Battery latches for Lumedyne
Started Aug 22, 2013 | Discussions
HotArt Regular Member • Posts: 118
Anyone know where I can buy latches like the ones used to hold Lumedyne Batteries to their Power supply?
 HotArt's gear list:HotArt's gear list
Olympus Stylus SP-100
UKphotographers Veteran Member • Posts: 4,175
Re: Battery latches for Lumedyne
Lumedyne would be your best bet.
Ian.
http://www.commercialphotographer.co.uk
Theres only one sun. Why do I need more than one light to get a natural result?
HotArt OP Regular Member • Posts: 118
Thanks, I did ask Lumedyne, they want to have the items sent in for repair.
This is a simple fix for me if I can buy the latches else where.
Thanks Guys, I found the latches.
Where did you find them?
Ian.
McMaster Carr.
Lawrence Keeney
Lawrence Keeney Veteran Member • Posts: 6,642
McMaster Carr is also a great place to find those hard to locate (in the U.S.) very small metric screws used in camera and camera equipment.
 Lawrence Keeney's gear list:Lawrence Keeney's gear list
Canon EOS 5D Mark III Canon EOS 6D Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
Thanks, any hard to find item, from now on, I will be checking them first.
