XF1 setting comparisons
Started Aug 18, 2013 | Discussions
homepics Regular Member • Posts: 315
These shots are from the camera, to iphoto, and imported to dpreview. No processing was done. The comparison shots are taken on a tripod, with the timer. This first set compares EXR, Kim's and Dave's settings. The only change from the recommended settings is on Dave's. I forgot the -ev. The pictures were taken in the late afternoon.
I think EXR is out.  I don't like what it does with the foreground plants. Dave's looks a little too dark. I am not sure -ev is needed. From other tests I have done, the metering setting of Average tends to result in a darker result than Multi. The pictures were taken in the late afternoon.  Anyway, I'll see how Dave's settings worked tweaked with Multi metering instead of Average.
Dave
Kim
EXR
homepics OP Regular Member • Posts: 315
More XF1 setting comparisons
I took a few more sets of comparison shots today. Here is the first group. A pattern that emerged is that Average meter may result in better pictures after adjustments, but with no adjustment Average (to my eye) results in the picture being too dark. (More to come in a short while.)
Dave, Multi meter, no -ev
Dave Average meter, no -ev
Kim
Re: More XF1 setting comparisons
Kim
Dave, Average, no -ev
Dave, Multi, no -ev
Dave, Multi, -1/3 ev
Dave, Average, - 1.3 ev
In this set, you can really see a difference between Kim and Dave's settings. But, with the changes in Dave's settings to color, tones, etc., it is hard to tell how much of the difference is a result of the different DR setting and the M and L setting.
Dave, Average, -1/3 ev
Dave, Multi -1/3
Dave, Multi no -ev
Kim
Lloydy
Lloydy Forum Pro • Posts: 18,890
Homepics ...
... It is certainly an interesting set of comparisons you have posted.
And, there are a few unexpected results.
One is that sharpening halos are obvious in M size but not L size, The other is the M size settings seem darker than the L size.
I find this a little strange as Provia with DR 400% setting should, by rights, be lighter than Astia with DR 200%.
The main thing that has attracted my attention though is the difference between Multi and Average.
I will try some comparisons between the two as I can see Multi may have some benefit.
Thanks for all the work you have done.
In the end, it really is up to the user as to what they choose. And, you have certainly added food for thought.
Cheers, Dave
CAcreeks
CAcreeks Veteran Member • Posts: 8,810
Re: [set#1] XF1 setting comparisons
Homepic, thanks for doing this comparison! These are the only ones I looked at so far. I see you used a tripod, based on the shadow at bottom of image.
The difference between EXR and KimL could be exposure. The EXR is 1/3 stop more exposed at EV 13.1 vs 13.4. With KimL settings everything looks more 3D - not just plants in foreground, but trees in the background as well. I think this is more than can be explained by 1/3 stop different exposure. However the EXIF claims that Auto-EXR selected DR 400%, and KimL EXIF says that Development Dynamic Range = 400.
Dave's settings result in ISO 200, unnecessary f/8, and warmer colors due to film mode "F1b/Studio Portrait Smooth Skin Tone" which I think means Astia. Although the EXIF claims the Light Value = 13.8, when calculating, the EV comes out at 14.8. This is probably a bug in Fuji firmware. I feel the image is underexposed.
Well there you have it: ammunition for those who say EXR is overcomplicated with lousy defaults.
Film Mode : F1b/Studio Portrait Smooth Skin Tone
Dave
Kim
EXR
John.Laninga
John.Laninga Senior Member • Posts: 2,237
My take on the settings
Thanks for the good work, very interesting.  I have done something similar, with similar results.  Combining your experiments, and my much less rigorous testing, here are my observations:
1.  Without actually seeing the scene in person, it is hard to judge which mode is more accurate.
2.  Any mode does OK for a travel camera.  I may be a heretic here and say to just use the ones you like best.  If I want to get any more detailed then I will pull out my DSLR.
Honestly, the XF1 (as well as my LX7) are great little cameras, capable of doing a superb job as a travel camera.  Maybe our desire to pixel peep is overkill on these small format cameras.
But I do appreciate reading everyones experience with these cameras, I learn every time!
 John.Laninga's gear list:John.Laninga's gear list
Fujifilm X-S1 Fujifilm XF1 Fujifilm X30 Pentax K-3 II Pentax smc FA 31mm F1.8 AL Limited +4 more
CAcreeks
Re: My take on the settings
I don't have a DSLR. Had a film SLR, seldom used because it was too big, and DSLRs are even bigger. And heavier.
If by "travel camera" you mean something that can make posts for Facebook, all three settings are fine. So is a cellphone.
However if you want to display an image at full monitor size, especially the Apple Retina displays, the KimL settings look superior to the other two, in the first set, and probably most of the time.
Same goes for printing at 13x19, which is the maximum you can get from an affordable inkjet.
Thanks for the comments.  I did use a tripod for all pictures, with the camera timer.
I think everyone knows Kim's settings. The settings I used for Dave (which I think are his settings), are:
Program (P) mode, large (L) size, 4:3, Fine, Raw+Jpeg, DR 200%, ISO 800 (Auto), Astia, Highlight Tone - Medium Soft, Shadow Tone - Medium Soft, Noise Reduction - Medium Low, minus 0.33 EV, Photometry - Average, AF Tracking (but I used AF center for the tests).
I'll probably do some more tests next weekend (see how Kim's settings look with shadow adjusted, and maybe a few other variables).
Re: Homepics ...
Cheers, Dave
Dave,
The lowered shadow tone on your settings might contribute to your settings being lighter than Kim's.
Also, I wonder if lowering sharpening will lessen the Halos?
David
CAcreeks
homepics wrote:
The settings I used for Dave (which I think are his) are:
In the first set of images (gray house and cars across the street) the EXIF says 0 EV.
CAcreeks
Re: XF1, buildings at 25th street
In this scene, average metering resulted in .4 stop less exposure, 14.9 vs 14.5 EV. So the shadows in that one match KimL settings, while highlights in the multi-metering match KimL settings. With KimL settings the  exposure was 14.5 EV.
Large is getting better since early EXR days. However if your goal is to show this image at monitor resolution, e.g. 1600x1200, the KimL image looks more 3-dimensional and it's easier to read signs that are not in shadow. But perhaps the large image prints better, especially shadow portions of the multi-metered image.
Overall: six of one, half dozen of the other, unlike the gray house and cars, where the KimL settings were decidedly superior.
Kim
Wellington100 Veteran Member • Posts: 8,285
Re: XF1 setting comparisons
Dave
Kim
EXR
I have come to the conclusion that there is no absolute better or worse situation because both Dave and Kim PP their images and Kim has recently said that his settings are designed to do as little damage as possible to the image to facilitate better PP, which would imply that OOC, they will not look their best. A bit like the old Nikon D70 which produced very flat images specifically designed to be PP'ed, whereas the D50 images were more vibrant up OOC.
It makes comparing hard, do you compare OOC or after optimal PP of each image. Whats more, both of them are very proficient with RAW and can get more out of decent capture that way. Its hard to get to a truly objective and definitive conclusion IMHO.
Doctors are bad for your lifestyle.
