Canon EOS 70D VS Canon EOS 1D Mark III (Getting a new Camera)
Started Aug 31, 2013 | Discussions
Chi Hyun
Chi Hyun Forum Member • Posts: 84
*Okay guys, I am trying to upgrade a new camera from my Canon EOS Rebel T4I 650D.*
I like the both 70D and the 1DMKIII.
_The one thing that impressed me in the 70D, is the new dual-pixel sensor that auto focuses really fast.
_The one thing that impressed me in the 1DMKIII is the 10fps continuous shooting (burst) Sounds like a machine gun!
They are similary priced. But I don't know what to get.
I like to photograph trains
And marco.
Sometimes portraits too.
Maybe sports
(Video mode is not really a matter to me because I already have a Canon VIXIA Camcorder AND a T4I that records 1080p.)
Thanks for your reply (If you do)
I also have a 1DMKIII VS Canon EOS 7D in the forums: Canon EOS 1D / 5D / 6D Talk. So please check that out!
 Chi Hyun's gear list:Chi Hyun's gear list
Canon EOS Rebel T4i Canon EOS-1D Mark III Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS II +3 more
ryan2007
ryan2007 Forum Pro • Posts: 12,001
Re: Canon EOS 70D VS Canon EOS 1D Mark III (Getting a new Camera)
Buy both cameras and return one or both if you do not like them.
If you want to add to your existing DSLR and if your existing DSLR performs well you can look at a mirrorless camera system
Fuji XE-1 or Xpro-1, great still ability  APC format, 1.5x
Panasonic GH-3, very capable all in one for stills and video. Micro Four Thirds, 2x crop
I have shot with extensively DSLR and mirror less. If you like the same quality some of the mirror less options are great. You'll be amazing how small physically the gear is compared to a DSLR and how much weight you save, but performance does not suffer.
All have weaknesses and nothing is perfect. However, this idea for mirrorless is for a add on not replacement for what you seem to do.
I use the Canon XA-20 for video.
TTMartin
TTMartin Veteran Member • Posts: 7,304
For your interests I think that the 7 fps of the 70D vs the 10 fps of the 1D Mk III is inconsequential. I also think the additional resolution of the 70D would be very important.
If it were me I would choose the 70D.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 7D Canon EOS 400D +26 more
CameraCarl
CameraCarl Veteran Member • Posts: 4,374
Get the 1D if you need heavy duty water resistance (hours in the rain) and have the lenses that are water resistant, too. Get the 1D if you need a camera that takes a lot of abuse and keeps on shooting. Get the 1D if you REALLY need 10 fps (most people don't unless shooting pro sports or super fast moving wildlife). Otherwise get the 70D.
Limburger
Limburger Senior Member • Posts: 6,288
Buy a 7D.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100
GuardianFlash
GuardianFlash Senior Member • Posts: 1,418
You do realize that there's a major weight difference right? Go carry a 12+ pound weight around for half a day. That's like the 1D Mark III with lens.
 GuardianFlash's gear list:GuardianFlash's gear list
Canon EOS 70D Canon EOS Rebel SL1 Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-M 18-55mm f/3.5-5.6 IS STM
CameraCarl
That is a bit of an exaggeration. To get to 12 pounds, you'd need to carry a 1D Mark III (3 pounds) and 600mm f4 IS II.  A more realistic combination is the Mark III and the 24-105 for 4.5 pounds (still heavy, but not unbearable).
Ember42
Ember42 Contributing Member • Posts: 602
Do you do much video?  If so - 70D
Do you have good EF_S lenses?  If so - 70D
Is weight an issue? If so 70D
Do you do mostly sports or active wildlife? If so 1D3
70D is going to be the better general mix camera.  The ID3's advantage is if you are foucs speed or frame rate limited.
 Ember42's gear list:Ember42's gear list
Canon EOS M Canon EOS 7D Mark II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF 100-400mm f/4.5-5.6L IS USM +14 more
Chi Hyun
Chi Hyun OP Forum Member • Posts: 84
Thanks!!
Chi Hyun
I like to photograph trains, portraits, macro.
To be honest EF-S Lenses are not good. I'm gonna buy a USM lens because L lenses are too expensive and the EF-S focuses too slow.
Like I said, video is not a problem because I already have a T4I and a Vixia camcorder.
Thanks!
Chi Hyun
Dude the 1DMKIII is only 2.7 pounds -_-
Chi Hyun
I am only gonna spend 1200 dollars..
Thanks though
Chi Hyun
Oh, well I DO have a 1DMKIII VS 7D. Look it up somewhere in the 1D / 5D / 6D Talk
Thanks! That is still heplful
Ember42
Thanks!
Do you mean STM?
The EF-S 17-55 and EF-S 10-22 are both USM lenses, and have top flight optics.  They just have the reduced image circle for EF-S.
Jerry-astro
Jerry-astro Veteran Member • Posts: 6,518
Not accurate at all...
That's a HUGE generalization and basically inaccurate, except perhaps for your specific EF-S lens (whatever that is). The 17-55 and 15-85 are both excellent EF-S lenses with decent build quality, fast focusing, and absolutely "L" quality optics.  Even the 18-55 II kit lens has excellent optics and delivers great image quality.
If you're unhappy with your lens, and plan to stick with a crop camera, then you'll be selling yourself short by limiting yourself only to EF lenses, particularly if you don't have short term plans to move to FF.  If you're still a ways away from going to FF, then you're probably better off getting good EF-S lenses and then selling them later when you make the move.  The better lenses (such as those mentioned above) hold most of their value well.
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Carl Zeiss Touit 2.8/12 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
tommy leong
tommy leong Regular Member • Posts: 464
this has good to be one of the BEST advice on DPreview
fully agree
Chi Hyun
Oh yeah. Sorry. Most STM lenses focus slow.
Akpinxit
Akpinxit Regular Member • Posts: 262
If you mentioned "sports" and "macro" , when FF 1D is the choice for you .
I must add here , that in my understanding , these two models stand very far one from another . 1D is standard choice for professional still photo , while 70D is more tends for low badged film maker .
t.c. marino
t.c. marino Contributing Member • Posts: 649
..i'm from the other camp(nikon)most of my colleagues shoot canon,we "play"with each other's cameras.i'm a big fan of the 1d series canons..70d is newer camera with newer technology and will have better iq..BUT the speed, response,build,ergonomics"black out"time and af performance of the 1d series cameras are MUCH better than the "regular"canons.1d3 iq is still excellent..if you need the great video options and quality..go 70d..i shoot nikon ff d700 & dx 300s,both great cameras,but i prefer to shoot My "D" series nikons..BTW..i recently purchased a used EOS 1dmk2n,sent it to canon and had it overhauled with new shutter/mirror box,reskined cleaned and lubed cost me $870 including original purchase(got the camera almost for free).it looks brand new..LOVE IT as i always wanted a 1d series canon..DONT SWEAT the dxo scores for the canon cameras..serious shooters from both camp dont care about dxo scores as we are solely focused on capturing great images with our gear.the bitching that goes on here and" over there" is comical at best.good luck with you're decision
nikonshooter
t.c. marino
it's worth the weight..work out,build some arm strength,once you handle the big/bad pro series cameras from canon/nikon..hard to go back to "lesser" bodies..even if they are newer with better iq
nikonshooter
