GH3 - Rear screen died today. :(
Started Sep 6, 2013 | Discussions
SHood
Veteran MemberPosts: 4,528Gear list
Re: GH3 - Rear screen died today. :(
In reply to sea_dragon, Sep 6, 2013
sea_dragon wrote:
Thanks for the suggestions. I did try the eye sensor but it doesn't have any effect. The screen most likely has a connector problem.
I'll contact Panasonic Canada when I get back from vacation on Monday. Thank God this camera has an EVF that is allowing me to continue shooting.
I'm heading to Europe in 5 weeks so I hope I can get this resolved by then.
If my LCD stopped working I may not find out for weeks as I rarely use it.
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
sea_dragon
Contributing MemberPosts: 742Gear list
In reply to LMNCT, Sep 6, 2013
Actually, since I live about 45 minutes drive from Panasonic Canada, I think I'm going to bring the camera to them myself. I did this with a Roland keyboard a few years ago and they looked at it on the spot. I doubt that will happen this time, but I'll be able to hopefully show them in person what its doing.
 sea_dragon's gear list:sea_dragon's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Leica Summilux DG 25mm F1.4 +4 more
sea_dragon
In reply to sea_dragon, Sep 8, 2013
I'm still curious. Does anyone know if there is a master reset for the GH3? The kind that puts it back to out of the box mode where it asks you date/time and language?
While inspecting the body for a reset button, I noticed that the camera serial number has almost completely rubbed off to the point where you can't read it.. It's just ink on a sticker rather than being etched like it is on lenses. Not sure why Panasonic opted for that. I hope this doesn't cause a warranty hassle.
Jeff Tokayer
Veteran MemberPosts: 6,114
Most electronic devices today, do not have a physical switch to perform a hard reset. It's usually done via firmware, or a combination of key presses.
My nickel, since the penny is being discontinued...
Jeff.
sea_dragon
In reply to sea_dragon, Sep 9, 2013
I dropped the camera in to the Panasonic repair shop today and was able to show the technician that will be working on the camera what it's doing. He suspects a loose connection but will know for sure when he opens it up.
Should be a quick turnaround but of course will depend if parts are needed and availability.
Mike Ronesia
Senior MemberPosts: 2,856Gear list
In reply to sea_dragon, Sep 10, 2013
Good to hear you were able to show the issue to the right person. I wish it was that easy for everyone.
Mark James
A.K.A. Mike Ronesia
 Mike Ronesia's gear list:Mike Ronesia's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH +7 more
sea_dragon
In reply to Mike Ronesia, Sep 10, 2013
Mark James
A.K.A. Mike Ronesia
Yes, it felt good to be able to do this in person.  I phoned Panasonic first and they told me where the service place was so I drove there this afternoon.  I'm lucky to be only ~45 minutes away.
sea_dragon
In reply to sea_dragon, Sep 12, 2013
I just heard from the repair technician and he said the screen itself is bad.  The connections were good.  He's ordered a new screen assembly.
PC Wheeler
Forum ProPosts: 15,051Gear list
In reply to SHood, Sep 12, 2013
Same here. Only use it for menus so far. Then back it goes, LCD against the body.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Canon PowerShot SX50 HS Panasonic Lumix DMC-FZ1000 Sony a6000 Sony E 30mm F3.5 Macro +5 more
sea_dragon
In reply to PC Wheeler, Sep 14, 2013
Phil
I use the EVF for most of my shots, but I also use the screen quite a bit for menus, awkward shooting angles and for video.  It needs to work.
The built in flash is something that I wouldn't notice if it was broken as I never use it.  In fact, I don't think I've ever used it.  But I'd still want it fixed if it were broken.
sea_dragon
In reply to sea_dragon, Sep 22, 2013
So, I got my camera back from service a couple of days ago.  New screen works great.
Then, as I was using the camera today, I could hear something rattling every so often as I handled the camera.  Then this plastic hinge cover piece fell off.  Obviously broken during the screen replacement.
Grrrr!  I just can't seem to win with this stuff.  Now I have to bring it back as this piece is broken and does not stay on.
This is why I dread getting stuff fixed as it never seems to be put back together properly.
Very frustrating.
