NEX C3 vs NEX 3N
Started Aug 31, 2013 | Questions
ionutradulescu
ionutradulescu Junior Member • Posts: 29
NEX C3 vs NEX 3N
this is the question. i have the C3 and i want the 3N.
this step make any sens?
Jerry R Veteran Member • Posts: 9,135
I have a C3 and just ordered the 5R. I'm not sure what advantage the 3N has over
I have a C3 and just ordered the 5R. I'm not sure what advantage the 3N has over the 3C. There are a few reasons I went with the 5R:
1. Tilt EVF ($240 at BHphoto)
2. Smart Zoom: I'm not sure if the 3N has this. The mag on the C3 is not very good, but I have it on the R1 and find it very useful.
3. NEX-5R is $449 with a memory card & bag at BH.
Canon A2E, Sony R1, Panny TZ5, NEX C3/Zeiss 24mm E Lens, Nikon D5100 & Nikon V1
dr_elis Senior Member • Posts: 1,161
Re: NEX C3 vs NEX 3N
According to engadget.com it may make sense:
"But it's by far the most impressive entry-level Sony ILC we've seen, and one of the very best options for less than 600 bucks. Excellent image quality, a solid (but compact) build and Sony's new 16-50mm retractable zoom lens make the NEX-3N an excellent fit for interchangeable-lens hopefuls making the jump from a compact point-and-shoot, or even current NEX-3/C3/F3 owners ready for something a bit more fresh. It's a fantastically capable camera, and it looks great, too. We wouldn't hesitate to pick one up."
the 3N is currently $50 more than the 5R.
drmix New Member • Posts: 6
Heres a good link that compares the specs of the two.
http://snapsort.com/compare/Sony-Alpha-NEX-3N-vs-Sony-NEX-C3
ionutradulescu
ionutradulescu OP Junior Member • Posts: 29
Re: the 3N is currently $50 more than the 5R.
SH, not new
ionutradulescu
put the price away. is it bettter compared to C3? i want your opinion, not opinion from reviews
Larnus
Larnus Forum Member • Posts: 65
The F3 is a much better upgrade despite its ugliness. I'd go for 5R as real upgrade. my c3 balance is awful which 3n copies. tilted shutter btn of 5r better plus wifi stuff etc. works better with off cam flash too. u WD notice these things if u push c3 as much as I have with 30k shots in a yr and 3x service visits!
007peter
007peter Forum Pro • Posts: 10,307
I try 3N - disappointed, feel Cheap, Halo, with really bad LCD
ionutradulescu wrote:  this is the question. i have the C3 and i want the 3N.
I have a C3 and wanted a camera with a build-in flash as I find flash attachment annoying.  I went to camera store to but walk away very disappointed:
1. 3N LCD is horrible - not just in low resolution, but in brightness as well.  It is also very NOISY, tend to show mosquitos dots everywhere.  It reminds me of early 2001 plasma tv with poor resolution and obvious screen-door effect
2. "Single Hinge" LCD = NO Tilt down.  Older NEX 5n/5r/c3 have "double hinge" allowing it to tilt up or down.  The 3N gone cheap with just a single hinge.  Thus, you can only flip it up 180 degrees, but not down anymore.
3. Metal Grip feel cheap + slippy - doesn't hold it as well as C3
4. Thick Like a BRICK.  I dislike the Brick-Like design of nex-6, 7, and 3N.  3N is hands-on feel like a brick, its doesn't have the tiny small feel of c3 and 5n, 5r
Anyhow, sorry to throw cold water on you, but I walk away rather disappointed with 3N.  There was too much cost-cutting resulting in a camera that feel rather cheap as well.  Where as the Nex 5R (next to 3N) feel very nice.  Its LCD is superb, has soft rubber grip = feel high class, and is very small (no brick like design).
I would strongly encourage you to try it out in person (don't take anyone's word for it, including mine).  To me, 3N is a downgrade from C3.  NEX-5n/5r/5t are the better upgrade.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 25mm F1.7 ASPH
hyenadog Contributing Member • Posts: 820
its always interested me that in Sony's outlet store they sell (refurbs) the C3 for >> 3N
so in the UK the 3C with cheaper 18-55 goes for GBP299 and the 3N with more expensive 16-50PZ for GBP239  ?
ionutradulescu
i got the camera. it feels cheap. i like the flash for bounce function. i dont like the screen very much. but its newer than my C3... for 16-50 where i can find a hood?
BubbaHotepUK Regular Member • Posts: 458
I've got both (actually, the missus now uses my C3) & the answer is yes, the 3N is better but not massively so.  It's definitely an incremental upgrade as opposed to a step change.  The single biggest improvement isn't IQ, but the fact that the 3N doesn't discharge the battery when powered down - a real bugbear with the C3.
Note that the 3N never got a full firmware update to support the SELP1650 - it does work but you need to set the lens compensation to auto yourself, and obviously there is no zoom lever, so you need to use the one on the lens.
 BubbaHotepUK's gear list:BubbaHotepUK's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Sony Cyber-shot DSC-RX100 IV Sony Alpha NEX-5N Canon EOS 70D +2 more
FRANCISCO ARAGAO
FRANCISCO ARAGAO Regular Member • Posts: 186
F3 is a beauty!!
 FRANCISCO ARAGAO's gear list:FRANCISCO ARAGAO's gear list
Sony Alpha NEX-6 Sony DT 18-70mm F3.5-5.6 Sony E 18-200mm F3.5-6.3 OSS Sony Alpha DSLR-A200 Sony Alpha NEX-C3 +4 more
