Panasonic G6 mini review from full frame user
Started Sep 7, 2013 | Discussions
Joachim Gerstl
Veteran MemberPosts: 6,236Gear list
Sep 7, 2013
Hi,
I tried out a Panasonic G6 I bought as a present for my mother in law ( no I really like her ). I liked it a lot that's why I wrote about my thoughts of it and how it compares to my Canon 6D or Fuji XP1.
Hope it helps those who are on the fence regarding this camera or buying into m43. Here is it:
http://www.littlebigtravelingcamera.com/?p=3600
regards
Joachim
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Panasonic Lumix DMC-GM1 Canon EOS 6D Fujifilm X-T1 +17 more
Canon EOS 6D Panasonic Lumix DMC-G6
Hen3ry
Forum ProPosts: 14,330Gear list
Re: Panasonic G6 mini review from full frame user
In reply to Joachim Gerstl, Sep 7, 2013
Joachim Gerstl wrote:
Hi,
Joachim, many thanks. An excellent short review making the appropriate points succinctly and well.
I particularly like the way you approached the G6 as a camera -- something for taking pictures -- not as some sort of adversary you need to hammer into the ground!
I also particularly liked your picture of G6 in the hand -- it puts the size into perspective. People keep talking about it as though it is a big camera when I know from the specs it is actually as small (in the real world, with a lens on it) as my E-PL3 with EVF in place.
I'm out to get a G6 in a couple of months' time. I was going to buy it myself, but as a 71 year old with a couple of married daughters, you’ve inspired me to maybe approach my sons-in-law …
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://pngtimetraveller.blogspot.com/2011/10/return-to-karai-komana_31.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-G6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic 12-35mm F2.8 +4 more
ThePhilips
Contributing MemberPosts: 699Gear list
3. If you are not in close up or street photography there is still a strong point for more DOF: when taking pictures of kids or pictures of more people. With a full frame DSLR you need to stop down to make sure that all persons are in focus. It happened to me a couple of times that I shot at f2.8 just to find out that the second face is out of focus.
[...] A perfect sensor is of no use if the image is not in focus. [...]
*Nod*.
People routinely forget about this important difference: larger DOF also means less OOF shots. And even some OOFs are still good for web resolutions.
Many years ago I went with Oly 43 cams and the larger DOF was one of the major reason. Now, without much thought, I'm too buying into the m43.
 ThePhilips's gear list:ThePhilips's gear list
Olympus E-520 Olympus E-620 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital 45mm F1.8 +8 more
Manip16
Contributing MemberPosts: 515
I think that was a well written, accurate, and overall worth reading review. Only small note I might have added is that using anything other than 4:3 on a 4:3 camera will cause IQ loss for obvious reasons.
Joachim Gerstl
In reply to Hen3ry, Sep 7, 2013
Thank you, Geoff. The camera is very small. It might look like a DSLR but it is small and light yet still very capable.
Joachim Gerstl
In reply to Manip16, Sep 7, 2013
Thank you. Maybe I'm stupid but why should I loose image quality when I use only part of the sensor?
I loose some resolution but otherwise there should be any penalty. Am I wrong?
LudwigVB
Regular MemberPosts: 337Gear list
In reply to ThePhilips, Sep 8, 2013
*Nod*.
Many years ago I went with Oly 43 cams and the larger DOF was one of the major reason. Now, without much thought, II'm too buying into the m43.
I also see greater DoF as an advantage of M43. When I was using fim cameras, I generally required greater DoF for the pictures I took. I often used the DoF scale marked on the lens (as in the OM system lenses) for zone focussing, which served me well. That's something I miss with digital cameras that have AF.
 LudwigVB's gear list:LudwigVB's gear list
Nikon D90 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 70-300mm f/4-5.6G Nikon AF-S Nikkor 50mm f/1.8G
David 247
Senior MemberPosts: 2,906Gear list
In reply to Joachim Gerstl, Sep 8, 2013
A nice brief review and well balanced on all points.  Nice that you also provided a link to an in-depth technical review.
