7D and lens(es) you can't live without.....
Started Aug 21, 2013 | Questions
yycPhotog Forum Member • Posts: 84
For all those who currently own the 7D, what lens(es) do you own that you couldn't do without,  and why?
For me, it  would be the 100 - 400 L. Beautiful lens and I love the IQ. Plus I find its fast in focusing and does a great job at capturing wildlife. I have started to use it for macro as well, but haven't quite perfected this area yet, but the more I play with it, the more I learn from it.
 yycPhotog's gear list:yycPhotog's gear list
Nikon Coolpix P900 Canon EOS 7D Canon EOS 5D Mark III Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +3 more
Jerry-astro
Jerry-astro Veteran Member • Posts: 6,714
Re: 7D and lens(es) you can't live without.....
Probably the 17-55 and 100-400L if I were hypothetically limited to only two lenses.  I find the 17-55 to be am almost ideal walkaround lens and probably use it for 90% of my shots.  When I need to go long, the 100-400L is by far the best and most versatile telephoto I've owned.
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Carl Zeiss Touit 2.8/12 Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
tonyjr
tonyjr Veteran Member • Posts: 5,256
Right now the 10-22 , 17-55 , 70-200 mk II W / 2 X III . The 10-22 , 17-55 would be replaced with same . The 70-200 would be replaced with the 28-300 .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
checkmate91 Regular Member • Posts: 102
15-85 most of the time for me. I have a 70-200 f4 for "special occasions" hehe.
I also love to use my old Oly 50 and 28 lenses on an EMF-chip adapter for still life stuff, seems to me sometimes like how real photography used to be.
 checkmate91's gear list:checkmate91's gear list
Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/4L IS USM
Calliope
Calliope Senior Member • Posts: 1,529
My 70-300L. Light, sharp and fast to focus. Really like the close focus distance and the range for action shots.
 Calliope's gear list:Calliope's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 400mm f/5.6L USM Canon EF 16-35mm f/2.8L USM +5 more
Michael Eckstein Senior Member • Posts: 2,147
I used the 70/200L and the 100/400L combination  for years and then changed to the 70/300L and the 400L ƒ5.6. Both of the lenses are better than the previous combination. The 400 ƒ5.6 is sharper wide open then the 100/400 is at any ƒ stop. The 70/300L is one of the finest lenses I have ever used, amazing quality and color rendition and is a bargain at it's current price.
 Michael Eckstein's gear list:Michael Eckstein's gear list
Canon EOS M Canon EOS 7D Mark II Canon EF-S 18-135mm f/3.5-5.6 IS Canon EF-S 60mm f/2.8 Macro USM Canon Extender EF 1.4x II +7 more
Calliope
Completely agree! I added a used 400mm and love the combination.
rdspear Veteran Member • Posts: 4,388
10-22, 24-105, 100-400.  I use all of them regularly and can't imagine not having any of them for certain shooting situations.  I have 8 other lenses, but could get by without any of them if I needed to.
 rdspear's gear list:rdspear's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Canon EF-S 10-22mm f/3.5-4.5 USM +19 more
Brian L Johnson Regular Member • Posts: 210
My 100-400 is essentially the only lens that gets mounted on my 7D, used almost exclusively for wildlife.  I use my 5D with 17-40, 24-70, or 70-200 for most everything else.
Brian Johnson
Noogy
Noogy Senior Member • Posts: 1,482
40mm f/2.8 STM. Pairs with the 7D for a flexible, generally walk-around glass, and with its light weight makes the camera a joy to carry all day.
JCC
"Photography is therapeutic."
http://www.pbase.com/joshcruzphotos
 Noogy's gear list:Noogy's gear list
Canon EOS 7D Sony Alpha NEX-5 Canon EOS 6D Canon EOS Rebel SL1 Canon EF 20mm f/2.8 USM +10 more
RJayP
RJayP Junior Member • Posts: 26
My 70-200 2.8is mk2 stays on my 7d 85% of the time
 RJayP's gear list:RJayP's gear list
Canon EOS 7D Canon EOS M Canon EOS 6D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 75-300mm f/4.0-5.6 III +12 more
skanter
skanter Forum Pro • Posts: 10,606
I don't get it. How does 112mm minimum work as a walk-around lens?  Do you only shoot things from very far away?
Sam K., NYC
 skanter's gear list:skanter's gear list
Adobe Photoshop Lightroom 5 Canon EOS 70D Sony a6000 Canon EF 50mm f/1.8 II Canon EF-S 10-22mm f/3.5-4.5 USM +10 more
Charcurt Regular Member • Posts: 351
I'm keen for the 40 mm pancake, how do you find this for portraits? Too long?
nick
 Charcurt's gear list:Charcurt's gear list
Canon EF-S 18-55mm f/3.5-5.6 IS II
happysnapper64 Senior Member • Posts: 5,180
15-85 & 70-200f/4IS L
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I'm so fast, when I turn off the light, i'm in bed before the room gets dark" The great Mohamed Ali.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 100mm f/2.8 Macro USM +9 more
Noogy
nick
Quite the opposite, since it's shorter than my 50mm f/1.4 USM.  Harder to isolate the background but sharp at wide open.  Best value for money, a must have.  For generally walk-around it's tops; for portrait and landscape it gives even L lens a run for their money.
JCC
Limburger
Limburger Senior Member • Posts: 6,438
Can't live without is a bit harsh stated but 15-85 is my walkaround and 70-200 f4 L a nice addition to it.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100
Calliope
Sam K., NY
That pretty much sums it up for me. I bet 95% of my shots over the past two years have been taken with my 70-300 and I shoot a lot. In some places it is not safe to do street shooting close in. In LA and Hollywood tourists have been killed for taking photos with their cell phones.
Zee Char Forum Pro • Posts: 10,870
300L F4 IS. My go to birding and sports lens. Light and has IS. If I had the cash I would probably pick up the 2.8 for sports.
 Zee Char's gear list:Zee Char's gear list
Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III Sigma 2x EX DG Tele Converter +3 more
rwbaron Veteran Member • Posts: 9,237
70-200f4LIS and 400f5.6L are on my 7D 75% of the time with my 300f4L third. I have the 10-22, 15-85, 24-105, 50f1.4 and 100 macro but they get little to no use. For street shooting I now use the 7D/70-200 combo with my G1X over the other shoulder which cuts down on lens changes and the 10-22 in my jacket pocket just in case. I like to extract, isolate and compress subjects hence the love of long glass
Bob
 rwbaron's gear list:rwbaron's gear list
Canon PowerShot G9 Canon PowerShot S90 Canon PowerShot G1 X Canon EOS 7D Fujifilm X-T1 +23 more
Jeff Peterman
Jeff Peterman MOD Forum Pro • Posts: 11,885
My normal kit is a 10-22, 17-55, and 70-200. When I only carry two, typically I take the 17-55 and the 70-200. If I can't take the 70-200 (size/weight/"no pro lenses") I take a 55-250 instead. If I really have to go light with the 7D, I take the 17-55 and an 85 f1.8. This is all for normal shooting - for macro, it's the 100mm macro. I have several other lenses, but essentially just use the above.
On the other hand, it's pretty clear from the above list that my real key lens is the 17-55 f2.8 IS. This is a wonderful lens with a really useful range (although I wish it went out to 85mm).
Jeff Peterman, Moderator 7D and Phone/Tablet forums.
Not a staff member, or paid employee, of DPReview.
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
www.pbase.com/jeffp25
www.jeffp25.smugmug.com
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +18 more
