Olympus 40-150mm f2.8 coming in 2014
Started Aug 28, 2013 | Discussions
Cipher Senior Member • Posts: 2,600
I wonder how big it'll be...f2.8 at 150mm.  I hope it's reasonable prices...
http://www.43rumors.com/ft5-new-40-150mm-f2-8-lens-to-come-in-2014/
tinternaut Veteran Member • Posts: 7,178
Re: Well that's not going to be cheap.....
I think some long time users of the longer Four Thirds lenses would probably prefer a 50-20 f2.8-3.5.
 tinternaut's gear list:tinternaut's gear list
Olympus E-510 Panasonic Lumix DMC-L1 Olympus E-30 Olympus PEN E-PL1 Olympus PEN E-PM2 +13 more
Cipher OP Senior Member • Posts: 2,600
Personally I think it might actually be a 40-100mm f2.8 since that makes more sense.
QuakeO Regular Member • Posts: 138
pass
Sure, f2.8 would be great to have, but I couldn't ju$tify an upgrade to my already excellent 40-150mm.
 QuakeO's gear list:QuakeO's gear list
Panasonic Lumix DMC-GF3 Olympus PEN E-PL5 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +1 more
BJL Veteran Member • Posts: 8,829
WIth the f/2.8 standard zoom going to 40mm, why would it make sense having only a 2.5x zoom range for its big brother? Going by the maximum effective aperture diameter of 150mm/2.8 = 54mm, which tends to dictate the size of the biggest and heaviest front elements, this could be comparable in size to an 80-300mm, f/5.6 for 35mm format. In fact, combining such an 80-300/5.6 with a 2x focal reducer would be one way to create a 40-150/2.8 for 4/3" format, but there are more optimal designs! So maybe no larger than the fairly common 75-300/3.5-5.6 zooms.
To put it another way, the 50-200/2.8-3.5 has a slightly larger maximum effective aperture diameter of 200mm/3.5 = 57mm, so a 40-150/2.8 could be a bit smaller.
Smaller lenses, better in low light, more telephoto reach:
you can have any *two* at one time.
 BJL's gear list:BJL's gear list
Olympus E-1 Olympus E-620 Olympus OM-D E-M5 Canon EF 28-105mm f/3.5-4.5 II USM Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +8 more
tt321 Senior Member • Posts: 7,265
Re: Olympus 40-150mm f2.8 coming in 2014
If they can make it to a similar size/weight of the 100-300 (and why not?) I'm in.
It'll be a lot bigger I think.
Skeeterbytes Veteran Member • Posts: 9,622
Definitely among those who wanted the 50-200 adapted, but if they truly hold the aperture to 2.8 at 150, then it's a viable option even if it surrenders some reach. After that they can make a 150-350/4.0!
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
brunobarolo Senior Member • Posts: 1,051
No. It will have the same diameter (since 150:2.8 is the same as 300:5.6). But it will be shorter since it's ending at 150mm, as opposed to 300mm.
Zensu11
Zensu11 Senior Member • Posts: 1,491
It would be larger but would it be a LOT longer and a LOT wider? I'd guess they would want to keep it as small as possible to accommodate the 62mm filter size to match the new 12-40 PRO lens. I can't see them adding only their second PRO lens at a different filter size than 62mm.
Maybe the lens will be a 40-150mm F2.8-4.0 variable aperture to keep size and price down?
 Zensu11's gear list:Zensu11's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +1 more
Will caution that Oly has a pretty sketchy record WRT standardizing filter sizes, so while logic may infer they'll keep the two new lenses the same, history only moderately supports it.
Am still scratching my head over the 12-40's apparently two-piece hood and how it may accommodate filters or other accessories.
Rick
—Mark Twain
azazel1024 Senior Member • Posts: 1,133
True...but it does make a certain amount of sense based on the aperature size of 53.5mm to get 150mm and f/2.8 on the long end. You should be able to do a front element and filter threads such that a 62mm filter should fit just fine on it.
I'd imagine it will not be a small lens, but I doubt it'll be that big either. As pointed out, the 50-200mm f/2.8-3.5 has a slightly larger maximum aperature, it also has 33% more reach AND it has a slightly longer lens register to work with.
If the price comes in at a resonable level, a 40-150mm f/2.8 would be very, very interesting to me. That said, if all later Olympus m4/3 cameras have PDAF on camera, an adapter and the 50-200mm f/2.8-3.5 might be a better match for me.
Anything over 100mm is going to pretty much be exclusively wildlife and sports. Sports might pick up more as my kids get older (5, 3, 17 months now), but Wildlife is always going to be a very uncommon thing for me, though I could see some times wanting a lens for wildlife (Yellowstone, if I ever go on a trip to Africa, a few others I can think of). In either case, having the ability to go to 200mm would be rather nice, though maybe not mandatory.
Many things dealing with Olympus and their OM and Pen cameras, plus my general photography and musings http://omexperience.wordpress.com/
 azazel1024's gear list:azazel1024's gear list
Sigma 30mm F2.8 EX DN +10 more
yslee1 Regular Member • Posts: 496
Ah bollocks, this is what I really want. But since I prefer Panasonic bodies, not having IS in this particular range really spoils it for me.
Sigma had a 50-150/2.8 DX lens that was fairly small with a 67mm filter size and weighed 775g, about 200g less than the 50-200. So that's likely to be the approximate dimensions this new lens will be.
Brian Wadie
Brian Wadie Veteran Member • Posts: 6,906
this agrees with what an Olympus rep told me in March this year at the Focus on Imaging Exhibition. The rumour then (amongst the UK Olympus reps) was that it may come out this Autumn but the 12-40 seems to have preceded it
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 Canon EOS 7D Mark II Canon EF 70-300mm f/4-5.6L IS USM Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 +1 more
4thnebula Senior Member • Posts: 1,978
A good match for 12-40 f2.8
Should be an excellent addition.  Then will only need a 140-300 f4.
 4thnebula's gear list:4thnebula's gear list
Canon EOS 70D Sony a6000 Sony E 35mm F1.8 OSS Canon EF 35mm f/2 IS USM Olympus PEN E-PL5 +12 more
Cane Senior Member • Posts: 6,900
Yeah, I an sure it will be reasonably priced..... cough.