- David
'The most important feature of any camera is 'Will you have it with you when you need it."
http://lightweaver.zenfolio.com
http://lightweaversblog.blogspot.com
http://www.youtube.com/my_videos?o=U
 David 247's gear list:David 247's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-FZ300 Olympus E-M5 II Olympus 9mm F8 Fish-Eye Body Cap Lens Olympus 12-40mm F2.8 +1 more
cwathington
Regular MemberPosts: 126
Good review. Not sure I agree about the fast lenses part. I have the PL 25mm and the Oly 45mm. They are both great wide open.
DElliott
Senior MemberPosts: 1,040
Essentially it's just cropping the photo, and thus, like you say, reducing the available resolution.  But it won't impact image quality in any other way.
Sean Nelson
Forum ProPosts: 11,592
Of course, "image quality" is a very vague and nebulous term.   But in very general terms you loose "image quality" whenever you have to enlarge an image more than "usual", whether it's because you're starting from a smaller sensor, cropping, or displaying/printing the image at a large size.   The "IQ" loss is due to factors such as reduced resolution (the bigger the pixels are reproduced, the less sharp the result), extra noise (you loose the noise averaging effects that occur when you show the picture at a small scale and noise in adjacent pixels is averaged out), etc.
When you use only part of the sensor, you have a smaller diagonal to work with.   So if you show the results (on a monitor or via printing) at the same diagonal size as uncropped images, then you're having to enlarge a little bit more and hence, I assume, the claim of "IQ" loss.
Personally, though, I think the effect is pretty small, and it's totally dependent on the idea that you're going to reproduce the image at the same diagonal size.   I can easily imagine scenarios where that wouldn't be the case.
Still, the multi-aspect sensor used on the GH1 and GH2 eliminated the issue altogether, and it's a shame that it hasn't been a feature in the latest generation of cameras.
Joachim Gerstl
In reply to Sean Nelson, Sep 8, 2013
Thank you Sean and DElliot. It confirms what I thought.
I understand that the 4:3 ratio gave the name to the whole system but I'm wondering how many people really shoot at 4:3 today and why.
Sergey_Green
Veteran MemberPosts: 8,864Gear list
I thought so also ..
I think the size of the image depends on number of pixels, and not the medium it was recorded on. Larger pixels for the same count (and on a larger frame) however is a different story, and is usually seen quite early in the images.
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
Sergey_Green
So let's call the fact as an advantage ;) ..
*Nod*.
Because you simply do not have any other option, and you won't forget.
- sergey
Joachim Gerstl
In reply to David 247, Sep 8, 2013
- David
Thank you. I think Gordon's reviews are among the best. Very balanced and without the "the best camera ever buy now" ads.
Trevor Carpenter
Forum ProPosts: 11,467Gear list
I shoot at 4:3 because I think it provides a much more attractive format than 3:2. In PP I sometimes crop to 16|:9 or 16:10. I never use 3:2. I have a 4:3 screen I may end up with a 16:9, I am never going to have 3:2 Surely 3:2 is the only format that will always give you black bits whatever screen you use. I think 3:2 is obsolete.
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
Joachim Gerstl
In reply to cwathington, Sep 8, 2013
Thank you. I have to admit that I haven't tried one of the fast lenses but m43 compared to full frame means about 2 stops difference in DOF. Combined with a shorter focal length i.e. 45mm compared to 90mm DOF is even larger.
So the 1.8/45mm acts more like a 4/90mm lens on a full frame. Something that can be achieved with the slow standard lens. Which is not impressive for subject to background separation.
If you put a real fast lens like the 1.2/85 or the 1.4/85 on a full frame camera it is a completely different story.
If you want to have shallow DOF m43 is the wrong choice. If this is not important than it is a very good choice with lot's of good and compact lenses.
mausta
Regular MemberPosts: 219
In reply to DElliott, Sep 8, 2013
GH1 and GH2 have multi aspect ratio sensors, no cropping.
jwhphotos
Regular MemberPosts: 336
I do believe that the 43rds and m43rds are named for an old film size convention and not the ratio of the sensor.
John
Kim Letkeman
Forum ProPosts: 33,332Gear list
well ...
You pretty much lost me when you quoted the classic FF addict's lament ... with a 4/3" sensor it is hard to separate the subject from the background.
A nonsense statement without all sorts of qualifications ...
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-G5 +16 more
