Is There a Way...? (Back-button focus question)
Started Aug 30, 2013 | Discussions
hydrospanner Regular Member • Posts: 156
I'd like to set up my D300 such that the AF-ON button will begin autofocus, and when it does this, the shutter-half-press autofocus will be disabled.  Is there a way to set this up to happen automatically?
I currently have a seperate bank of shooting settings for using back-button focus, in which the half-press does nothing, but I'd like to have it set up such that the half-press AF is the normal MO, but when the AF-ON button is pressed, it overrides that.
Is this possible?
 hydrospanner's gear list:hydrospanner's gear list
Panasonic Lumix DMC-LX7 Nikon D300 Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 10-20mm F4-5.6 EX DC HSM +2 more
JusLookN Veteran Member • Posts: 4,187
Re: Is There a Way...? (Back-button focus question)
If I'm not mistaken, in the default setting (which is shutter half press), you actually have the choice of using either one for focussing. Just use the one you want to focus with.
I see what you are saying. Just go back to your custom settings and change shutter activation it to default.
Glenn
I'm kinda partial to video, but I'm hangin!
 JusLookN's gear list:JusLookN's gear list
Nikon D700 Sony Alpha DSLR-A100 Sony Alpha DSLR-A900 Nikon D3S Sony a77 II +1 more
Glenn
That should have been change shutter activation(A5) to default(shutter/AF-on).
Glenn
Julius
Julius Contributing Member • Posts: 792
Custom Functions a5, set to the AF-On only. Then the shutter will be disabled.
 Julius's gear list:Julius's gear list
Olympus E-M1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital 1.4x Teleconverter EC-14 +11 more
