The Advantages of DR400 vs DR200 vs DR100 - High Contrast Scene
Started Sep 2, 2013 | Discussions
Elyharbour
Elyharbour Senior Member • Posts: 1,555
Re: Using Auto DR400 - What Triggers DR200 and DR400?
Trevor, do you find "average" metering generally the best for these sort of scenes?
 Elyharbour's gear list:Elyharbour's gear list
Sony SLT-A57 Fujifilm XF1 Fujifilm X30 Fujifilm X-T1 Sony DT 35mm F1.8 SAM +8 more
Trevor G OP Veteran Member • Posts: 6,541
Average is meant for everything.
Multi is meant for face detection, I believe.
I never use spot - Average works so well.
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
Elyharbour
I do find on the X20 that it often under-exposes (at least for landscapes). That's using multi. Once or twice I tried average, it seemed a little darker so went back to multi. I probably need a broader comparison in different lights / scenes to reach a conclusion on this.
That explains it - use Average (it's designed for normal use).
If it's darker, you would adjust using the EV Compensation wheel.
Cheers
Trevor G
