a65 for aircraft photography
Started Aug 14, 2013 | Questions
bobbydazler New Member • Posts: 11
Hi
Has anyone used the a65 for photographing an air show ie fast jets and if so could they recommend a suitable long zoom that will focus really quickly with the a65.
 bobbydazler's gear list:bobbydazler's gear list
Olympus Tough TG-2 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +2 more
Samsolar Senior Member • Posts: 2,207
Re: a65 for aircraft photography
bobbydazler wrote:
Hi
The Sony 70-300G is my go to lense.Shooting jets is not as triky as shooting prop planes at a lower shutter speed so as to catch the action of the props so that it doesn't look like the engine stopped.
 Samsolar's gear list:Samsolar's gear list
Sony SLT-A77 Sony a77 II Sony 70-200mm F2.8 G Sony 70-300mm F4.5-5.6 G SSM Sigma 50-150mm F2.8 EX DC APO OS HSM +2 more
geoffmalter
geoffmalter Senior Member • Posts: 2,513
I've used the 55-300mm at air shows successfully shooting jets and props.
 geoffmalter's gear list:geoffmalter's gear list
Olympus Tough TG-1 iHS Panasonic Lumix DMC-LX7 Sony SLT-A57 Canon EOS M Sony DT 55-300mm F4.5-5.6 SAM +8 more
Canadian Club
Canadian Club Forum Pro • Posts: 41,885
A65 with Tamron 18-270
Check one of my post.
http://www.dpreview.com/forums/post/51969865
CC
9000AF Contributing Member • Posts: 585
I've used the  A77, same EVF and sensor, with the Sigma 100-300, some examples here (1-10). Before that I had the A55 with this lens which worked well, too.
http://www.dyxum.com/dforum/aircraft-airports-15_topic95824_post1199736.html#1199736
 9000AF's gear list:9000AF's gear list
Sony RX100 Sony Alpha 7 Sony a77 II
DistantView Forum Member • Posts: 53
Geoff
I wonder if you can help me then as I took my 55-300 to a small airshow (albeit with A700 & A57) but had almost no good shots from it. The focussing was very slow and even if it did find sharp focus would then randomly go out of focus while I was following the plane.
Probably my settings are wrong but a bit of advice would help.
OP - Sorry to hi-jack your post but hopefully it will assist you too !
Many thanks
RT
DistantView wrote:
Geoff
Many thanks
RT
There are a few basic techniques for air shows, that give me OK results, I don't consider myself an expert by any means, I only attended 3 air shows so far.
AF: AF-C and central focus point help keeping planes in focus,
Apertures between f/8 and 11 provide some DOF and compensate for small focus errors. Exposure  compensation set to +1 .. +1.7 to compensate for the bright sky.
Shutter speeds vary depending on A/C type. Jets work well with 1/800 or shorter, for all planes in flight but especially for props it pays off to learn panning smoothly and keep speeds between 1/200 and 1/400.
I adjust ISO as needed to make aperture/shutter speed combinations work.
I hope this helps.
Good advice so far Shoot Manual exposure and I like center focus while I have seen other say area. I only know what works for me.
This was taken several years ago
busch
busch Forum Pro • Posts: 31,547
I am presently shooting with the a77 and the Sony 70-400 G2 and getting good results. I used the G1 before the G2. I also use the Sony 70-200 with and without a 1.4TC.
One of the prime things in shooting aircraft is to develope a GOOD panning technique.
Busch
Take the scenic route! Life is too short to do otherwise.
My Photos
 busch's gear list:busch's gear list
Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-ZS7 Sony a77 II Sony 70-200mm F2.8 G Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +11 more
bobbydazler OP New Member • Posts: 11
Many thanks to all who helped with my query on photographing aircraft.
Have now got some idea as what to go for.
