70-400 II produce worst images than version I?
Started Sep 2, 2013 | Discussions
Condor Senior Member • Posts: 1,768
Surfing the net for comparative reviews between old 70-400 and the new one, I found yhis youtube video.
http://youtu.be/QzKQWqTUJ6Y
But even though the reviewer sees better photos with version II, if you take print screens of the last compartive photos, version's I IQ always beat version's II. Check by yourself.
Does any of our members have acces to both versions to perform and show us independent comparative samples of several real world subjects.
I've already tested version II at my local Sony store, and focusing is very very fast... But are the outputs as focused as those provided by the slow focusing versión I?
Thanks in advance,
Ed
busch
busch Forum Pro • Posts: 31,550
Re: 70-400 II produce worst images than version I?
Condor wrote:
clip
Yes! I went form G1 to G2 and my keeper rate improved.
Busch
Take the scenic route! Life is too short to do otherwise.
My Photos
 busch's gear list:busch's gear list
Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-ZS7 Sony a77 II Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-200mm F2.8 G +11 more
Condor OP Senior Member • Posts: 1,768
busch wrote:
Condor wrote:
clip
Excellent, you have G1 and G2. Could you show to all of us real world compartive samples to verify IQs by ourselves (originals please).
Thanks in advance,
Ed
Amateur Sony Shooter Veteran Member • Posts: 5,417
I have G1 and had G2 for over a month for AB test, AF speed G2 is about 20-30% faster than G1 (still image), image quality they are the same. In some cases I think my G1 is touch bit sharper but that could be just micro adjustment issue. In the end I am keeping my G1.
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-200mm F2.8 G Kenko Teleplus Pro 300 AF 1.4x +5 more
G2
400mm comparative samples:
G1
(unknown member) Veteran Member • Posts: 3,992
1:1 crops?
EXIF?
This is where I'd normally write an impressive summary of my skills and proficiencies.
Amateur Sony Shooter wrote:
I have G1 and had G2 for over a month for AB test, AF speed G2 is about 20-30% faster than G1 (still image), image quality they are the same...
Excellent input
I also find G1 output's sharper than G2.
Ed
G1
G2
The fruit in the G2 image is back focused.
But what about the first set?
Where these 1:1 crops?
And what about shutter speed, aperture etc?
Michael Fritzen Veteran Member • Posts: 4,598
AFAIK there's not a single claim the GII is performing optically better than the G1. However I have no doubts that keeper rate can rise quite significantly because of the improved AF speed (even more when precision is maintained or even improved).
Please consider the following points as additional possible factors for improved keeper rate: 1) SLT - so no more slapping mirror and such less vibrations; 2) Better camera-AF system with MFA providing best possible precision; 3) Better high ISO performance which allows for working with faster exposure times - much more important for tack sharp photos than commonly considered (for high resolving sensors the suggestions have left the "film-time-value" of 1/FL for quite some time, oscilating now at about 1/(2 x FL) to 1/(3 x FL) for best results.
So at least for handheld shooting at long FL it's counterproductive with modern camera to main ISO low for best low noise results when results suffer degradation from blur due to handshake and/or subject moves.
Michael Fritzen
What do you mean? I do not see any single piece back of the fruit focused.
In which case. Whatt's the benefit of fast focusing... If it is not focused?
And what about shutter speed, aperture etc.
Auto mode I suppose (read the OP), but who cares? The lenses were tested using the very same alpha camera.
Ed
Ed at Ridersite Forum Pro • Posts: 17,252
Why no EXIF?  And, why shooting on auto?  The settings could have been different.  If not, how are we to know?
I don't think peaches are a very good subject for demonstrating sharpness regardless.  Animal hair or bird feathers work much better.  It's very hard to set up a good test, but using hair or a bird feather in some way might work.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony SLT-A77 Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
In the G2 image the foreground leave is in focus whereas the fruit is not. Which makes it completely useless to compare with the G1 image in this particular sample. Likewise, the first two image comparisons give no valuable image data whatsoever from which to do a comparison. To which I'd add, do nothing to help the issue along I'm afraid. ie. what arguments such as these need are resolution charts and large sample averages so as to help reduce such things as copy variance and the likes.
There's more though I think this is plenty to put a proper perspective on the limitations of these particular samples imo.
RoxanneY Contributing Member • Posts: 641
Ack!  I was assuming that Sony would do this kind of testing before releasing a new lens.  It's scary to think that the 70400G2 wouldn't be as good as the 70400G considering the prices we're talking about.
Roxanne
Dr Tone Regular Member • Posts: 204
The lens are the same optically. Upgraded focusing and improved coating on the G2.
Individual samples might be better than the other. One isn't 100% better than the other all the time.
 Dr Tone's gear list:Dr Tone's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha 7R II Sony 70-400mm F4-5.6 G SSM II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 +2 more
rob_b Contributing Member • Posts: 652
Interestingly, Ed, have a look at the single thread of gossamer on the G1, that is missing from the G2 image. Definitely either a different in focus position or sharpness.
Alan_S
Alan_S Senior Member • Posts: 1,664
Okay, I'll take the bait; have both lenses...
Haven't done any direct side by side comparison until now (gotta get around to geeing the silver one photographed and advertised for sale!). Just a quick snap from both, manually focused (with focus magnifier) on the center of the image at about 4 meters; on a tripod; taken with two separate a99, same settings, RAW, processed with identical ACR settings... Far from a scientific comparison but about as close as I'm gonna get ! .. and, as expected, I don't see any difference other than the tiniest bit of focus difference with this razor thin DOF and some movement in the grass blades due to the breeze.
G1
G2
they were taken just a few minutes apart... I see the exif shows different -- just checked an in the a99 with the G2 attached I had neglected to turn Daylight Savings 'on' so it's showing an hour early.
- AlanS
 Alan_S's gear list:Alan_S's gear list
Sony Cyber-shot DSC-RX10 III Sony SLT-A99 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-200mm F2.8 G Sony 70-400mm F4-5.6 G SSM II +3 more
G2
G1
linzdoctor7d Contributing Member • Posts: 876
Real test shots and review of 70-400 II lens!
Thanks in advance,
Ed
I trust this reviewer opinion over that dude on your you tube link any day since he does have real images to compare and not captures from a video! Hope you enjoy them sharp images in Gustav's review!
http://www.dyxum.com/DFORUM/today-try-the-new-sal70400-ssm-g-ii_topic96363_page1.html
 linzdoctor7d's gear list:linzdoctor7d's gear list
Minolta DiMAGE A1 Minolta DiMAGE 7 Sony Alpha DSLR-A700 Sony Alpha DSLR-A550 Konica Minolta Maxxum 7D +30 more
I agree.  I have the G2.  No way it's that different.  The problem is, I really can't tell what the OP did.  The crops are different, the focus is different and who knows about the settings.
AEH
