Best way to carry/use 2 cameras
Started Aug 24, 2013 | Discussions
Mike Ronesia
Mike Ronesia Senior Member • Posts: 2,938
I'm looking for something that will allow me to carry and switch between 2 cameras quickly. I've looked at this style, but don't like how the cameras hang. One body will have a flash and one won't. I was thinking maybe a chest clip for one and a holster clip for the other. I'm not having any luck finding this sort of setup though. I'd rather not have the camera attached to me while using it.
Any thoughts or ideas on where to look and maybe what they're called so I can do a search.
If I'm off track and you have other ideas that might also be helpful.
Mark James
A.K.A. Mike Ronesia
 Mike Ronesia's gear list:Mike Ronesia's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH +7 more
BBbuilder467 Senior Member • Posts: 1,421
Re: Best way to carry/use 2 cameras
Lowepro has a "Modular" system that offers a "technical" vest, harness, belt, etc. Then you can accessorize them to suit.
wazu
wazu Senior Member • Posts: 1,369
Mark James
A.K.A. Mike Ronesia
Hey Mike,Mark
The dual BR system you posted a pic of is great for stationary shooting. As you point out the swinging cameras are not comfortable when moving around. You don't indicate body and lens sizes so I can only suggest my methods for a FF Canon 5D3 and a Canon 60D. I use a belt holster (Spyder) for the 60D and a lens like the 35L along with the single BlackRapid which I attach the large FF DSLR with a 24-70 or 135L to. When walking I try to keep the large camera on the BR strap behind my hip so that it doesn't bounce around.
I also use another method with a smallish shouder bag and a DSLR plus flash accessories in it which I can pull out and use the wrist strap before reholstering in the bag. That along with another camera around my neck with conventional strap or BR. Mostly I prefer this method because you have extra gear in the bag like batteries and cards.
If you are hiking with two cameras the chest bag is a bad idea because it obstructs your view of your feet and it is easy to stumble because of that. If you use it on flat ground then it's very comfortable and convenient.
There is a crack in everything That's how the light gets in. - Leonard Cohen
Mike Ronesia
Mike Ronesia OP Senior Member • Posts: 2,938
Thanks for the suggestions. I think I'll start with something like this GTMax  It's cheap and looks very easy to get the camera in and out of. The Lowpro didn't seem to be what I was after, but the spyder might do the trick as well.
I have a Lumix GH2 and GH3 that I want to be able to switch between quickly. So much smaller then FF but not little.
Mark James
A.K.A. Mike Ronesia
speedy mate Regular Member • Posts: 140
Depending on how active you are with that setup and what you are wearing, it may become uncomfortable supporting the weight of a camera from your belt.  It really is all about personal preference, and I found mine to not like the clip holster.  You may find you love it and for that price it's definitely worth finding out for yourself.  And while my preference is to have two black rapid slings criss-crossed over my shoulders it's not everyone's first choice.
I should note that with the stud mounted systems (where you screw into the tripod mount), I am CONSTANTLY checking to make sure it is still secured.  I was shooting a 5k a few months ago and the stud worked itself out of the tripod foot on my 70-200.  Next thing I know, I'm looking down at a busted D7000 to my left and a 70-200 rolling around to the right with the camera's mounting hardware still attached.  Still love the black rapid system but now I just make sure everything's secured.
Mike Ronesia
Good info, thanks.
Mark James
A.K.A. Mike Ronesia
NancyP Veteran Member • Posts: 5,265
Cotton Carrier vest and holster:
http://buy.cottoncarrier.com/cotton-carrier-camera-system-p/124rtl-d.htm
Comfortable, less flopping about.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
I use the Cotton Carrier vest, and the bare camera (Canon 60D) is attached to the vest, so I do see my feet. Good thing, too, because most of the trails I choose are "rooty" and stony. I don't know how a pro camera grip would feel.
NancyP
Sigma DP3 Merrill
dwa1 Senior Member • Posts: 2,974
Cotton Carrier vest plus Cotton StrapShot.
Mike,
I use the Cotton Carrier vest plus the Cotton Strap Shot. Originally, I used the 2-camera system (vest and Side Holdster). But the side unit was getting in my way when I sat down to shoot close-ups.
This year I bought the StrapShot and I am very pleased with this. I attach it to my right backpack strap. I keep a Nikon D300 with a Sigma 150 f2.8 macro on the vest as this is my main / "go to" combo. I use a Nikon D90 with another (longer mm) lens on the StrapShot.
The Cotton Carrier vest goes on first, then the backpack, then the cameras. The main camera strap goes on my neck but there is no weight on the strap.
The people at Cotton Carrier have been very helpful over the years. Good same company to work with.
Hope this helps,
Wayne
Mike Ronesia
Re: Cotton Carrier vest plus Cotton StrapShot.
Thanks everyone. Looks like a few good options out there. A couple of questions. How secure are the cameras in the Cotton rig and how easy are they to take out and put back, can you switch quickly or is it a process?
Mark James
A.K.A. Mike Ronesia
Mark James
A.K.A. Mike Ronesia
Which is it? Mike or Mark?
Anyway, yes the Cotton system is very secure. Watch their short demo video about how it locks in and stays secure. Very easy to do use - putting it in and taking it out.
If you use a backpack you could simply buy 2 of the StrapShots instead of the vest and one Strapshot. I always use a backpack, but the vest and one StrapShot works great for me.
Wayne
cyrano Contributing Member • Posts: 893
OpTech dual harness
I use this to carry two large bodies with 24-70 and 70-200 lenses during long event shoots:
OP/TECH dual harness
I've used the Black Rapid dual-camera system, too. For event work, I prefer the OP/TECH dual harness for these reasons:
(1) There is no concern about putting heavy loads on the tripod sockets.
(2) There is no concern about dropping a camera if any single connector fails.
(3) There is no concern about connectors coming loose.
(4) The cameras are more stable against my body when I'm walking around -- which is really important when shooting in crowded venues.
(5) It's much easier to use this system with a tall flash bracket, as the camera remains upright when not in use. I can drop the camera/flash/bracket rig to my side without having the flash risk hitting the ground.
I find the OP/TECH system very comfortable for extended shoots. It's also very reasonably priced.
HomoSapiensWannaBe Regular Member • Posts: 265
Re: OpTech dual harness
Excellent system!  I prefer the Op/Tech double sling, though.  Securing the straps to both camera lugs gives peace of mind, but is not necessary except perhaps with heavy pro cameras and big lenses. I attach only to the left lug (opposite the grip). This way there is no strap in the way on the grip side, and it is easier to shoot verticals.
