARShutterbug Veteran Member • Posts: 8,825
You answered your own question
The monopod is useful when:
convenient or facing situations in which using a tripod is impossible.
Aznmadness Forum Member • Posts: 91
Re: Tripod vs Monopod
Best of both worlds is to get a tripod/monopod in one.
I find a monopod useful in situations where I still need to move around and a tripod is to bulky. Although a monopod will only save you a few stops where as a tripod will be for long exposer.
** Gonna Die Waiting for the SEL 85mm or Fast Macro at a Longer FL**
 Aznmadness's gear list:Aznmadness's gear list
Sony Alpha NEX-7 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS Tamron 18-200mm F/3.5-6.3 Di III VC Sigma 19mm F2.8 EX DN +1 more
hotdog321
hotdog321 Forum Pro • Posts: 15,705
I'm a pro and own and use both--they have completely different uses:
A tripod, of course, is ideal for really long, steady exposures at night/low light or any other time you need excellent camera support. I've even used a tripod to support remote cameras out around the space shuttle launch pad (RIP) where you have to setup and leave the cameras overnight.
A monopod is a totally different, but equally useful beast. Generally smaller and lighter, it is ideal for supporting mammoth lenses used by sports and wildlife photographers or working in crowds where a tripod would pose a danger. For instance, I used one just two nights ago where I had to photograph opera singer Renee Fleming from the back of the auditorium with a 300 f/2.8. It provides support and allows somewhat longer shutter speeds.
Both support systems have their uses and you must decide when you need one or the other.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
sacentre OP Senior Member • Posts: 1,599
Thank you to those who took the trouble to give detailed and thoughtful replies.
Rankin Johnson Regular Member • Posts: 182
I have a cheap tripod and use it occasionally for portraits of my kids and the like.
I have a nice monopod (a Manfrotto automatic, with a one-hand length adjustment mechanism) and it is very useful for photographing sports; it helps to support a moderately heavy lens, and it makes it easier to track lateral movement. I haven't added a head that would let the camera tilt relative to the monopod, but I may at some point.
/s/ Rankin Johnson IV
-Fighting for justice, but I'll settle for a reversal.
Mark Scott Abeln Veteran Member • Posts: 7,775
Tripods are much more useful.
But last year, I injured my knee (it is much better now) and any kind of walking over uneven terrain could be hazardous for me, and I didn't want to carry a heavy tripod under those conditions. I got a monopod which doubled as a walking stick, and it helped me to squeeze a couple of stops of light in dim lighting.
This was taken at night with a monopod.
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF Nikkor 50mm f/1.8D +1 more
Thanks Mark, Rankin
Those were the kind of insights I was looking for. Very useful.
Trevor
Guidenet
Guidenet Forum Pro • Posts: 15,748
Tripod plus Monopod
Trevor
Trevor you need both and they both have very distinct purposes. I use a tripod in the field as well as in the studio. Not only does a tripod help with steadiness and a way to keep the camera in certain positions, but it also acts as a resting platform when your arms get tired.
The monopod comes into its own in the field on action subjects. It's easier to tilt and turn it all to pan faster moving subjects.
One point many don't get is how to implement a two method support system. The trick, in my opinion, is to make sure all your cameras and lenses with tripod collars have the same quick release plates always attached. This way I can move quickly between methods to match the conditions. I can pop it off the tripod for quick hand holding or snap it on my monopod for a smooth pan of a flying Ring Neck. Then, pop it off and back on the tripod to wait for the next situation. The key is a common connection method.
I like Manfrotto's lever RC2. Make sense? If I used a dovetail it would have to be the Acra compatible non-lever dovetail. With the arca compatible levers, the plates don't always interchange between brands.
Cheers, Craig
Follow me on Twitter @craighardingsr : Equipment in Profile - f/22 Club Member
I reserve the right to make mistakes in reasoning and logic as well as to change my mind anytime I wish. I also ask forbearance with respect to my typos. Please take a look at my gallery here at DPR.
 Guidenet's gear list:Guidenet's gear list
Canon PowerShot G1 X Nikon D300 Nikon D700 Nikon D3S Nikon D800 +31 more
Re: Tripod plus Monopod
Thank you, Craig. Interesting.
Trevor
Guidenet wrote:
Trevor
Cheers, Craig
garrywatson
garrywatson Junior Member • Posts: 39
Well the basic difference in a monopod and a tripod is that- you can use a tripod for shooting something where you need your camera to be steadiest. Monopods are used for more controled shoots than handheld. Monopods are portable than the tripods. They provide you more flexibility to move around and therefore, are good for shooting pictures that need you to move instantly and even setup instantly, such as sports, journalism, etc.
Norm Neely Senior Member • Posts: 1,494
My hiking staff also functions as a monopod.
http://www.dpreview.com/forums/post/35185358
Norm
